Replacement Muffler for Super Tigre 90    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Replacement Muffler for Super Tigre 90
Page: [1]
Login
Replacement Muffler for Super Tigre 90 - 5/26/2012 1:41 AM
jigeye
Score: 135
Last Login: 2/24/2013
Status: offline
I have been through 3 ST mufflers for this engine. They are not built well. Baffles keep falling out. I'm done with these but need choices for a replacement muffler.
Hide Signatures
       Post #: 1
RE: Replacement Muffler for Super Tigre 90 - 5/26/2012 2:00 AM
1QwkSport2.5r
Score: 155
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: jigeye
I have an Italian S90K with the stock ST "swing" muffler and haven't had any problems with it. The S90 and G90 should have the same muffler bolt spacing. The muffler I have isnt the "quiet" muffler, as it doesnt have a baffle inside. I dont know how much quieter the quiet muffler is, but my muffler never comes loose and isnt that offensive noise-wise.
A video of my 90 running, if you're interested. The camera geeks a little so the picture stinks, but the audio seems okay..
S90K running
_____________________________
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to jigeye)
       Post #: 2
RE: Replacement Muffler for Super Tigre 90 - 5/26/2012 2:01 AM
rc34074
Score: 101
Status: offline
google for Bisson, Slimline, and Jtec
Ed
"there are fighters and there are targets"
Hide Signatures
       Post #: 3
RE: Replacement Muffler for Super Tigre 90 - 5/26/2012 2:23 PM
turbo.gst
Score: 115
Last Login: 5/20/2013
Status: offline
I use a header with a mousse can type muffler. I use a tuned pipe mount to support the can. It will fix the muffler issue and give you a nice power boost.
Hide Signatures
(in reply to rc34074)
       Post #: 4
RE: Replacement Muffler for Super Tigre 90 - 5/26/2012 4:05 PM
Pylonracr
Score: 105
Status: offline
Call Dub Jett and get a Jettstream muffler.  They are by far the best, but kind of expensive.  They give a modest power boost and will last forever if you do not plow it into the runway.  Stay away from any Pitts style mufflers for performance and tuning reasons.  Macs makes nice mufflers and tuned pipe headers for a reasonable price and are of high quality as well.
Good Luck
Scott
Revver Brother #260
Hide Signatures
(in reply to turbo.gst)
       Post #: 5
RE: Replacement Muffler for Super Tigre 90 - 5/26/2012 5:22 PM
earlwb
Score: 584
Status: online
The MAC's one piece Pro or Sportsman mufflers come to mind.
http://www.macspro.com/onepiece.asp
Bisson also makes a Sport muffler that is a good candidate too. Bisson doesn't just make Pitts mufflers.
Since the muffler screw hole spacing is 47mm, any muffler with a 47 to 48mm screw spacing becomes a potential candidate. Such as the Jett 90 muffler too.  If I remember correctly, the K&B .65 Sportster engines use that same hole spacing as well.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to Pylonracr)
       Post #: 6
RE: Replacement Muffler for Super Tigre 90 - 5/27/2012 1:49 AM
rc34074
Score: 101
Status: offline
the Bisson pitts muffler for the G90 is their 2175 muffler which is listed on the bisson website for $56.00 USD.
Ed
Hide Signatures
(in reply to earlwb)
       Post #: 7
RE: Replacement Muffler for Super Tigre 90 - 5/27/2012 8:28 AM
1QwkSport2.5r
Score: 155
Status: offline
If it were me, and stock mufflers were out of the question, I'd spend the extra $40 for the Jettstream as I think they look nicer and they give an easy 1000-1500rpm boost. If DIY is your style, a Mousse Can Pipe is the other way to go for a nice boost.
I personally think Pitts mufflers are ugly and most that I've looked at have too little expansion volume causing either no gain or loss in performance. That's just me though.
Hide Signatures
       Post #: 8
RE: Replacement Muffler for Super Tigre 90 - 5/27/2012 8:47 AM
NM2K
Score: 161
Status: offline
quote:
ORIGINAL: jigeye
Are you using vibration isolation engine mounts with the mufflers mentioned above? Many engine manufacturers will not warrant engines, parts or accessories when used in conjunction with a such an engine mount.
Ed Cregger
"Practice makes prefect"
Hide Signatures
       Post #: 9
RE: Replacement Muffler for Super Tigre 90 - 5/27/2012 4:53 PM
daveopam
Score: 191
Last Login: 5/18/2013
Status: offline
Just run in without the baffle. It's common for these to get a loose baffle. If you shake the muffler to get the baffle to the front of the muffler, you can twist it with a pair of long nose plyers and pull it out.
David
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to NM2K)
       Post #: 10
RE: Replacement Muffler for Super Tigre 90 - 5/28/2012 11:50 PM
jigeye
Score: 135
Status: offline
Now that's an idea... They must be flimsy little things.
Hide Signatures
(in reply to daveopam)
       Post #: 11
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Replacement Muffler for Super Tigre 90
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
