How do you get that smooth finished look    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> How do you get that smooth finished look
Page: [1]
Login
How do you get that smooth finished look - 5/29/2012 4:09 PM
harlanb
Score: 105
Last Login: 6/18/2013
Status: offline
I have built two kits so far and starting to get the hang of covering. Half science, and half magic.
I am still trying to get that smooth, finished appearance. I still keep getting the wood grain coming through the monokote.
I currently sand with 320 grit and put a coat of balsa rite on, then sand again with 320 grit again.
So far I have mixed results.
What do all of you do to get a smooth looking appearance?
Hide Signatures
       Post #: 1
RE: How do you get that smooth finished look - 5/29/2012 4:27 PM
Charlie P.
Score: 202
Last Login: 6/17/2013
Status: offline
Use dark covering colors.
_____________________________
Charlie P. (NY) "Gravity is weak but persistant".
AMA 747089/IMAA 30723
Hide Signatures
(in reply to harlanb)
       Post #: 2
RE: How do you get that smooth finished look - 5/29/2012 5:42 PM
MajorTomski
Score: 113
Status: offline
Don't iron the covering to the sheeted wood. Attach it only to the outer edges. Try to locate the Harry Higley book "There Are No Secrets" Lots of help in that one well worth every penny
Spitfire Brotherhood #6
Kadet LT 40 Brotherhood #98
Hide Signatures
(in reply to Charlie P.)
       Post #: 3
RE: How do you get that smooth finished look - 5/29/2012 10:14 PM
dbacque
Score: 137
Status: online
Don't use the Balsarite. It's great stuff but if you're covering with MonoKote you don't need it and it will give you lots of headaches like not being able to get a smooth finish. I do use Balsarite (film version) on firewalls, wing saddles and other problem areas for a little extra adhesion but if you put it on everywhere you are asking for a bad finish.
Then when you sand, use a sanding bar. If you sand with a loose piece of paper it can dig deeper where the wood is softer, accentuating the grain. Using a sanding bar will remove the high spots and level the wood no matter what the grain.
Dave
Hide Signatures
(in reply to MajorTomski)
       Post #: 4
RE: How do you get that smooth finished look - 5/29/2012 11:40 PM
flyboy9994
Score: 100
Last Login: 11/4/2012
Status: offline
I came across a post somewhere that shows the most awesome covering job I have ever seen. I'll try and find it but I remember the guy said he used a mixture of Elmers white glue and water mixed 50/50. Brush on, let dry completely and finish sand then cover.
Randy
Hide Signatures
(in reply to dbacque)
       Post #: 5
RE: How do you get that smooth finished look - 5/29/2012 11:48 PM
flyboy9994
Score: 100
Status: offline
Here's a pic of the plane that used the elmers/water method
http://www.rcgroups.com/forums/attachmentNew.php?attachmentid=3961223
Quote from the owner of this plane:
"My Kaos has been covered several times over the years, but it is currently covered in Monokote. The secret to the finish is that i "paint" the wood with elmers white glue cut 50% with water, then sand it smooth & cover over that. Comes out looking like glass everytime."
Hide Signatures
(in reply to flyboy9994)
       Post #: 6
RE: How do you get that smooth finished look - 5/30/2012 4:18 AM
kenh3497
Score: 115
Last Login: 6/11/2013
Status: offline
Waxing......... OOPS wrong forum
Sent from my Dry-Erase-Board
Hide Signatures
       Post #: 7
RE: How do you get that smooth finished look - 5/31/2012 6:52 PM
GLGofLB
Score: 100
Last Login: 5/29/2013
Status: offline
If you want no grain and also want to iron down completely use glue and water base, I have had good luck doing the method described in the Harry Higgley book "No Secrets"  Sealing the edges and shrinking with a heat gun.  However either method calls for placing finished strips around the edges.
A couple pictures of my Something Extra
Hide Signatures
(in reply to kenh3497)
       Post #: 8
RE: How do you get that smooth finished look - 5/31/2012 6:54 PM
GLGofLB
Score: 100
Status: offline
Hide Signatures
(in reply to GLGofLB)
       Post #: 9
RE: How do you get that smooth finished look - 6/1/2012 1:48 AM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
What MajorT said in spades!
Hide Signatures
       Post #: 10
RE: How do you get that smooth finished look - 6/1/2012 5:21 PM
prgonzalez
Score: 110
Status: offline
GREAT INFORMATION !!!
Spitfire Brotherhood #96, Ultra Sport Brotherhood #20
Hide Signatures
(in reply to SeamusG)
       Post #: 11
RE: How do you get that smooth finished look - 6/3/2012 2:45 AM
harlanb
Score: 105
Status: offline
Ok,
I did some experimenting, and I thought I would share my results.
I tried doing the thinned Elmers white glue method with marginal results.
I also tried several coats of krylon primer, sanding between coats. The results where about the same as the Elmers glue method.
The person at my local hobby shop steared me to some Sig Sanding sealer.
I used two coats, sanding between coats.
This made for a very smooth look when applying monakote.
It worked very well.
Hide Signatures
       Post #: 12
RE: How do you get that smooth finished look - 6/5/2012 3:34 AM
TexasAirBoss
Score: 151
Last Login: 6/16/2013
Status: offline
The finish depends completely on the prep. Sand it all smooth, then use a finer grit paper. I go all the way to 400. And I use T bars on the wings to avoid high spots and low spots.
Click to see fullsize image.
Click for fullsize
ME: "I need a good rate down to one three thousand". EXPRESS: "Roger, we''re coming down like a Bonanza full of doctors"
Hide Signatures
       Post #: 13
RE: How do you get that smooth finished look - 6/13/2012 3:20 PM
jsevey
Score: 100
Last Login: 3/5/2013
Status: offline
I use Deft brand lacquer based sanding sealer. Build up a few coats and then lightly sand with fine paper between coats until the grain is covered. It drys extremely fast and you can apply several coats and sand in a single afternoon. Sands quickly and easily and comes off very powdery. I use this method for film covering, fabric and dope, or fiberglass. Comes in cans for brushing (my favorite- builds up quicker) or in spray cans. Clean up with lacquer thinner. Hope this is helpful.
jim
Hide Signatures
(in reply to TexasAirBoss)
       Post #: 14
RE: How do you get that smooth finished look - 6/13/2012 9:52 PM
AllTheGoodNamesAreTaken
Score: 118
Status: offline
quote:
ORIGINAL: jsevey
jim
+1 on the Deft sanding sealer!
Don''t just stand there, go get some glue!
Hide Signatures
(in reply to jsevey)
       Post #: 15
RE: How do you get that smooth finished look - 6/14/2012 4:25 AM
rcmigpilot
Score: 103
Last Login: 12/17/2012
Status: offline
quote:
ORIGINAL: jsevey
jim
Have you used this method on balsa covered foam wings? I would be scared the lacquer would find a crack in the sheeting and melt the core.
The two most useless things on Earth are altitude above you, and runway behind you.
Hide Signatures
       Post #: 16
RE: How do you get that smooth finished look - 6/15/2012 5:26 AM
harlanb
Score: 105
Status: offline
That sounds like the way to do it.
Where do you get the Deft brand lacquer based sanding sealer?
I did not see this at my LHS. Can you get this at a hardware store?
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
