RE: Ziroli B-25 build pics    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Ziroli B-25 build pics
Page: <<   < prev  1 2 [3]
Login
RE: Ziroli B-25 build pics - 11/15/2012 12:48 AM
gblas777
Score: 100
Last Login: 5/19/2013
Status: offline
had to enlarge the holes in the wing ribs where the wing tubes pass through to get the right dihedral. then cut some holes in the ply plates that go around the wing tube.they kind of work like a centering cam. they will be epoxied to the wing tube and ribsto hold in proper alignment..the holes that were precut put the dihedral almost an 1" off..little extra work but now is all set
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to gblas777)
       Post #: 51
RE: Ziroli B-25 build pics - 11/15/2012 4:06 AM
jumper666
Score: 105
Last Login: 4/19/2013
Status: offline
This is turning into a science project.
gb
Hide Signatures
       Post #: 52
RE: Ziroli B-25 build pics - 12/13/2012 3:13 PM
Edwin
Score: 156
Status: offline
Subscribed.
Edwin
Hide Signatures
(in reply to jumper666)
       Post #: 53
RE: Ziroli B-25 build pics - 12/13/2012 11:06 PM
gblas777
Score: 100
Status: offline
welcome aboard edwin....with the holidays and the extra time at work havent had much time to do much lately..hopefully very soon i will make some good progress
Hide Signatures
(in reply to Edwin)
       Post #: 54
RE: Ziroli B-25 build pics - 12/13/2012 11:27 PM
Edwin
Score: 156
Status: offline
This one is a future project for me. I'm putting together a H9 B-25 as a test bed and practice plane to test out subsystems, new processes, and my new DX18. This is a real handy transmitter. I was able to use servo balance to fix a flaps geometry problem and now I'm using it to sync my engines. Servo balance has 7 way points that you can fine tune to other channels. I'll be tuning each engine individually for best running, then using servo balance to match up rpms without changing the tuning. I used to use a JR matchbox. Then will come the bomb doors and separate bomb drop. Its running with a split power bus for servos and receiver.
Edwin
Hide Signatures
       Post #: 55
RE: Ziroli B-25 build pics - 12/18/2012 12:29 AM
gblas777
Score: 100
Status: offline
back to the build...this aircraft has many complex curves...here is a few wood sheeting pieces wetted and taped into place on the aft lower fuse to conform close to a final shape and will get a final cut when dry....time involved with this part of the process but worth the end results
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Edwin)
       Post #: 56
RE: Ziroli B-25 build pics - 12/18/2012 8:58 PM
OldScaleGuy
Score: 120
Status: offline
Subscribed. I built one of these shortly after the plans were released from Mr. Ziroli. Great flying plane!
_____________________________
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
       Post #: 57
RE: Ziroli B-25 build pics - 1/21/2013 5:48 PM
dalemilam58
Score: 100
Last Login: 2/1/2013
Status: offline
I just bought a set of B-25 plans from a fellow club member..I was wondering if the planes came with a parts list...I like to be old fashion and cut my own wood...so I'm needing alist of wood that is used for this build....Thank you
"if you''re going to be ''STUPID'' you need to be real fast or very tough"
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 58
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.219RCU1
