Props    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> Props Page: [1]
Login
Props - 5/30/2012 3:36 PM
wholehog
Score: 100
Last Login: 5/15/2013
Status: offline
Is it necessary to polish a prop? I here it doesn't matter,and it does. Polish the side facing the front of the boat with a satin finish on the other side. Then I herd to satin the whole prop. Does any of this matter? Thanks
Hide Signatures
       Post #: 1
RE: Props - 5/30/2012 6:11 PM
advanced builder
Score: 105
Last Login: 5/17/2013
Status: offline
only if you heat race. otherwise forget-about it.
_____________________________
Stoney Pond Model Boat Club, Canandaigua, NY
International racer
Hide Signatures
(in reply to wholehog)
       Post #: 2
RE: Props - 5/30/2012 7:05 PM
wholehog
Score: 100
Status: offline
I plan on racing. So what is best now. Thanks
Hide Signatures
(in reply to advanced builder)
       Post #: 3
RE: Props - 5/31/2012 1:08 AM
coyv10
Score: 102
Last Login: 3/24/2013
Status: offline
I have tried it both ways and have not seen a difference ( I like mine polished)
Hide Signatures
       Post #: 4
RE: Props - 5/31/2012 1:24 AM
advanced builder
Score: 105
Status: offline
quote:
ORIGINAL: wholehog
If you feel it will give you a edge, then Yes polish
International racer
Hide Signatures
       Post #: 5
RE: Props - 5/31/2012 4:40 AM
Tundrahog
Score: 100
Last Login: 3/18/2013
Status: offline
A polished prop is a fast prop. I balance/polish/sharpen my own props. I have a couple done by the pro's. Don't see a difference. I do not do cupping/cutting. That I let the pro's do.
I have a gasser 55" cat and a small 16" electric hydro. Just added a .12 Zippkits rigger to the fleet. Hope to have the nitro in the water in a couple of weeks.
John
Hide Signatures
       Post #: 6
RE: Props - 5/31/2012 2:23 PM
amax
Score: 107
Last Login: 5/14/2013
Status: offline
A Polished Prop will Slip through the water easier where a Sanded prop when done Right will Grab the water a push it the direction you want.
If your running a large aggressive prop and need it to Slip a little to let the engine get up in the RPM's You Polish It. BUT a Polished Prop will also Break Loose Easier in the turns or under Heavy Acceleration loads.
If you run a Smaller Prop that the engine has No Problem Turning Up you Sand the Blade surface to make it Grab the water and GO. A sanded prop will Launch Easier, Pull Turns Stronger, Hole Shot out of the turns Quicker, and Recover from a Spin Out\Stall Easier.
You just have to Experiment a little and figure out what works best for You and Your Driving Style and Boat set up.
Top Speed Hobbies llc. Gotta Need For Speed..
www.youtube.com/user/topspeedhobbies
Hide Signatures
(in reply to Tundrahog)
       Post #: 7
advanced builder
Score: 105
Status: offline
Joe over at Zippkits.com has a good selection of props. And a good price. I been running his Billet .21 prop on my .21 JAE rigger. MY .12 JAE i run his 438 -440 props
International racer
Hide Signatures
       Post #: 8
RE: Props - 5/31/2012 3:26 PM
wholehog
Score: 100
Status: offline
Thanks everyone!
Hide Signatures
       Post #: 9
RE: Props - 5/31/2012 4:22 PM
wholehog
Score: 100
Status: offline
For Top Speed: I have a 1/12 hydro. I am using a 1.34 x 2.06 s/s prop. It is sharpened and balanced. Is this a good prop for this boat or do you recommend something else? Thanks
Hide Signatures
       Post #: 10
RE: Props - 5/31/2012 5:18 PM
amax
Score: 107
Status: offline
If your running basically Stock engine & Set Up, The Octura Y535 (2 blade prop) for Top Speed, the Octura M435\3 (3 Blade) for Pulling Quick Turns and Hole Shots(Heat Racing). Stainless Steel is a bit Heavy for these small engines and the 1\8" Prop shaft, the Beryllium\Copper(Octura) is lighter and easier to work with when you S&B the prop.
Hide Signatures
       Post #: 11
RE: Props - 5/31/2012 5:37 PM
advanced builder
Score: 105
Status: offline
quote:
ORIGINAL: amax
If your running basically Stock engine & Set Up, The Octura Y535 (2 blade prop) for Top Speed, the Octura M435\3 (3 Blade) for Pulling Quick Turns and Hole Shots(Heat Racing). Stainless Steel is a bit Heavy for these small engines and the 1\8'' Prop shaft, the Beryllium\Copper(Octura) is lighter and easier to work with when you S&B the prop.
When I got a billet prop or a AB it's always a little rough from machining. Same with Props4U -I did get his modded prop for the .12 and I was very happy. but delicate I tore that prop up a few years ago. You can't do what they do with a Dremal.
International racer
Hide Signatures
(in reply to amax)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
