ys fz110 (not the s version)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> ys fz110 (not the s version) Page: [1]
Login
ys fz110 (not the s version) - 5/21/2012 4:44 PM
Neil Leonard
Score: 100
Last Login: 7/12/2012
Status: offline
if any one can help here is my problem.i have an fz110(remember them).i got it second hand and when i ran it in the stand the rear bearing gave way.so i rebuilt it with new bearings,o rings,gaskets,front oil seal,piston ring,diaphram the lot.i have run about 3 tanks through it.i have since run it on yamada mix and bekra 30.it idles sweet on either mix.transition seems to be ok.though there is a little bit of spitting from the carb.holds steady 4000rpm.but top end i cant seem to get any more than about 7500 rpm.have ran it wot and try to lean it but it gets to about 7400 and the starts to die likes its to lean.started with the high end about 1 3/4 out.this is with a master airscrew k series 15x8 prop.when i look at others on the forum they are getting into th 9000.have looked at the valve clearence and its good so i dont think its that.if the reg is a little rich would this affect top end?
Hide Signatures
       Post #: 1
RE: ys fz110 (not the s version) - 5/21/2012 5:34 PM
ThumbSkull
Score: 108
Last Login: 6/15/2013
Status: offline
I get 8500 on a 16x6 Xoar (about the same load as 15x8) with 30% on a just broken new one. Are you sure you got the cam on the right tooth?
Carb spitting a little fuel is normal. Needs broke in yet to get max power. If the top end RPM falls off then it's too lean.
Hide Signatures
(in reply to Neil Leonard)
       Post #: 2
RE: ys fz110 (not the s version) - 5/21/2012 7:15 PM
Neil Leonard
Score: 100
Status: offline
hi with the crankshaft dot at the bottom of the casing(lining up with the seam) i had the cam dot at 12 oclock.do you think i should go back a tooth to 11.55?i no some can exaggerate the rpm but 7400!!!!even my magnum xl120 would spin faster.and it was a dog.its a fresh gallon of 30%.i will tap the cam shaft out and re-set it see what happens.
cheers
Hide Signatures
(in reply to ThumbSkull)
       Post #: 3
RE: ys fz110 (not the s version) - 5/22/2012 6:00 PM
Neil Leonard
Score: 100
Status: offline
moved the cam gear to 11.55 with the crank at tdc.still no inprovement.rpm will still drop off at 7400 when i lean it out.i will try a bit more running in and maybe a different prop.thought it would spin the 15x8 with ease on 30%.i want to love this engine but its giving me none back!!!
Hide Signatures
       Post #: 4
RE: ys fz110 (not the s version) - 5/23/2012 12:35 AM
Jimmy Skids
Score: 100
Last Login: 6/17/2013
Status: offline
Your set up was correct the first time. dot on crank at 6 o'clock, dot on cam gear at 12 o'clock...... or pistion at TDC and the cam dot at roughly 12:05.
Skids
_____________________________
Spitfire Brotherhood #99
Outlaw Racing CD 2001 to present
Hide Signatures
       Post #: 5
RE: ys fz110 (not the s version) - 5/24/2012 3:01 PM
petec
Score: 101
Status: offline
The regulator controls overall fuel volume to the engine, try richening the regulator a bit to see if that helps. Remember to make regulator changes in 1/8th turn steps at most. You might also pul the HS needle out and flush it out in the event there is something blocking it. Just pull the needle valve out and pull the prop through to let the regulator push fuel through it.
Team YS, Team Airtronics
Pattern Junkie, Revver Brother #82, Gear Head
Hide Signatures
(in reply to Jimmy Skids)
       Post #: 6
RE: ys fz110 (not the s version) - 5/25/2012 4:36 PM
Neil Leonard
Score: 100
Status: offline
i can get about 8500 with an apc 15x6 prop.though this also seems under powered.i dont think the reg is to lean as the carb fills up with fuel if left for a while.i think i may fly with this see if it breaks in more in the air.
Hide Signatures
(in reply to petec)
       Post #: 7
RE: ys fz110 (not the s version) - 5/25/2012 5:51 PM
ThumbSkull
Score: 108
Status: offline
quote:
ORIGINAL: Neil Leonard
That's a good sign the regulator plunger is not seating properly. May still have crap in it or need an new plunger.
Hide Signatures
       Post #: 8
RE: ys fz110 (not the s version) - 5/26/2012 3:22 AM
petec
Score: 101
Status: offline
The regulator is not closing if the carb is filling with fuel. The early 1.10 had a different plunger that would stick from time to time in some engines (not all engines which made it a devil to diagnose) so a new plunger might not be a bad idea.
Hide Signatures
       Post #: 9
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> ys fz110 (not the s version)
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
