Tornado S30 Transmission/Differential Broken?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Tornado S30 Transmission/Differential Broken?
Page: [1]
Login
Tornado S30 Transmission/Differential Broken? - 5/11/2012 10:37 PM
fun4oli
Score: 100
Last Login: 7/4/2012
Status: offline
I am relatively new to RC cars.
We have been running the Tornado S30 off-road for three times. The last time we were at a racing track. We used the car without a problem for maybe an hour. Then it was my turn and I did a few laps. I had a light crash and the motor went out. After we restarted it the motor was able to rev up but the car did not move.
When I just roll the car on the ground now (at home) it rolls freely but rolling it does not turn the central drive shaft. Also all wheels spin freely.
I am not an expert, but on my recently bought Volcano S30, when I turn one wheel the other turns as well, the other way. And when I roll my model on the ground it turns the central driveshaft.
What is the issue here with the Volcano? Is the gear box for the rear wheels (is that a differential?) broken? Would I just buy the whole thing and then replace it? Or whatever is in the midle of the car, that enclosed box between the tank and the motor, could that be broken?
Hide Signatures
       Post #: 1
RE: Tornado S30 Transmission/Differential Broken? - 5/11/2012 10:48 PM
Dads like rc too
Score: 540
Last Login: 6/18/2013
Status: offline
Sounds like you stripped a spur gear.
_____________________________
Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
Hide Signatures
(in reply to fun4oli)
       Post #: 2
RE: Tornado S30 Transmission/Differential Broken? - 5/12/2012 12:32 AM
fun4oli
Score: 100
Status: offline
But which one, where? How do I investigate? And how do I fix it?
Hide Signatures
(in reply to Dads like rc too)
       Post #: 3
RE: Tornado S30 Transmission/Differential Broken? - 5/12/2012 1:52 AM
lakesrunner
Score: 100
Last Login: 3/9/2013
Status: offline
 He's talking about the the gear in the transmission. The one you set the gear mesh with, it's in the middle of the buggy.
Hide Signatures
       Post #: 4
RE: Tornado S30 Transmission/Differential Broken? - 5/12/2012 4:59 AM
fun4oli
Score: 100
Status: offline
Thanks!
Actually the whole mystery was solved today. The rear grub screw, the one where they tell you in the manual to definitely loctite it (which we never did because it is so hard to reach), had come loose. Aha! So today I invested four dollars in a hex key set and tighten it. Of course we were so eager to go run the car again that we did not bother to loctite it and then lost the screw alltogether. OK, go an buy grub screw, this time loctite it for sure, and off to happier times.
Hide Signatures
(in reply to lakesrunner)
       Post #: 5
RE: Tornado S30 Transmission/Differential Broken? - 5/12/2012 12:15 PM
Dads like rc too
Score: 540
Status: offline
Sorry, didn't catch the part where you said you rolled it on the ground and the tranny didn't turn. At that point it would be obvious something had just come loose in the drivetrain. The Grub screws are notorious for this. Glad you figured it out on your own.
Hide Signatures
       Post #: 6
RE: Tornado S30 Transmission/Differential Broken? - 5/12/2012 5:44 PM
lakesrunner
Score: 100
Status: offline
Great you got it going. Did you loctite all your other grub screws? The same thing can happen.
Hide Signatures
       Post #: 7
RE: Tornado S30 Transmission/Differential Broken? - 5/13/2012 12:03 AM
fun4oli
Score: 100
Status: offline
There are two, right, one in the front and one in the back?
Hide Signatures
       Post #: 8
RE: Tornado S30 Transmission/Differential Broken? - 5/13/2012 4:46 AM
Dads like rc too
Score: 540
Status: offline
quote:
ORIGINAL: fun4oli
4. Rear diff cup, rear tranny cup where brake disk is, front tranny cup, front diff cup.
Basically each cup on each end of the center dog bones.
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
