CAMBER MIX USED TO WORK WITH 14MZ DOES NOT WITH THE 18 (IS IT A BUG)?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Futaba Radios Direct support forum >> CAMBER MIX USED TO WORK WITH 14MZ DOES NOT WITH THE 18 (IS IT A BUG)?
Page: [1]
Login
CAMBER MIX USED TO WORK WITH 14MZ DOES NOT WITH THE 18 ... - 5/11/2012 8:46 PM
tassos p
Score: 100
Last Login: 5/18/2013
Status: offline
HELP PLEASE
I need to set up CROW on my jet - it used to work fine on my 14MZ but does not anymore on the 18MZ although I copied the files and everything else seems to work very well.
I have set CROW through the "CAMBER MIX" menu under the "MODEL MENU"
Can you please check with your radios out there when you select any condition (I have made a separate "CROW CONDITION") when you press the ACT/INH button what are the alternatives on your radio. It should be ACT or INH right? Well in mine it is either ACT or OFF (see picture bellow). I can't set CAMBER MIX to ACT. I can't activate the CAMBER MIX and thus the CROW. Very strange.
Just to clarify things the wing layout is with 1 servo for flaps and 2 separate ailerons as per attached picture.
Can you please check on your radios if you get the same? Is this a bug or does the "OFF" depend on something else which I'm missing????
If in the 'SWITCH' you choose 'ON' the CAMBER MIX doesn't depend on a SWITCH it is always 'ON'.
By the way I upgraded the sw of the radio to v2.1.0
Your feedback would be greatly appreciated.
Tassos
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: CAMBER MIX USED TO WORK WITH 14MZ DOES NOT WITH THE... - 5/12/2012 11:28 AM
tassos p
Score: 100
Status: offline
Ok, not a bug, but quite difficult to find it out. I was breaking my head all these days because it worked in the 14 and not the 18.
The answer?
CAMBER is a function.
One needs to set it in the FUNCTION menu. Transfering models from the 14 to the 18 will not activate the CAMBER function automatically. One needs to activate it manually in the Linkage Menu> Function
Find a spare channel and insert CAMBER function.
In the manual it does not mention that CAMBER function needs to be activated in order for CAMBER Mix to be able to work.
Anyway, busted. Be carefull activating CAMBER as a function the radio assigns automatically a switch to it (RST) and you need to deactivate it > set to NULL otherwise CAMBER mix will be affected.
Now my crow works fine.
Thanks alot
Tassos
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to tassos p)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
