RE: My attempts...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: My attempts...
Page: <<   < prev  1 2 3 [4] 5 6   next >   >>
Login
RE: My attempts... - 6/19/2012 11:40 AM
windcosmic
Last Login: 5/11/2013
Status: offline
Free space.
< Message edited by windcosmic -- 6/21/2012 10:05 AM >
Hide Signatures
(in reply to windcosmic)
       Post #: 76
RE: My attempts... - 6/19/2012 11:43 AM
windcosmic
Status: offline
comunque si, mi riconosco nello spilungone di 'The commitments'.
Hide Signatures
       Post #: 77
RE: My attempts... - 6/19/2012 12:02 PM
Captain Terrific
Last Login: 5/18/2013
Status: offline
Must be cool to have your own thread and be the only poster in it!
Cheers,
Dave
Hide Signatures
       Post #: 78
RE: My attempts... - 6/19/2012 12:26 PM
H5606
Last Login: 5/17/2013
Status: offline
"Model Airplane" is an international language! I was able to access RCU in Poland. I can't speak or write Italian but it looks like you're speaking perfect "Model Airplane" to me so please keep going; I like it! Someone else recently turned me on to the Outerzone free plans site that you referenced in some of your posts in which I have similar interests...
< Message edited by H5606 -- 6/19/2012 12:57 PM >
Hide Signatures
       Post #: 79
RE: My attempts... - 6/19/2012 12:37 PM
windcosmic
Status: offline
(censurato).
< Message edited by windcosmic -- 6/19/2012 4:59 PM >
Hide Signatures
(in reply to H5606)
       Post #: 80
RE: My attempts... - 6/19/2012 5:00 PM
windcosmic
Status: offline
Yes, dependin on the time I will have and money.
I think No -name and the drawing on page 2 should be a good start for those who are interested to approach the R/C pylon racing world. The ample wing surface coupled to proven airfoils should guarantee successful flies without troubles.
The Tsunami Pegna would be a bit critical (so i like it). More suited to straight fast passes attempts than fly around the pylons.
P.s. : to go fast with a Nelson Q.40 engine, the very first 'Tsunami' drawing should be nice. But You have to use a M.H. semisymmetrical airfoil mounted at 0° (not the airfoil i indicated on the plan... more suited for a fast aerobatic plane..)
It costruction is really fast and simple.
Errata corrige: There was a mistake on the No-Name drawing. The 'main' frame is correct, you have to redraw the other two, anyway I think it could work fine the same (more space for the engine).
(concludendo la chiacchierata, distintamente saluta),
Giovanni Pavan
< Message edited by windcosmic -- 6/20/2012 6:57 AM >
Hide Signatures
(in reply to H5606)
       Post #: 81
RE: My attempts... - 6/19/2012 7:13 PM
H5606
Status: offline
windcosmic,
Are you designing the Tsunami/Pegna to comply with rules of some racing class like QM-40 or Formula I or is it just for fun and to go fast?
Hide Signatures
       Post #: 82
RE: My attempts... - 6/20/2012 6:58 AM
windcosmic
Status: offline
- Qualcuno ha rimosso il mio post : 'no, i just drew it to have fun with my HP 28s. '
- e ho mentito: L'HP28s ha da un anno le batterie scariche... no direi che quel disegno è un altro 'disegno delirio'.
The best of all is the one I drew with the pencil (drawings are on page 2). It is very well suited to fly with the old F1 engines (the 'image base' is pretty the same).
I am not interested to 'compete' in any racing circuit..
The one with elliptical wings should be very good looking. + or - the old Flair 'Shark'. Nice with a Quickee 500 engine.
Hide Signatures
(in reply to H5606)
       Post #: 83
RE: My attempts... - 6/20/2012 7:35 AM
windcosmic
Status: offline
Free space.
Hide Signatures
       Post #: 84
RE: My attempts... - 6/20/2012 8:16 AM
windcosmic
Status: offline
Ho deciso qualcosa!! (i decided something!!). I will build the plane with elliptcal wings.
(ma non lo so.. dipende da come se mette le robe..)..
Hide Signatures
       Post #: 85
RE: My attempts... - 6/20/2012 8:58 AM
windcosmic
Status: offline
Air Combat wing built months ago with the aid of Giuseppe Panzieri's article. I still have to sand it well.
I cut a bigger wing with his method and it worked.
I permit myself to 'post' a very interesting link to the Webpage of Mr. Panzieri with some nice 'how to's' : http://www.46squadron.it/Consiglio%2046.htm
Click to see fullsize image.
Click for fullsize
< Message edited by windcosmic -- 6/20/2012 12:11 PM >
Hide Signatures
       Post #: 86
RE: My attempts... - 6/20/2012 12:07 PM
windcosmic
Status: offline
Free space.
< Message edited by windcosmic -- 6/20/2012 12:37 PM >
Hide Signatures
       Post #: 87
RE: My attempts... - 6/20/2012 12:16 PM
windcosmic
Status: offline
< Message edited by windcosmic -- 6/20/2012 12:38 PM >
Hide Signatures
       Post #: 88
RE: My attempts... - 6/20/2012 5:19 PM
windcosmic
Status: offline
simplify it by yourself: http://outerzone.co.uk/plan_details.asp?ID=1861
solution: you can make the wingtips squared instead of rounded.
the tail surfaces could be built with conventional wingribs instead of the more complex geodetic structure.
< Message edited by windcosmic -- 6/20/2012 5:42 PM >
Hide Signatures
       Post #: 89
RE: My attempts... - 6/20/2012 5:27 PM
windcosmic
Status: offline
Turn this control line stunter into a .40 R/C pylon racing plane: http://outerzone.co.uk/plan_details.asp?ID=211
solution: you have to make strongest the tail surfaces (you can make them out from 5mm balsa sheets).
You have to change the airfoil and to move the trailing edge at the begin of the flapped area. better, in the hinge's centre position.
The wing area is too large. Once you'll have removed the flaps, you will have obtained the right root chord.
< Message edited by windcosmic -- 6/20/2012 6:03 PM >
Hide Signatures
       Post #: 90
RE: My attempts... - 6/20/2012 6:19 PM
windcosmic
Status: offline
The biggest of five: http://outerzone.co.uk/plan_details.asp?ID=3066
Hide Signatures
       Post #: 91
RE: My attempts... - 6/20/2012 6:22 PM
windcosmic
Status: offline
Pylonize it by yourself!! : http://outerzone.co.uk/plan_details.asp?ID=3065
Hide Signatures
       Post #: 92
RE: My attempts... - 6/20/2012 6:24 PM
windcosmic
Status: offline
For the old fart guys: why don't you make a similar website for old electronics' schemes?
Hide Signatures
       Post #: 93
RE: My attempts... - 6/21/2012 1:50 PM
windcosmic
Status: offline
I will protect you.. (si ma chi che tutte le me scappa via?) and nothing can hurt you.... http://www.outerzone.co.uk/plan_details.asp?ID=3072
Hide Signatures
       Post #: 94
RE: My attempts... - 6/21/2012 1:54 PM
windcosmic
Status: offline
FREE SPACE.
< Message edited by windcosmic -- 6/22/2012 6:47 AM >
Hide Signatures
       Post #: 95
RE: My attempts... - 6/21/2012 1:58 PM
windcosmic
Status: offline
FREE SPACE.
< Message edited by windcosmic -- 6/22/2012 6:48 AM >
Hide Signatures
       Post #: 96
RE: My attempts... - 6/21/2012 3:06 PM
rgburrill
Status: offline
quote:
ORIGINAL: Captain Terrific
Cheers,
Dave
Yea, and to have moset the pages "free space" or just plain empty.
Hide Signatures
(in reply to Captain Terrific)
       Post #: 97
RE: My attempts... - 6/21/2012 6:31 PM
windcosmic
Status: offline
FREE SPACE.
Hide Signatures
(in reply to rgburrill)
       Post #: 98
RE: My attempts... - 6/22/2012 5:32 PM
windcosmic
Status: offline
free space
< Message edited by windcosmic -- 6/23/2012 5:37 AM >
Hide Signatures
       Post #: 99
RE: My attempts... - 6/22/2012 5:42 PM
windcosmic
Status: offline
Free space.
< Message edited by windcosmic -- 6/22/2012 7:29 PM >
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
