My attempts...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> My attempts... Page: [1] 2 3 4 5 6   next >   >>
Login
My attempts... - 5/31/2012 12:09 PM
windcosmic
Score: 100
Last Login: 5/11/2013
Status: offline
Here my simple plans...
Click to see fullsize image.
Click for fullsize
< Message edited by windcosmic -- 6/9/2012 4:24 PM >
Hide Signatures
       Post #: 1
RE: My attempts... - 5/31/2012 12:12 PM
windcosmic
Score: 100
Status: offline
Currently I am working on the Tsunami.
Click for fullsize
Hide Signatures
(in reply to windcosmic)
       Post #: 2
RE: My attempts... - 5/31/2012 12:16 PM
windcosmic
Score: 100
Status: offline
Free space.
< Message edited by windcosmic -- 6/21/2012 9:49 AM >
Hide Signatures
       Post #: 3
RE: My attempts... - 5/31/2012 12:20 PM
windcosmic
Score: 100
Status: offline
This is a a copy of a german model plane, the only difference is the wing position..
Click for fullsize
Hide Signatures
       Post #: 4
RE: My attempts... - 5/31/2012 12:25 PM
windcosmic
Score: 100
Status: offline
Free space.
< Message edited by windcosmic -- 6/21/2012 9:51 AM >
Hide Signatures
       Post #: 5
RE: My attempts... - 5/31/2012 12:27 PM
windcosmic
Score: 100
Status: offline
Free space.
< Message edited by windcosmic -- 6/21/2012 9:48 AM >
Hide Signatures
       Post #: 6
RE: My attempts... - 5/31/2012 5:41 PM
windcosmic
Score: 100
Status: offline
Il mio lo faro' cosi'... :
Click for fullsize
Hide Signatures
       Post #: 7
RE: My attempts... - 6/1/2012 10:55 AM
Headhunter70
Score: 100
Last Login: 5/25/2013
Status: offline
very nice ! reminds me a little of the ME209
Click for fullsize
Hide Signatures
       Post #: 8
RE: My attempts... - 6/1/2012 12:26 PM
windcosmic
Score: 100
Status: offline
Free space.
< Message edited by windcosmic -- 6/21/2012 9:50 AM >
Hide Signatures
(in reply to Headhunter70)
       Post #: 9
RE: My attempts... - 6/1/2012 12:35 PM
windcosmic
Score: 100
Status: offline
< Message edited by windcosmic -- 6/4/2012 6:01 AM >
Hide Signatures
       Post #: 10
RE: My attempts... - 6/1/2012 4:52 PM
windcosmic
Score: 100
Status: offline
< Message edited by windcosmic -- 6/4/2012 6:02 AM >
Hide Signatures
       Post #: 11
RE: My attempts... - 6/1/2012 4:54 PM
windcosmic
Score: 100
Status: offline
Niente.. il disegno dello stesso modello con le ali ellittiche lo 'posto' domani...
Hide Signatures
       Post #: 12
RE: My attempts... - 6/2/2012 11:38 AM
windcosmic
Score: 100
Status: offline
Free space.
< Message edited by windcosmic -- 6/21/2012 9:52 AM >
Hide Signatures
       Post #: 13
RE: My attempts... - 6/2/2012 5:56 PM
windcosmic
Score: 100
Status: offline
Su outerzone.co.uk vedo che hanno inserito questo: http://www.outerzone.co.uk/plan_details.asp?ID=2990
una buona base sulla quale poi eventualmente lavorare..
Hide Signatures
       Post #: 14
RE: My attempts... - 6/2/2012 6:29 PM
windcosmic
Score: 100
Status: offline
Un buon carter da 'OPSizzare' : http://www.ebay.com/itm/Super-Tigre-X40-RV-Crank-Case-Used-Performance-Speciality-/261033384599?pt=LH_DefaultDomain_0&hash=item3cc6cd5a97
bisogna: fresare la sede del cilindro, altrimenti la camicia OPS non entra. Usare bielle OPS di quelle grosse con la fresatura in mezzo..
il tappo carter col disco Super Tigre (dopo al limite si fanno con la bachelite) e l'albero Tigre . Usare inserti sottotesta OPS da fresare sotto accuratamente e chiaramente guarnizioni OPS.. e dopodichè provare..
- rettifica: se il carter è usato, probabilmente non occorre fresarlo. Il motore che ho 'OPSizzato' ieri mi aveva fatto dannare, perchè aveva la sede del cilndro stretta e non so come sono riuscito a fresarla con una moletta di quelle viola stile Brico Center.
( a momenti me se verseva il carter, ma go avesto culo)...
< Message edited by windcosmic -- 6/2/2012 6:51 PM >
Hide Signatures
       Post #: 15
RE: My attempts... - 6/3/2012 5:42 AM
windcosmic
Score: 100
Status: offline
Versione del modello 'Attacker' con ala a pianta ellittica. Il problema comune a quasi tutte le mie 'proposte', a parte lo 'Tsunami (spero) è la non conformita' al regolamento F.A.I. per quel che concerne la fusoliera...
- Si, infatti.. non sono ammesse parti della fusoliera costituite da pinne ... comunque la soluzione resta semplice: la falsa presa d'aria inferiore la monto 'posticcia' sulla parte inferiore della fusoliera con un paio di ordinate a pianta trapezia e la parte anteriore costituita da un blocchetto di balsa sagomato.
- Poi, per Mustanghizzare il tutto (cosi' il modello sarebbe conforme anche a quella parte del regolamento che prevede che il modello debba essere una semiriproduzione di un vero aereo da corsa al pilone),basterebbe modificare la sagoma del timone di direzione e cambiare radicalmente la pianta dell'ala. (1,30 o poco piu' di apertura dovrebbe andare bene).
Click for fullsize
< Message edited by windcosmic -- 6/21/2012 9:53 AM >
Hide Signatures
       Post #: 16
RE: My attempts... - 6/3/2012 5:05 PM
windcosmic
Score: 100
Status: offline
Free space.
< Message edited by windcosmic -- 6/21/2012 9:54 AM >
Hide Signatures
       Post #: 17
RE: My attempts... - 6/4/2012 7:45 AM
windcosmic
Score: 100
Status: offline
Free space.
(delirio).
Click for fullsize
Click for fullsize
< Message edited by windcosmic -- 6/21/2012 9:55 AM >
Hide Signatures
       Post #: 18
RE: My attempts... - 6/5/2012 1:08 PM
windcosmic
Score: 100
Status: offline
Hide Signatures
       Post #: 19
RE: My attempts... - 6/5/2012 1:10 PM
windcosmic
Score: 100
Status: offline
Hide Signatures
       Post #: 20
RE: My attempts... - 6/5/2012 1:18 PM
windcosmic
Score: 100
Status: offline
Dunque.. il jett .50 ce l'ho... mi 'posto' i consigli per l'uso.. : http://www.rcuniverse.com/forum/m_2613869/anchors_2650548/mpage_1/key_/anchor/tm.htm#2650548
Hide Signatures
       Post #: 21
RE: My attempts... - 6/5/2012 1:19 PM
windcosmic
Score: 100
Status: offline
Hide Signatures
       Post #: 22
RE: My attempts... - 6/5/2012 6:12 PM
windcosmic
Score: 100
Status: offline
O
< Message edited by windcosmic -- 6/21/2012 9:56 AM >
Hide Signatures
       Post #: 23
RE: My attempts... - 6/6/2012 6:42 AM
windcosmic
Score: 100
Status: offline
Vedo di farmi capire: sto cercando di esporre le idee.. non di illustrare un disegno completo. Della serie: 'unisci i puntini' oppure 'coloralo tu'..
(anche perchè mi ci vorrebbe troppo tempo e son abbastanza incasinato).
Hide Signatures
       Post #: 24
RE: My attempts... - 6/6/2012 10:25 AM
windcosmic
Score: 100
Status: offline
Dunque.. il problema del motore che non ci sta potrebbe anche esser risolto lasciando pure che le logherine od il castello motore sporgano ai lati del muso (cosi' da farnire anche ulteriore 'materia' sulla quale far aggrappare resina epossidica) , poi, ricoprire il tutto con due blocchetti di balsa da sagomare bene in modo da simulare le sporgenze della naca motore del'aereo full - size.
- Con un'ogiva piu' grande, tipo da 50mm, il problema è ancora piu' semplice...
- Non fate riferimento alle misure, si riferiscono ad aun altro modello..
- 07/06/2012 : Errata corrige. La parte in alto va rimossa. In pratica, la forma dell'ordinata parafiamma assomiglia ad il buco di una serratura.
Click for fullsize
< Message edited by windcosmic -- 6/7/2012 5:31 AM >
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
