GP Hole Locator to mount servos    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> GP Hole Locator to mount servos
Page: [1]
Login
GP Hole Locator to mount servos - 5/12/2012 4:12 PM
KitBuilder
Score: 131
Last Login: 5/21/2013
Status: offline
As i was mounting the servos in the quite tight space of my current build I had the idea to use my GP Hole Locator for marking engine mount holes to mark the holes through the servo grommets. Maybe others are already doing this. This proved invaluable as its easily used with one hand allowing the other hold the servo and rail in place. Will be using this for any applicattion whether I have space or its cramped.
http://greatplanes.com/accys/gpmr8130.html
< Message edited by KitBuilder -- 5/13/2012 2:05 PM >
_____________________________
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
       Post #: 1
RE: GP Hole Locator to mount servos - 5/12/2012 5:20 PM
KaP2011
Score: 115
Last Login: 5/22/2013
Status: offline
My GP hole locater is one of the most used tools on my bench. I use it any time I need a small hole centered, cowls, engine mounts, landing gear, servos. Come to think of it, I need to order a new one in case I wear this one out.
KaP2011
Ultra Sport Brotherhood #110
KaP2011
AMA #408493
Hide Signatures
(in reply to KitBuilder)
       Post #: 2
RE: GP Hole Locator to mount servos - 5/12/2012 8:49 PM
daveopam
Score: 191
Last Login: 5/18/2013
Status: offline
These are great. Mine is in my flight box cause I have used it at the field.
david
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to KaP2011)
       Post #: 3
RE: GP Hole Locator to mount servos - 5/25/2012 9:21 PM
dmbaerry
Score: 100
Status: offline
I am going to order one.
Hide Signatures
(in reply to daveopam)
       Post #: 4
RE: GP Hole Locator to mount servos - 5/26/2012 1:47 AM
DavidAgar
Score: 146
Status: offline
One of the best tools designed for RC. I have 3 of them and use them for everything. Good Luck Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
(in reply to dmbaerry)
       Post #: 5
RE: GP Hole Locator to mount servos - 5/26/2012 6:40 AM
Roguedog
Score: 105
Status: offline
I have to agree.This is one of the simplest and best designed tools I have in my toolbox. Centers the holes perfectly on motor mounts. No longer have to oblong the engine mounting holes in my RC engines.
Hide Signatures
(in reply to DavidAgar)
       Post #: 6
RE: GP Hole Locator to mount servos - 5/26/2012 4:38 PM
Lone Star Charles
Score: 105
Status: offline
This is one of my favorite tools for locating holes for mounting just about anything.
When I am drilling holes for a set of servos, I will usually draw the servo layout using AutoCAD and then print the drawing.  I can then use masking tape to locate the servo drawings on the support rails.  It gives a perfect layout every time.  The only complaint that I have is that it is sometimes difficult to get the exact measurements of the mounting holes from some of the servo manufacturers.
Hide Signatures
(in reply to Roguedog)
       Post #: 7
RE: GP Hole Locator to mount servos - 5/27/2012 3:19 AM
smithcreek
Score: 159
Status: offline
I chuck the knurled knob in my hand drill, makes it even easier to make a good deep pilot hole in aluminum engine mounts and when you drill the real size hole the bit does not wander at all.
For a kit you are, and to a kit you shall return.
Hide Signatures
(in reply to Lone Star Charles)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.281RCU1
