hk 450 clone    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> hk 450 clone
Page: [1]
Login
hk 450 clone - 5/21/2012 8:03 PM
Dustinxxx
Score: 100
Last Login: 5/21/2012
Status: offline
Ok, i recently got my throttle problem taken care of, settingings in transmitter setup.  So today i took it out to give it the maiden voyage, but upon spinning it up, the tail just takes off and makes the heli spin on the ground.  Do went into gyro settings (dx6i)  and looked at settings,  its sw- gyro. then 0 - 60% and 1- 40%. So just messing around i adjusted both to 40 % with no change. Does this sound like a bad gyro. Have the hk 401b. Or is there something im missing in settings?  Also noticed a lot of slop on main motor gear, but it apears that everything is tight. Any suggestions.. Thanks in advance.
Hide Signatures
       Post #: 1
RE: hk 450 clone - 5/21/2012 9:41 PM
ahamay
Score: 105
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: Dustinxxx
You need to reverse your gyro compensation direction. If your using the 401b there is a little dip switch on the gyro for reversing this.  The dx6i gyro settings are for the remote gain adjustment.
_____________________________
Tarot 500 FBL ZYX-S, Tarot 450 PRO V2 FBL ZYX , Tarot 450 PRO V2 FBL ZYX-S , MCPx V2, Nano CPx
Hide Signatures
(in reply to Dustinxxx)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
