4 Line Fuel Tank    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> 4 Line Fuel Tank
Page: [1]
Login
4 Line Fuel Tank - 5/10/2012 2:19 AM
BobH
Score: 116
Last Login: 5/21/2013
Status: offline
I have a Laser 300 twin. I'm using a 24oz tank with two clunks and a vent line for the fuel supply. I need to think of a way to add a fourth (fill) line. Any one have an idea? thank you.
_____________________________
BobH.
Hide Signatures
       Post #: 1
RE: 4 Line Fuel Tank - 5/10/2012 2:50 AM
B Shipp
Score: 100
Status: offline
Can't you use one of the clunk lines to fuel and de-fuel? Use a fuel dot to plug off the fill line.
Hide Signatures
(in reply to BobH)
       Post #: 2
RE: 4 Line Fuel Tank - 5/10/2012 3:23 AM
John Baligrodzki
Score: 100
Status: offline
Bob,
What if you added a fitting to the bottom rear of the tank for your fill line? Then make sure the fuel dot is higher than the tank. Never done this. Only downside if that line comes off or if the fitting leaks then fuel everywhere you do not want it.
John
Hide Signatures
(in reply to B Shipp)
       Post #: 3
RE: 4 Line Fuel Tank - 5/10/2012 3:47 AM
BobH
Score: 116
Status: offline
I won't have access to the fuel lines once the cowl is on. So thats the reason for the separate fill line. I can add a nipple to the tank, I suppose. I'm using a Dubro tank. It's suspended inverted in the front of the cowl. I would have used two separate tanks per Laser's instructions but I don't have room.
BobH.
Hide Signatures
(in reply to John Baligrodzki)
       Post #: 4
RE: 4 Line Fuel Tank - 5/10/2012 5:22 AM
fytrjok
Score: 115
Last Login: 5/20/2013
Status: offline
Does the Laser have separate feeds to twin carbs? Why couldn't you just T off the main fuel line and use the second clunk line for fill and drain?
Hide Signatures
(in reply to BobH)
       Post #: 5
RE: 4 Line Fuel Tank - 5/10/2012 2:18 PM
BobH
Score: 116
Status: offline
I could use a T but I worry about one carb drawing more fuel and starving the other. Others I've spoken with all use a separate clunk. I know that works with no issues.
BobH.
Hide Signatures
(in reply to fytrjok)
       Post #: 6
RE: 4 Line Fuel Tank - 5/10/2012 3:42 PM
quist
Score: 116
Status: offline
Dreamworks sells tank fittings. you can put this in the top of the tank and use it as an overflow or put it in the bottom and use it as a fill and drain.
Click to see fullsize image.
Click for fullsize
If you don''''t have time to do it right the first time, when are you going to find time to do it again?
Hide Signatures
(in reply to BobH)
       Post #: 7
RE: 4 Line Fuel Tank - 5/10/2012 5:05 PM
BobH
Score: 116
Status: offline
I could "T" off of one of the fill lines. My only concern in doing that is I'll flood the carb/engine at that carb. The cylinders are inverted so I don't want to flood one and get a hydrolic lock.
The carbs aren't accessable once the cowl is on.
I'm on my way to the LHS to see what I can find.
BobH.
Hide Signatures
(in reply to quist)
       Post #: 8
RE: 4 Line Fuel Tank - 5/10/2012 6:22 PM
fytrjok
Score: 115
Status: offline
Only other thing I can figure is to install two separate tank systems.
Hide Signatures
(in reply to BobH)
       Post #: 9
RE: 4 Line Fuel Tank - 5/11/2012 2:51 AM
BobH
Score: 116
Status: offline
I have a solution. I plumbed the tank with two carb lines with clunks and a fill line with a clunk. At the LHS I bought fuel nipple that is threaded, has a shoulder and a nut. I drilled a hole in the top of the tank that was sized to let the fuel nipple thread into. Then on the inside of the tank the nut was secured. This arrangement compresses the nipple onto both sides of the tank. To prevent any leakage I made a latex gasket that fits under the shoulder, just in case.
I'll post a picture later...
BobH.
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.471RCU1
