REFERENCE SETTING K-170-F    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
K-170F
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> KingTech Turbines International >> REFERENCE SETTING K-170-F
    Page: [1]
    Login
    REFERENCE SETTING K-170-F - 5/8/2012 2:37 PM
    passagealanglaise
    Last Login: 2/7/2013
    Status: offline
     KINGTECH K170-F
    Factory Menu Start :
    Auto +2
    Pump Start Ramp 5
    Glow Power 7,4V
    Low Batt 7V
    Start Power Ignit 150
    Starter Power Fuel Ramp 150
    RPM 100% Starter 16000
    RPM Stop 19000
    RPM Reconnect 18000
    RPM Ignition 5000
    Pump PW Ignition 18
    Engine Min Flow 30%
    EGT End 120°C
    RPM Preheat K 5000
    RPM Fuel Ramp 5000
    Preheat Fuel 45%
    Ignit Time Out 27s
    Start Mode AUTO KERO
    Factory Menu Run :
    Full Power 123000
    Idle SPeed 34000
    Stop Peed 20000
    Start Min 100°c
    Max temp 840°C
    ACC DELAY 7  (possible without any problems to low as 4, even lower depending the elevation)
    DEC DELAY 4
    Stability Delay 100
    Pump Limit 600
    Review Data :
    Menu Start :
    Auto +2
    Pump Start Ramp 5
    Glow Power 7,4V
    Low Batt 7V
    RPM 100% Starter 15000
    RPM Stop 20000
    RPM Reconnect 19000
    RPM Ignition 3000
    Pump PW Ignition 17
    Engine Min Flow 30%
    EGT End 120°C
    RPM Preheat K 5000
    RPM Fuel Ramp 6000
    Preheat Fuel 30%
    Ignit Time Out 27s
    Factory Menu Run :
    Full Power 123000
    Idle SPeed 34000
    Stop SPeed 20000
    Start Min 100°c
    Max temp 840°C
    ACC DELAY   4
    DEC DELAY 4
    Stability Delay 100
    Pump Limit 600
    < Message edited by passagealanglaise -- 6/8/2012 12:06 PM >
    Hide Signatures
           Post #: 1
    RE: REFERENCE SETTING K-170-F - 5/8/2012 7:04 PM
    KC36330
    Last Login: 5/22/2013
    Status: offline
    quote:
    ORIGINAL: passagealanglaise
    ACC DELAY 7
    That's on the high side, you shouldn't have any problems as low as 4, even lower depending on your elevation.
    _____________________________
    JetCat USA Rep / KingTech Turbines Rep
    Hide Signatures
    (in reply to passagealanglaise)
           Post #: 2
    RE: REFERENCE SETTING K-170-F - 5/8/2012 7:40 PM
    passagealanglaise
    Status: offline
     I will edit the first post
    Hide Signatures
    (in reply to KC36330)
           Post #: 3
    RE: REFERENCE SETTING K-170-F - 5/10/2012 11:03 PM
    passagealanglaise
    Status: offline
    Guys
    what do you think about this data :
    RPM Ignition 5000
    RPM Preheat K 5000
    RPM Fuel Ramp 5000
    Strange no?
    Hide Signatures
           Post #: 4
    RE: REFERENCE SETTING K-170-F - 5/12/2012 6:49 PM
    passagealanglaise
    Status: offline
    hello
    Does somebody can compare his K170F setting with mine?
    Regards
    Hide Signatures
           Post #: 5
    RE: REFERENCE SETTING K-170-F - 5/12/2012 10:21 PM
    KC36330
    Status: offline
    hello
    Regards
    this is all i've got handy on mine at the moment........
    Click to see fullsize image.
    Click for fullsize
    Hide Signatures
           Post #: 6
    RE: REFERENCE SETTING K-170-F - 5/13/2012 5:27 PM
    passagealanglaise
    Status: offline
     thank you very much !
    With this setting your run on Diesel or Kerosen?
    Hide Signatures
           Post #: 7
    RE: REFERENCE SETTING K-170-F - 5/13/2012 5:36 PM
    KC36330
    Status: offline
    I use Jet A and JP8.
    Hide Signatures
           Post #: 8
    RE: REFERENCE SETTING K-170-F - 5/13/2012 5:54 PM
    passagealanglaise
    Status: offline
     ok same as me
    I will test your setting next week end
    Thank you very much
    Hide Signatures
           Post #: 9
    RE: REFERENCE SETTING K-170-F - 5/14/2012 3:09 PM
    mackeyjones
    Last Login: 4/14/2013
    Status: offline
    I found with the decreased Acceleration delay (4) it actually seemed at certain points during a quick acceleration to be pumping slightly too much fuel in. I am at sea level, and it was running on a test bench, otherwise mine ran fine on those settings.
    Hide Signatures
           Post #: 10
    RE: REFERENCE SETTING K-170-F - 5/14/2012 3:25 PM
    KC36330
    Status: offline
    I'm at less then 300' ASL and have acceleration delay set at 3 with no problems. i've had it as low as 1 but got some sputter during high speed spooling in flight, no problems at all at low speed/bench test.
    Hide Signatures
    (in reply to mackeyjones)
           Post #: 11
    RE: REFERENCE SETTING K-170-F - 5/15/2012 6:23 PM
    Nick Yuhasz
    Status: offline
    quote:
    ORIGINAL: KC36330
    hello
    Regards
    I purchased a USB adapter cable for the ECU10 and downloaded the Fadec V5 software from the Xicoy site and installed it on my WIN7 laptop. Appears to work fine except I cannot get to the parameter screen you show above. I can download the parameters to a file, but cannot display them as you have.
    Any suggestions?
    Nick
    Nick Yuhasz
    Amherst, Ohio
    Hide Signatures
           Post #: 12
    RE: REFERENCE SETTING K-170-F - 5/15/2012 7:49 PM
    KC36330
    Status: offline
    no idea, mine works on XP and Win7, maybe try reloading it.
    Hide Signatures
    (in reply to Nick Yuhasz)
           Post #: 13
    Page:   [1]
    Page: [1]
    K-170F
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    1.016RCU1
