RE: constant depth, tapered wing?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
GJC 1/6 Scale F-16 ARF PRO
Seller:  Flynstuff
Details:   $4,400.00   |  5/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> RE: constant depth, tapered wing?
Page: <<   < prev  1 [2]
Login
RE: constant depth, tapered wing? - 5/27/2012 3:26 PM
rmh
Score: 252
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: combatpigg
It will be interesting to see how well you are able to stay under the 28 oz goal with plug in wing panels.
I usually build the fin and rudder out of sticks...but choose light 1/8'' balsa sheet for the stab / elevator. I'll use 1/8'' aluminum brazing rod bent into a U shape for the elevator half joiner, and just sew it to the stab to support it in the middle. Balsa saw dust soaked with thin CA works in inlay the joiner to the elevator halves.
You have not discovered baking soda?
_____________________________
Libby is still watching you
Hide Signatures
(in reply to combatpigg)
       Post #: 26
RE: constant depth, tapered wing? - 5/28/2012 6:19 PM
BMatthews
Score: 247
Last Login: 5/14/2013
Status: offline
If you use aluminium tubing for the joiner be sure it's a "spring temper" aircraft grade. Most aluminium tubing you get is soft and easily bent with very little "spring" to it. A lighter and more sure option would be a large diameter carbon tube. At around 30 oz for AUW a thin wall carbon tube would do just fine given the large diameter that would fit between the spar caps.
The liners in the wings that the tube slips into could be made from rolled paper or similar quite easily for a light but snug slip fit.
Witty saying to be plagarized shortly.....
Hide Signatures
       Post #: 27
RE: constant depth, tapered wing? - 5/28/2012 8:38 PM
rmh
Score: 252
Status: offline
Many are 6061T6 - actually 2024 T3/4 is far better
Hide Signatures
(in reply to BMatthews)
       Post #: 28
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.125RCU1
