Need Some help Regarding Cat build and the parts I received!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> Need Some help Regarding Cat build and the parts I received!!!
Page: [1]
Login
Need Some help Regarding Cat build and the parts I rece... - 5/7/2012 11:08 PM
EuroXS4
Score: 100
Last Login: 8/12/2012
Status: offline
 Hey guys So I received a 42" catamaran laser cut kit today just have some questions as I do not have the plans for this kit so If any of you could identify where some of the pieces go that would be a big help.Also It seems as I have 1 extra bulkhead perhaps I am not sure.Someone correct me if im wrong??Here are the pics.
Also It seems as bulkhead D either cat cut too deep or is it supposed to sit that deep within the frames??Its the only one that seems out of place.Anyone Confirm this or have the same plans or instructions for this model??
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Need Some help Regarding Cat build and the parts I ... - 5/8/2012 2:01 AM
EuroXS4
Score: 100
Status: offline
Also which glue should I use to glue all this together??And can I use balsa to skin this hull???or should I use something else???Any input would be greatly appreciated.
Hide Signatures
(in reply to EuroXS4)
       Post #: 2
RE: Need Some help Regarding Cat build and the parts I ... - 5/8/2012 12:26 PM
clockworkclock
Score: 100
Last Login: 5/19/2013
Status: offline
I'm not exactly sure what glue to use, I would probably say some wood glue since the frame is wood.
I've seen people skin their hulls with both balsa and plywood, the plywood is more durable so it could be a better option.
Clock.
_____________________________
If it isn''t capable of turning itself into shrapnel, it needs more power!
Hide Signatures
       Post #: 3
RE: Need Some help Regarding Cat build and the parts I ... - 5/8/2012 12:44 PM
Hydro Junkie
Score: 116
Status: offline
The slot for that one frame was miscut so a filler will be needed if it's exposed in the tunnel. As far as glue, I'd go with a slow set epoxy. Epoxy will handle the pounding a boat of this type takes better than almost all other types. It can also be used to seal the wood against water damage as water will get in to the boat. As far as skin, I'd go with 1/16 aircraft grade ply. I"ve been building hydroplanes using West Systems Epoxy and birch ply for years, best materials I've found to date
Hide Signatures
(in reply to clockworkclock)
       Post #: 4
RE: Need Some help Regarding Cat build and the parts I ... - 5/8/2012 3:43 PM
ryan_t888
Score: 357
Status: offline
I too would use 1/16" plywood to skin the hull as well as 30 minute epoxy to hold everything together.
Hide Signatures
(in reply to Hydro Junkie)
       Post #: 5
RE: Need Some help Regarding Cat build and the parts I ... - 5/8/2012 9:39 PM
EuroXS4
Score: 100
Status: offline
any idea on where the other pieces should go that are laid out.The 2 large flat pieces that are bulkheads  one of them I dont think I need as it is bulkhead F there is 2 different ones and last blukhead I believe Is the transom.However all other pieces laid out I am clueless about.Also should I glue the 4 pieces that run bow to stern first?? then glue the bulkheads into those??I know in the picture It looks like there is 2 pieces that run bow to stern but if you look at the first picture at the bow you can see a line that dips below the bulkhead surface that line is another shorter 5/32 birchply that runs bow to stern just a shorter distance.
Hide Signatures
(in reply to ryan_t888)
       Post #: 6
RE: Need Some help Regarding Cat build and the parts I ... - 5/9/2012 11:35 PM
Hydro Junkie
Score: 116
Status: offline
I think you have several of the cross frames in the wrong places. Starting with the one that fit too low, move all the cross frames aft of that point back one slot and see if the extra cross frame fits in the deep slot. Without having the kit here in front of me, I'm just guessing on how it's set up
Hide Signatures
       Post #: 7
RE: Need Some help Regarding Cat build and the parts I ... - 5/9/2012 11:48 PM
huck1199
Score: 115
Last Login: 5/18/2013
Status: offline
Could the extra bulkhead be a doubler for the transom?
Hide Signatures
       Post #: 8
RE: Need Some help Regarding Cat build and the parts I ... - 5/10/2012 1:31 AM
EuroXS4
Score: 100
Status: offline
Hey guys thanks for the input.Each frame or bulkhead does have a  letter etched into it that corresponds to the slots on the side frames.Here is a picture of th frame in order from the bottom up.Unless they are labelled wrong.Let me know what you guys think.I would assume G and G' is a double up for the transom.However I make no sense of F and F' only thing I can come up with is that F" is for when your planning on running 2 motors and F is just for one.
Click for fullsize
< Message edited by EuroXS4 -- 5/10/2012 1:52 AM >
Hide Signatures
(in reply to huck1199)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
