U.A.T. ????    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> U.A.T. ????
Page: [1]
Login
U.A.T. ???? - 5/10/2012 2:30 PM
Jetfan20
Score: 107
Last Login: 5/23/2013
Status: offline
Hi Guys,
Which U.A.T. do you guys use for the larger turbines, lets say class 160 or larger. I have read do to the strong fuel demand from the larger turbines one should consider the all aluminum or CF U.A.T's. Has anyone had any trouble with the BVM or Hanson U.A.T's collapsing? What's your experience?
Thanks in advance,
Hide Signatures
       Post #: 1
RE: U.A.T. ???? - 5/10/2012 2:38 PM
AndyAndrews
Score: 151
Status: online
I use Tom Cooks UAT. It doesn't collapse (its made of machined alum.) also it has larger fittings for larger fuel lines. Here is the link:
http://www.jetmodelproducts.com/accessories.htm
Hide Signatures
(in reply to Jetfan20)
       Post #: 2
RE: U.A.T. ???? - 5/10/2012 2:54 PM
lov2flyrc
Score: 109
Status: offline
I would suggest either the Jet Model Products unit as Andy listed above or the GBR Jets Composite Air Trap (CAT)
See Here: http://dreamworksrc.com/catalog/gbrjets-composite-trap-130ml-p-1970.html
or the Larger version: http://dreamworksrc.com/catalog/gbrjets-composite-trap-large-260ml-p-1971.html
We also offer the JMP version.... http://dreamworksrc.com/catalog/machined-accumulator-large-fittings-p-2058.html
All these units have fittings sized for larger engines which drastically reduce fuel restriction, easing load on the pump.
_____________________________
Todd Witkoff
Dreamworks Model Products LLC
www.dreamworksrc.com
Your Source For RC Jet Accessories!
Hide Signatures
(in reply to AndyAndrews)
       Post #: 3
RE: U.A.T. ???? - 5/10/2012 2:55 PM
DominicM
Score: 101
Status: offline
GBR Jets CAT
Hide Signatures
       Post #: 4
RE: U.A.T. ???? - 5/10/2012 2:57 PM
Jetfan20
Score: 107
Status: offline
Thanks for the input guys...
Todd I was on your site last night trying to decide. Which size do you recommend, how much fuel does the typical U.A.T holds?
Hide Signatures
(in reply to DominicM)
       Post #: 5
RE: U.A.T. ???? - 5/10/2012 3:29 PM
lov2flyrc
Score: 109
Status: offline
For what engine?
The Hanson and BVM UAT hold 4oz.
Todd
Todd Witkoff
Hide Signatures
       Post #: 6
RE: U.A.T. ???? - 5/10/2012 3:37 PM
kimhey
Score: 100
Status: offline
I use a BVM UAT together with my Behotec 180 Gold.
Hide Signatures
(in reply to lov2flyrc)
       Post #: 7
RE: U.A.T. ???? - 5/10/2012 3:55 PM
marc s
Score: 110
Status: online
Jetfan,
The CAT 'M' is a 130ml unit, this is roughly 4.4oz and would be fine with 100-180N turbines, whilst it would also be fine with a 180N+ turbine you will not have much reserve should you drain the main tanks so a CAT 'L' would be a better option in this case - the L is 260ml, so roughly 8.8oz.
They come with a mount too and can be positioned in almost any orientation.
marcs
Hide Signatures
(in reply to kimhey)
       Post #: 8
RE: U.A.T. ???? - 5/10/2012 4:24 PM
Jetfan20
Score: 107
Status: offline
Todd,
Rhino or K-170
Hide Signatures
(in reply to marc s)
       Post #: 9
RE: U.A.T. ???? - 5/10/2012 4:44 PM
lov2flyrc
Score: 109
Status: offline
Standard BVM or Hanson will work fine with this size engine; OR you could go with the Medium CAT or the JMP Accumulator. Personally prefer the JMP or CAT units.
Todd Witkoff
Hide Signatures
       Post #: 10
RE: U.A.T. ???? - 5/10/2012 4:53 PM
FenderBean
Score: 119
Last Login: 5/22/2013
Status: offline
MAP makes a high flow version and it works fine.
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
       Post #: 11
RE: U.A.T. ???? - 5/10/2012 4:59 PM
Wap4life
Score: 110
Status: online
Here is what i use!
Wap
Hide Signatures
(in reply to FenderBean)
       Post #: 12
RE: U.A.T. ???? - 5/10/2012 5:23 PM
phjoker
Score: 100
Last Login: 4/27/2013
Status: offline
quote:
ORIGINAL: FenderBean
Same here.
http://dreamworksrc.com/catalog/high-flow-trap-p-1596.html
Pete H
A Happy Jet Central Falcon & Rhino Owner
Hide Signatures
       Post #: 13
RE: U.A.T. ???? - 5/10/2012 5:36 PM
bluescoobydoo
Score: 105
Status: online
wren 160 just the normal size uat, has been fine in two jets
I just ran out of talent !!!!!!!!
Hide Signatures
(in reply to phjoker)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
