RE: AMR High Wing Stick 30    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Rcexl Opto Gas Engine Kill Switch ***FREE SHIPPING***
Seller:  swgiantscalemodels
Details:   $13.29   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: AMR High Wing Stick 30
Page: <<   < prev  3 4 5 6 7 8 9 10 [11] 12   next >   >>
Login
RE: AMR High Wing Stick 30 - 7/10/2012 11:54 PM
WacoNut
Score: 175
Last Login: 5/23/2013
Status: offline
I stopped and picked up some new 1-1/2" long bolts for the engine. I installed the bolts along with heavy fender washers and locking washers. They did not have 10-32 T-Nuts or the Nord-Lock washers.
Once the engine was mounted I tested the ignition and all was well. I installed a 18x10 Xoar wood prop I had flown on the Stick previously and test ran the engine. After some minor linkage and trim adjustments all is well. The engine is pulling 7300rpm with the 18x10 and was pulling 8700rpm with the 18x6. The engine has much more thrust with the 18x10 prop.
I will take the Stick back out flying this Saturday at our Club Fun-Fly and get some video.
Later!!
Anthony
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to WacoNut)
       Post #: 251
RE: AMR High Wing Stick 30 - 7/11/2012 1:58 AM
VincentJ
Score: 145
Status: online
Great to see it back together again!  Looking at your last photo I noticed that you didn't use the silicone wire wrap on the spark plug wire as well as the clip to secure the ignition connector from comming apart.  May be good insurance to install.
VJ
Hide Signatures
       Post #: 252
RE: AMR High Wing Stick 30 - 7/11/2012 2:37 AM
WacoNut
Score: 175
Status: offline
Nice Spot VJ,
I will put them on before Saturday. I just threw the basics together to make sure the engine would run fine. Hard to believe the plane and the engine dropped from such an altitude and nothing was seriously damaged. The gear legs may or may not hold up under the stress of landings. I am afraid they have been weakened from the bending. I will see how they hold up this weekend and if they start bending out I will get another set of legs from AMR.
Later!!
Anthony
Hide Signatures
(in reply to VincentJ)
       Post #: 253
RE: AMR High Wing Stick 30 - 7/20/2012 10:51 AM
VincentJ
Score: 145
Status: online
Anthony, have you flown your Stick now that the repairs have been made?
VJ
Hide Signatures
       Post #: 254
RE: AMR High Wing Stick 30 - 7/28/2012 9:30 PM
impulse09
Score: 100
Last Login: 5/22/2013
Status: offline
This one maidens tomorrow, weather permitting. 15lbs dry, Mintor 38 for power. Cut one servo out by joining the elevator halves with a wire.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Don S :)
Hide Signatures
       Post #: 255
RE: AMR High Wing Stick 30 - 7/29/2012 12:25 AM
WacoNut
Score: 175
Status: offline
Looks really good, make sure you give us a flight report.
I would really suggest starting with the throws at the recommended settings. I thought the elevators looked small and added more throw and it was very sensitive on the 1st flight.
Later!!
Anthony
Hide Signatures
(in reply to impulse09)
       Post #: 256
RE: AMR High Wing Stick 30 - 7/30/2012 2:52 AM
impulse09
Score: 100
Status: offline
Got three flights on it today. I thought it was tail heavy because it was dropping the tail in the turns, but it passed the 45 degree inverted upline test and the CG is where it is supposed to be. Using rudder in the turns cleans up this behavior. Needs differential on the ailerons.
Where did yours balance and how did it fly?
Don S :)
Hide Signatures
       Post #: 257
RE: AMR High Wing Stick 30 - 7/30/2012 3:22 AM
WacoNut
Score: 175
Status: offline
I balanced mine right on the wing tube per the manual.
My stick will also climb in a turn if you do not input rudder. I am used to flying my 1/3 Cub and using rudder all the time so I am used to it.
A guy in my club has a GP big stick and it fly's the same way, tail low. His does not want to clinb in the turns. Maybe some differential will help a little.
Glad to hear your flights went well.
Anthony
Hide Signatures
       Post #: 258
RE: AMR High Wing Stick 30 - 10/20/2012 4:20 PM
Smash McCrash
Score: 100
Last Login: 3/9/2013
Status: offline
I want to thank Waco for a great guild thread. I have been looking at AMR Stick kits for a while and always wondered about the quality. After seeing this and hearing that you have built 3 of their kits, I am finally going to get the 30cc kit, eventually. Gotta sell some of the smaller crap that I don't want anymore. I was about to start scaling up a set of plans that I found online, but the kit will be easier and quicker, but knowing that they turn out tail heavy, I will probably make some changes to try to alleviate the need for nose weight. Maybe move the tail servos out back...
Mike
Hide Signatures
       Post #: 259
RE: AMR High Wing Stick 30 - 10/20/2012 5:11 PM
WacoNut
Score: 175
Status: offline
Mike,
I have been enjoying flying my Stick. I have been playing around with the wing incidence on mine. The plane tends to climb while turning if a generous amount of rudder is not input. I have raised the L/E of the wing by 3/16" and it behaves much better in the turns.
Later!!
Anthony
Hide Signatures
(in reply to Smash McCrash)
       Post #: 260
RE: AMR High Wing Stick 30 - 10/22/2012 1:57 PM
flygilmore
Score: 131
Last Login: 5/16/2013
Status: offline
I love the blue and white impulse..........looks great! Sometimes folks way over do a scheme and it looks tacky. Yours is nice and clean and those colors flow nicely with the planes lines!
I didn''''t choose Mojo, Mojo chose me PRO BRO #1963
Hide Signatures
       Post #: 261
RE: AMR High Wing Stick 30 - 10/30/2012 7:17 PM
sl5406
Score: 100
Status: offline
WacoNut,
After building and flying the 30cc AMR high wing stick, I would like your opinion about the use of a Saito GlowTwin (50cc) with CDI ignition for power on it. I have had the this Saito 300 for several years but have not found a suitable airframe for it. Would it overpower the airframe, and would weight and balance be an issue on the AMR 30CC Stick? Your opinion would be appreciated.
sl5406
Hide Signatures
       Post #: 262
RE: AMR High Wing Stick 30 - 10/31/2012 10:28 PM
WacoNut
Score: 175
Status: offline
I am not familiar with that engine. The DLE-30 is a good match for this plane and it is by no means over powered. I did have to add quite a bit of nose weight to get mine balanced so you can stand to have a heavier engine. The largest prop I would fly this plane with is a 20" prop, anything bigger and you may start to have ground clearance issues.
Good Luck!!
Anthony
Hide Signatures
(in reply to sl5406)
       Post #: 263
RE: AMR High Wing Stick 30 - 12/22/2012 8:56 PM
pippip
Score: 100
Status: offline
Just getting ready to pull the trigger on the high wing version as I have an OS GT33 without a home. What torque rating for the servos does the manual call for?
Hide Signatures
       Post #: 264
RE: AMR High Wing Stick 30 - 12/22/2012 9:28 PM
WacoNut
Score: 175
Status: offline
I don't know what I did with my manual. I am using Hitec HS645-MG's on all the control surfaces.
Anthony
Hide Signatures
(in reply to pippip)
       Post #: 265
RE: AMR High Wing Stick 30 - 12/23/2012 6:34 PM
pippip
Score: 100
Status: offline
Anthony,
Thanks! I think I am going to add flaps and use 4x 9252s in the wing. They are 92 oz-in (@4.8v) each so I should be good, total power will be little > a single HS645.
Pip
Hide Signatures
       Post #: 266
RE: AMR High Wing Stick 30 - 12/23/2012 9:58 PM
WacoNut
Score: 175
Status: offline
I mixed flaps into the ailerons. Not that it is needed as the plane slows down really nice without flaps.
Later!!
Anthony
Hide Signatures
       Post #: 267
RE: AMR High Wing Stick 30 - 1/18/2013 8:58 PM
pippip
Score: 100
Status: offline
The fuse is completed . What size servo arms and engine standoffs did you end up using?
Hide Signatures
       Post #: 268
RE: AMR High Wing Stick 30 - 1/20/2013 1:30 AM
WacoNut
Score: 175
Status: offline
quote:
ORIGINAL: pippip
Sorry about the delay,
I used the standard arms that came with the Hitec 645's. The engine stand-offs are what came with the DLE-30 as well.
Later!!
Anthony
Hide Signatures
       Post #: 269
RE: AMR High Wing Stick 30 - 1/20/2013 3:13 AM
Smash McCrash
Score: 100
Status: offline
I've been working on my stick and am really happy with how it's turning out. I was a little disappointed with some of the laser work originally, but I came up with a fix for The seriously torched balsa. All of the cutting for the ply has been great, it's just the thick balsa that was in need of some creative repair. I have the fuse and tail surfaces ready for final sanding, with the main landing gear adjusted more to my liking. I also replaced the bolts for DuBro axles and the small wheels with 5" DuBro lites. I bent the landing gear to give a lower and wider stance. I like the look much better. I have my 7985's in for the elevators, and a 7955 for the rudder. I will have my DLE 35RA on Monday to get that fitted. I have just started the wing. The jig and laminated parts are ready to start the full assembly.
Mike
Hide Signatures
       Post #: 270
RE: AMR High Wing Stick 30 - 1/21/2013 1:49 PM
malitape
Score: 100
Last Login: 5/19/2013
Status: offline
Pictures, pictures, where are the pictures?????
pete
Cub Brother #129
Hide Signatures
       Post #: 271
RE: AMR High Wing Stick 30 - 1/23/2013 5:41 AM
Smash McCrash
Score: 100
Status: offline
Ok, got it now. Enjoy!
Mike
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Smash McCrash -- 1/23/2013 6:04 AM >
Hide Signatures
(in reply to malitape)
       Post #: 272
RE: AMR High Wing Stick 30 - 1/23/2013 2:56 PM
malitape
Score: 100
Status: offline
Looking great, Mike. Don't be shy about posting more pics as you work on a specific area.
Any mods or shortcuts will help others (me) as we follow build threads. Thanks for sharing.
pete
Cub Brother #129
Hide Signatures
       Post #: 273
RE: AMR High Wing Stick 30 - 1/23/2013 6:29 PM
pippip
Score: 100
Status: offline
Hello! I had the same problem with the thick balsa parts which seemed to impact the pieces for the square rudder. I was looking to build the round one so it was not a large impact to me. The fuse and tail fins went together great.
The pics below are the first step of the wing assembly. AMR did a great job with the jig, it is a vary large plus!!!!!!!
My only large deviation will be that I am adding flaps. I created copies of W19 and W18 and will install them between ribs 3 & 4. I fully understand that they are not needed on this model but I have couple others in the works that do so I am going to use this plane as my experimentation/training platform.
Pip
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 274
RE: AMR High Wing Stick 30 - 1/23/2013 7:22 PM
vertical grimmace
Score: 154
Status: offline
quote:
ORIGINAL: WacoNut
Went flying this morning. I took my Stick 30 and my 33% Cub. 1st up was the Stick 30. I did about 5 circuits of the field with a couple of loops and rolls then shot a practice approach. I throttled up to go around and climbed for altitude as I turned cross wind, all of the sudden the Stick pitched straight up and the engine died. I immediately noticed the engine hanging from the fiewall by the spark plug wire . I leveled the plane out and made a gentle turn towards the runway when the spark plug wire let loose of the engine and it dropped straight into a soybean field as the plane once again pitched straight up due to the severe change in CG. The plane immediately stalled and was at an altitude of about 75ft. I held in full down elevator and the plane dove towards the ground. At about 15ft of altitude I went full up elevator and the plane again pulled up and stalled about 8 ft above the beans and then just dropped straight into the beans in a flat attitude. I found the plane sitting on it's gear in the beans with the main gear slightly sprung and a couple of minor dings on the top wing surface from the engine. The engine was found approx. 100ft away in the bean field. The engine hit the ground on it's side and bent one of the standoff bolts. The interesting thing is the prop. One blade was split right up the middle and the other blade was delaminated. This was a Xoar 18x6 laminated prop.
I know the engine was tight before the flight. I have put 12 flights on the Stick since the last time the engine bolts were installed. This was the 3rd flight with this prop on the plane. The prop blade that was split up the middle appeared to be from the impact but the delaminated prop blade looks alot different. Is it possible the blade started to delaminate during the flight? I did tach the engine before the flight and it was pulling 8700rpm on the ground.
I am still puzzled at how all 4 bolts could come loose enough that they would all completely back out in just a 5 minute flight. The prop was well balanced and there wasn't any excessive vibration during runup before the flight. All 4 bolts were thru the fiewall and into the stand-offs with washers and lock washers and thread locker.
Anyhow I feel very lucky to get the plane on the ground in one piece. I will get some new bolts and change the bolting of the engine to a more bulletproof method.
I will get some pics of the plane and prop later.
Anthony
One suggestion, many times the firewall can compress from tensioning the bolts. So essentially they become loose because of this. Typical problem with gassers. One trick, is to drill a series of holes around the mounting bolt for the stand offs. Then insert and glue 1/16" dowels or toothpicks around the bolt hole. This provides strong end grain to be present behind the washers. Also, thread lock on all of these bolts. Never had one come loose set up this way.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
       Post #: 275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
