why are tires so expensive?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> why are tires so expensive?
Page: [1] 2   next >   >>
Login
why are tires so expensive? - 5/14/2012 2:13 PM
hanly2
Score: 100
Last Login: 6/10/2012
Status: offline
My son keeps tearing the tires off of his rustler and I have to keep looking for new tires and wheels.  He rips the tire right off the wheel or he strips the hex inside the wheel.  I have been finding used sets for pretty good prices but this is crazy.  What are some good tires that I can get at a great price.  Is there ever any really good deals that anyone has seen?
Hide Signatures
       Post #: 1
RE: why are tires so expensive? - 5/14/2012 2:42 PM
cumquat
Score: 210
Last Login: 5/24/2013
Status: online
proline dirt hawgs are a good. they have great traction on most surfaces and last for a long time. if the tire keeps coming off the rim, they arent glued properly. stripping hexs is caused by a few things, most commonly a loose wheel nut. the nylon in lock nuts will wear out the more you remove and install the nut. just replace the nuts when you change them this time and you should be good to go. if they strip again let us know.
_____________________________
HELP! IM STUCK ON AN ESCALATOR!
Hide Signatures
(in reply to hanly2)
       Post #: 2
RE: why are tires so expensive? - 5/14/2012 2:50 PM
phmaximus
Score: 627
Status: offline
thats strang that the tyre is comming of the wheel. generally thats because they were not glued correctly
and the stripping of the hex??? how??
might be time for hime to revise his driving style to save on rubber.
is there a chance he could be doing doughnuts and all the power is going to one wheel?? then over reving the wheel untill it brakes the glue on the bead
What motor, ESC and voltage?
To help find a tyre what are u after? hard wearing?
Where is generally driven? on road or offroad?
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
(in reply to cumquat)
       Post #: 3
RE: why are tires so expensive? - 5/14/2012 3:04 PM
hanly2
Score: 100
Status: offline
of course he is doing doughnuts, he is bashing the heck out of it that is why it is fun.  he has a rustler vxl running 2s lipo. he runs 50/50 on/off road
Hide Signatures
(in reply to phmaximus)
       Post #: 4
RE: why are tires so expensive? - 5/14/2012 4:06 PM
The_Shark
Score: 494
Last Login: 5/6/2013
Status: offline
I would tell him if he doesn't ease up on the abuse a little, he has to find a way to pay for the tires
There is a difference between bashing and abuse....
see if you can find some belted tires, or you can attempt to belt them yourself with some window screen and shoe goo
Signature
(Max. 125 chars. 2 lines max)
Hide Signatures
       Post #: 5
RE: why are tires so expensive? - 5/14/2012 5:12 PM
yakfish
Score: 426
Last Login: 5/21/2013
Status: offline
Why are tires so expensive???
Supply and demand my friend!
Hide Signatures
(in reply to The_Shark)
       Post #: 6
RE: why are tires so expensive? - 5/14/2012 6:35 PM
LaTuFu
Score: 275
Last Login: 8/31/2012
Status: offline
If he's bashing the truck hard and ballooning up the tires a lot, especially on asphalt, its going to be hard to keep the budget low on tires.  I watched my son burn up a brand new set of tires in one bash session on the driveway.  He was "UFO'ing" his Rusty as fast as he could.  The rear tires looked like pizza cutters the whole time.  When he was done, the tires literally peeled apart from the centerline because that was the only contact patch on the tires.  He bought the replacement set with his allowance, much to his dismay.  Amazingly, that set has lasted much, much longer.
Like the Thunder Tiger MT4 G3? Check it out on wondertiger.com
Hide Signatures
(in reply to yakfish)
       Post #: 7
RE: why are tires so expensive? - 5/14/2012 8:39 PM
Phoenix XB Racer
Score: 175
Last Login: 6/3/2012
Status: offline
One reason why tires are expensive is because they are needed. Unless if you are drifting with PVC wheels, you need tires.
New 2012 King Motor 1/5 23cc Gas Petrol KSRC-001 RC Baja Buggy
Hide Signatures
       Post #: 8
RE: why are tires so expensive? - 5/14/2012 8:47 PM
jayjay283
Score: 110
Last Login: 9/26/2012
Status: offline
rubber comes from rubber trees generally in the rain forests of south america. It does drip from the trees nonstop but people have to collect it and be paid then it has to be shipped most likely through the panama canal which is $400k ticket plus a freighter burns something around $1600 an hour in gas. Why arent tires more expensive may be a better question
Hide Signatures
(in reply to Phoenix XB Racer)
       Post #: 9
RE: why are tires so expensive? - 5/14/2012 9:22 PM
hanly2
Score: 100
Status: offline
Yeah so I am leaning toward just getting a new set of rear all stars and a set of dirt hawgs.  I think that would be the best choice for all terrain driving.
Hide Signatures
(in reply to jayjay283)
       Post #: 10
RE: why are tires so expensive? - 5/14/2012 9:51 PM
The_Shark
Score: 494
Status: offline
quote:
ORIGINAL: jayjay283
tires are a ripoff im sorry, they just are, when you can buy a cheap 1/1 car tire for $40 and 4 buggy tires cost as much if not more.
foams are even worse, if you go all nuts on them not only will they bald in two runs, they will also "chunk"
my advice is to buy the cheapest tires you can find, and put some traction compound on em.
Signature
Hide Signatures
       Post #: 11
RE: why are tires so expensive? - 5/14/2012 10:58 PM
jayjay283
Score: 110
Status: offline
I was just looking at buying some xl moabs for a gmaxx im turning 1/6th, they dont make them anymore and a 1/2 crap used set it $100 LOL no way man, I can hike to brazil and gather my own rubber while eating spiders for that price
Hide Signatures
       Post #: 12
RE: why are tires so expensive? - 5/14/2012 11:15 PM
nitrosportsandrunner
Score: 296
Status: online
it gets worse if you want scale looking wheels/tires for a rock crawler. you can spend $80-$100 on some sets!
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
       Post #: 13
RE: why are tires so expensive? - 5/15/2012 12:30 AM
phmaximus
Score: 627
Status: offline
quote:
ORIGINAL: hanly2
So eccentally u are complaining about him doing burnouts and doughnuts and the tyres are wearing excessively?
What did u expect? He needs to revise his driving habits or just keep buying them for him
My only other thought it get him some drift tyres, then he wants to bash it use rubber tyres, when he wants to abuse it use PVC drift tyres.
Or he is not suited to a 2wd truggy. Might be worth thinking about something els
Oh how does he strip the wheel hexes? On what setup?
Hide Signatures
       Post #: 14
RE: why are tires so expensive? - 5/15/2012 12:33 AM
phmaximus
Score: 627
Status: offline
Per kg of rubber Rc tyres are a rip off, well mainly the big brands.
Check the price of 1/5 rubber wow....
Best value s 1/10 touring car rubber... Heaps cheaper
Hide Signatures
       Post #: 15
RE: why are tires so expensive? - 5/15/2012 1:06 AM
SyCo_VeNoM
Score: 626
Status: offline
quote:
ORIGINAL: phmaximus
1/8th scale buggy tires off ebay $25 for 4 preglued
think I spent more on my 1/10th scale TC tires without rims
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
       Post #: 16
RE: why are tires so expensive? - 5/15/2012 1:09 AM
jayjay283
Score: 110
Status: offline
buy some anaconda traxxas tires, those have crap traction and he can burn out all day
Hide Signatures
       Post #: 17
RE: why are tires so expensive? - 5/15/2012 2:03 AM
hanly2
Score: 100
Status: offline
I am not complaining about his driving habits at all.  put it this way, I have the stampede vxl and I beat the snot out of it and still have the stock tires and wheels with no damaged hexes.  I also drive his car the same way.  His tires are not going bald, he had the original set and the rears came unglued.  Then he burnt the hex on one of the wheels so we p/u a set of slash rims and tires and when he was driving it this weekend a big chunk of one of the tires just fell off.  So we put the stockers back on ( i had glued the hex into the burnt wheel)  he drove it for a while before the glue broke loose.  So now I have 2 sets one has a bad tire and the other has a bad wheel.  And don't give me no bs about the price of rubber $20 for a set of these tires is a joke, you can get 4 wheels for $20.  My motorcycle tires were only $50 and my car tires only cost me $100 for 18" performance tires.  basically I can get a whole stampede for $80 but a new set of wheels and tires cost $60-70.
Hide Signatures
       Post #: 18
RE: why are tires so expensive? - 5/15/2012 2:29 AM
SyCo_VeNoM
Score: 626
Status: offline
quote:
ORIGINAL: hanly2
I am not complaining about his driving habits at all.  put it this way, I have the stampede vxl and I beat the snot out of it and still have the stock tires and wheels with no damaged hexes.  I also drive his car the same way.  His tires are not going bald, he had the original set and the rears came unglued.  Then he burnt the hex on one of the wheels so we p/u a set of slash rims and tires and when he was driving it this weekend a big chunk of one of the tires just fell off.  So we put the stockers back on ( i had glued the hex into the burnt wheel)  he drove it for a while before the glue broke loose.  So now I have 2 sets one has a bad tire and the other has a bad wheel.  And don't give me no bs about the price of rubber $20 for a set of these tires is a joke, you can get 4 wheels for $20.  My motorcycle tires were only $50 and my car tires only cost me $100 for 18'' performance tires.  basically I can get a whole stampede for $80 but a new set of wheels and tires cost $60-70.
try aluminum hex's
had hex's on my one RC strip quite often I replaced them with the aluminum ones and it didn't happen again.
Hide Signatures
       Post #: 19
RE: why are tires so expensive? - 5/15/2012 2:55 AM
yakfish
Score: 426
Status: offline
I would agree that if you make your boy pay for his own replacements he will take better care of them. I bet if he paid for them himself they would last quite a bit longer.
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 20
RE: why are tires so expensive? - 5/15/2012 7:27 AM
Cronniss
Score: 100
Last Login: 6/21/2012
Status: offline
quote:
ORIGINAL: The_Shark
quote:
ORIGINAL: jayjay283
Good idea!
I bought a set of on-road tires for my R/C (cause I knew that I would be driving it both on- & off-road) and they're now just starting to show ware on them.  (I have been driving it kinda hard when I go out with it, and usually at around sunset when it is cooler but not dark...but the road is still warm, of course.)  Is there a particular brand that you'd suggest?  Or even belt them with a piece of worn full-sized tire?
Cronniss
(Just starting to get into RC.)
Hide Signatures
       Post #: 21
RE: why are tires so expensive? - 5/15/2012 11:24 AM
phmaximus
Score: 627
Status: offline
The reson r/c tyres are so expensive is supply and demand.... The demand is very extreemly low compared to real car tyres...
Hide Signatures
(in reply to Cronniss)
       Post #: 22
RE: why are tires so expensive? - 5/15/2012 3:42 PM
Scottgir
Score: 125
Status: offline
Pick up a set of the HPI Blitz Maxxis tires. Those things LAST!!!
Hide Signatures
       Post #: 23
RE: why are tires so expensive? - 5/15/2012 3:47 PM
Foxy
Score: 2012
Status: online
Whya re they so expensive? cos we muppets continue to pay the inflated prices and other muppets keep playing the 'Tires have a lot of RnD!' card, which is frankly rubbish. They do have RnD, but no more than any other RC product.
You think you got it bad in the small scales? Tyr a gasser. These are $82, A PAIR! http://www.amainhobbies.com/product_info.php/cPath/1_26_355/products_id/37012/n/Pro-Line-Bow-Tie-Pre-Assembled-Rear-Buggy-Tires-w-Desperado-Wheel-2
So, you got a smartphone. You now have virtually unlimited access to the collective acquired knowledge of the entire human race in the palm of your hand, and you use it to... play Angry Birds while sitting on the toilet. Way to go!
Hide Signatures
(in reply to Scottgir)
       Post #: 24
RE: why are tires so expensive? - 5/15/2012 4:22 PM
SyCo_VeNoM
Score: 626
Status: offline
quote:
ORIGINAL: Foxy
one of the reasons why I do not own a 1/5th scale RC
Hide Signatures
(in reply to Foxy)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.328RCU1
