What is up with this new engine???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> What is up with this new engine???
Page: [1] 2   next >   >>
Login
What is up with this new engine??? - 5/7/2012 4:42 PM
captinjohn
Score: 247
Last Login: 5/25/2013
Status: offline
New engine video....   http://www.youtube.com/watch?v=k9Sooc9RVxo&feature=player_embedded
_____________________________
I never met a engine I did not like !
Hide Signatures
       Post #: 1
RE: What is up with this new engine??? - 5/7/2012 4:57 PM
SrTelemaster150
Score: 229
Last Login: 5/26/2013
Status: offline
IMO going from ignition to glow is a giant step backwards.
IME ignition improves power & fuel economy, at least in converted 4-stroke engines running glow fuel on EI. I would think that gasoline would see even more improvements W/ignition over glow.
The small amount of added weight in anyting larger enough to carry the ignition module & extra battery pack is not significant.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to captinjohn)
       Post #: 2
RE: What is up with this new engine??? - 5/7/2012 5:01 PM
Hobbsy
Score: 650
Status: offline
That is an engine that runs on gasoline using a glow plug.
http://enya-engine.com/180XGS_E.html
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 3
RE: What is up with this new engine??? - 5/7/2012 5:34 PM
earlwb
Score: 584
Status: offline
Yes that is a special engine design from Enya, it uses gasoline instead of methanol and nitromethane in the fuel. Now Enya does sell a special oil that is required to be mixed with the gasoline. Other than you need the special Enya oil for the engine, it isn't bad. It runs pretty good. At present Enya is not selling the engine outside of Japan.  I think the gasoline they use in Japan is different from our gasoline they use here in the USA, so it is debatable on whether it would work here or not. I almost forgot, I think they use a special glow plug too.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to Hobbsy)
       Post #: 4
RE: What is up with this new engine??? - 5/7/2012 7:10 PM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
Price using today's conversion rate: $916.77
Hide Signatures
(in reply to earlwb)
       Post #: 5
RE: What is up with this new engine??? - 5/7/2012 9:51 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Hobbsy
Which begs the question-Why?
Hide Signatures
       Post #: 6
RE: What is up with this new engine??? - 5/7/2012 10:28 PM
earlwb
Score: 584
Status: offline
Gasoline tends to be more inexpensive in comparison to glow fuel, especially glow fuel with nitromethane in it. So there have been people interested in it as with a glow plug, one gets away from needing a spark ignition system and its associated equipment.
Yeah it is a bummer about how the Japanese Yen keeps going up in value while the US dollar keeps going down in value. It sure sucks to have to pay the higher price for Enya engines if you want one.
AMA # 928076
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 7
RE: What is up with this new engine??? - 5/7/2012 11:15 PM
Hobbsy
Score: 650
Status: offline
So you lose the Fred Flintstone aged ignition system.
Hide Signatures
       Post #: 8
RE: What is up with this new engine??? - 5/8/2012 1:48 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Hobbsy
Compared to a modern CDI ignition system, a glow ignition is primitive.
quote:
ORIGINAL: earlwb
An electronic ignition is no more expensive or complicated than an on-board glow driver & it's a lot more convenient than using an external glow power source.
I'm converting ALL of my Saitos, a 91, a 150, two 180s, a 200 TI twin & a 300 TTDP twin to C&H electronic ignition. I get 6%-10% more power & 25% better fuel economy. I see no advantage to running a large gas 2-stroke on glow ignition.
Hide Signatures
       Post #: 9
RE: What is up with this new engine??? - 5/8/2012 3:22 AM
earlwb
Score: 584
Status: offline
Cool. I do not blame you at all. I even say go for it. That is what makes this hobby so great as there is something for everyone everywhere.
AMA # 928076
Hide Signatures
       Post #: 10
RE: What is up with this new engine??? - 5/8/2012 4:01 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: SrTelemaster150
quote:
ORIGINAL: Hobbsy
quote:
ORIGINAL: earlwb
I dis-agree on that. Lets make a list.
1. No ignition unit to buy.
2. No worry on placement of CD unit.
3. No Ignition battery to buy.
4. No charging of a ignition battery.
5. No ignition switch needed or to replace ...viabration kills em.
6. No sparkplug cap that needs a secure ground or clamp.
7. No sparkplug wire to route or maintain.
8. No RF interference from a CD ignition to worry about.
9. No special advance curve on ignition...wrong curve...idle will jump RPM
10. Lite weight with many less electrical componets needed.
11. Just real simple to start & run. It does not get any more easy.
Thanks Capt,n  PS if they are like Gas/glow engines...the Idle is slower and smooth.
Hide Signatures
       Post #: 11
RE: What is up with this new engine??? - 5/8/2012 1:08 PM
Hobbsy
Score: 650
Status: offline
Your #1 reason is axactly why I said you could lose it the ignition system.
Hide Signatures
       Post #: 12
RE: What is up with this new engine??? - 5/8/2012 1:28 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: captinjohn
OK by me.
With glow ignition you either buy an on board glow driver or deal W/the inconvenience of a clip on device.
If you have several battery packs you can use the same type pack as you use for your RX as an ignition battery. Hardly a deal breaker to me.
With glow ignition you must either "place" an onboard glow system in the plane or "place" an external glow power device on the glow plug to start the engine, remove it after starting & then "place" it somewhere when you remove it after starting. You must do this "double placement" EVERY TIME you start you glow engine.
With EI you merely turn on the switch, start the engine & take off. I have never had to add ballast weight to a plane for proper CG. I just use the "placement of the ignition module & battery as ballast.
With glow ignition you must buy an external glow driver (battery) If you use an existing glow device, the same can be said for an ignition battery. Just use one of the many battery packs uased for Rx.
With glow ignition you have to "charge" the battery for the glow power.
I use the same type switch for igniton that I use for my Rx. If these switches are unreliable then loss of the RX would be much worse than loosing engine power. That could happen W/a glow engine too.
I use a McDaniels plug cap. It pushes on & twists to lock on just like a glow driver. It has a grounded shield in the wire, no external ground needed although I do run a wire from the module to the engine case.
I have not had to replace a sparkplug wire yet
This comes under the heading of proper set up. I've never had any RF interference in the plane. Just keep some distance between the ignition system & the RX/servos & use a non metalic throttle linkage.
With glow ignition you have no advance curve to help W/smooth transition. Buy a quality EI system & you will have the proper advance curve for the engine. Buy a cheap Chinese knock off & that might not be the case.
With glow ignition you must clip on a glow power device to start your engine, remove it after it starts, then place the glow power device somewhere before you can fly.
It's much simpler to turn on an ignition switch, start the engine & take off.
This last statement is just ludicrous. After going from glow to electronic ignition I can typically get 300-400 RPM lower reliable idle & easier starting. I also typically get 150-200 more RPM on top. That = more HP!
If you are intimidated by setting up an ignition system then so be it. It does take some knowledge & skill to set up EI. Some lack these talents so in those cases, glow might be a more attractive alternative.
Run glow if you can't properly set up an EI system, but don't try to make it sound like an improvement.
Hide Signatures
       Post #: 13
RE: What is up with this new engine??? - 5/8/2012 1:53 PM
TFF
Score: 148
Status: offline
Ignition systems are a hobby in themselves. Glow made this hobby. Is one better ? Always arguable. But if ignition was the solution, why was glow invented? I like ignition with glow there is some advantages, but they are small and for the experimenter more than the public.
Hide Signatures
       Post #: 14
RE: What is up with this new engine??? - 5/8/2012 2:17 PM
Sport_Pilot
Score: 233
Status: offline
That is not true, the advance curve is built into the plug, the plug retains heat better as the engine speeds up as there is less time between power cycles.  This has the effect of advancing the timing at full speed.  Also much effort has been made with this natural timing advance with more recent glow plug designs.  Plugs that were the right heat range at full speed and too cold at idle are using a thicker element with more platinum in the alloy to keep the plug hotter at idle for example.
Ignition does give more precise timing, however the advantage may not significantly increas RPM.  A recent poster had only 100 more RPM on glow fuel when adding an ignition system on a glow engine.  However he can now run gasoline or any methanol/gas mix he feels gives him the right power and economy combiniation he desires.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
(in reply to TFF)
       Post #: 15
RE: What is up with this new engine??? - 5/8/2012 4:30 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Sport_Pilot
100 RPM @ the top of is significant when a large prop is involved & the fuel consumpsion is factored in. My FA 150 gained 150 RPM W/a Dynathrust 18X8 prop, 7700 to 7850 RPM & ran 23% longer on the same 16oz 15% Cool Power fuel load. That equated to a gain of .155 HP & .67# of thrust on .81 power/fuel factor.
http://www.rcuniverse.com/forum/fb.asp?m=11069268
Take the increased HP/.81 & it equates to 31% more HP per fuel units consumed.
2.759HP/2.607HP = 5.8% increase 1.058/.81 = 1.306 = 31%
Also, the HP increase of the EI over glow was taken @ the initial timing advance setting of 28* BTDC. When I tested the E85/Klotz mix, the power drop was so drastic that I tried more timing advance & gained 300 RPM. I think I might have seen similar HP gains W/15% nitro/methanol fuel. I will soon test the 15% Cool Power fuel @ more aggressive spark advance to see what additional HP/thrust gains there are to be had.
Switching a large 2 stroke from spark to glow ignition, even on gasosline (which might show even more significant loss over 15% nitro methanol fuel) WILL result in a signifiacntv loss of HP per fuel consumed.
In small 40 sized or even some 60 sized aircraft, EI is not viable due to the bulk of the systems. When a lage enough aiurframe is involved, the weight of the fuel required for a given flight time will off set the weight of the EI system.
IMO, .91 4-stroke is the displacement threshold for cost/benefit as glow Vs spark ignition. I'm not sure where that threshold lies for 2-strokes, but the large 180 Enya would definately be above that threshold I believe.
Something else you guys are not taking into cosideration is that the gasoline used in that clip was 100 octane. Where are you going to find reasonably priced 100 octane gasoline readily available to the average R/C pilot?
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 16
RE: What is up with this new engine??? - 5/8/2012 6:39 PM
blw
Score: 655
Status: offline
Maybe it's just me, but I don't find any problems with attaching and removing glow igniters when I crank engines. I never thought of it as an issue.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 17
RE: What is up with this new engine??? - 5/8/2012 6:41 PM
Sport_Pilot
Score: 233
Status: offline
Sunoco.  avgas, or racing fuel.
< Message edited by Sport_Pilot -- 5/9/2012 1:20 PM >
Hide Signatures
       Post #: 18
RE: What is up with this new engine??? - 5/8/2012 10:44 PM
blw
Score: 655
Status: offline
Potsdam Municipal Airport-Damon Field is about 12 miles from your location, and they have avgas.
Coach Pat Dye
Hide Signatures
       Post #: 19
RE: What is up with this new engine??? - 5/8/2012 10:55 PM
earlwb
Score: 584
Status: offline
Why would you need 100 octane gasoline? These engines aren't big enough to need hi-octane stuff.
I think the marine or boat gasoline from places located around marinas and such locales would be a better choice, as it is a lower octane gasoline.
But then if you live in the desert far from a lake, you could have problems.
AMA # 928076
Hide Signatures
(in reply to blw)
       Post #: 20
RE: What is up with this new engine??? - 5/8/2012 11:42 PM
controlliner
Score: 100
Last Login: 5/24/2013
Status: offline
One thing to note is the oil they used, they said most two cycle oils they tried, destroyed many of their engines.
"Keep it clean and not too lean" Duke Fox
Hide Signatures
       Post #: 21
RE: What is up with this new engine??? - 5/8/2012 11:55 PM
Desertlakesflying
Score: 120
Last Login: 5/20/2013
Status: offline
quote:
Where are you going to find reasonably priced 100 octane gasoline readily available to the average R/C pilot?[/quote]
Yup, I go to Reno/Stead airport where the air races are held, drive out on the tarmac, pull up to the gas pump, use my card just like at the gas station, and fill up my jug.
Pretty simple if you ask me.
Back Roads Outlaws Revver #165
Hide Signatures
       Post #: 22
RE: What is up with this new engine??? - 5/9/2012 12:00 AM
Jim Thomerson
Score: 160
Status: offline
Fly diesel, no down side except the smell. After a few gallons run through, you won't notice it anymore.
Hide Signatures
(in reply to Desertlakesflying)
       Post #: 23
RE: What is up with this new engine??? - 5/9/2012 12:40 AM
fred985
Score: 112
Status: offline
diesel is great and a magneto ignition gets rid of a ton of crap too. i never had one of my old mag fired gas engines fail me. i will admit that they are easier to start with a starter,,,it can be hard to spin them fast enough to start by hand.
Hide Signatures
(in reply to Jim Thomerson)
       Post #: 24
RE: What is up with this new engine??? - 5/9/2012 1:48 AM
do335a
Score: 105
Last Login: 5/18/2013
Status: offline
Interestingly enough, that's exactly what the model engine manufacturers said about going back to ignition from glow when glow engines were introduced to replace spark ignition engines.
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> What is up with this new engine???
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
