New Turbine Engine Company-Xtreme Turbines!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> New Turbine Engine Company-Xtreme Turbines!!!
Page: [1] 2 3 4 5   next >   >>
Login
New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 6:26 PM
XtremeTurbines
Score: 100
Last Login: 5/20/2013
Status: offline
Xtreme Turbines is the newest edition of micro turbine engines for the R/C world.
Bringing you the highest quality of turbine engines. We strive for perfection.
Our turbines are tested with the highest degree of balance and precision.
We have a very nice and powerful 24lb thrust turbine engine with both options of Propane start or Kero Start. Please check out our website or give us a call to place your order today!
We are offering a nice introductory price.
SO CALL TODAY!!!
www.xtremeturbines.com
WE ARE HERE TO HELP!
We repair all RAM, Modellbau, FTE and T- Turbine Engines.
Top quality parts for your turbine engine.
We also provide balancing for turbine wheels and compressors.
Our top notch equipment is of the highest standard in today's model turbine industry.
  • Engine clean up
  • Diagnostics
  • Bearing Servicing
  • Precision Balancing
  • Crash Repair
  • Complete Tune ups
  • Upgrade your RAM, Modellbau, FTE or T-Turbine to new Technology. (Fadec ECU, KERO Start, etc)
We are here to help with any and all repairs that you might require!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:05 PM
david robinson
Score: 100
Last Login: 3/31/2013
Status: offline
 Not sure why you would call your turbine new. It looks like a old RAM with a Xicoy ECU and a jet cat kero plug. That engine use huge and heavy for the thrust. Compared to the new Jet Cat P100 and the Jet Central Rabbit 100 with the same thrust they are half the weight and size with all internal kero start etc...  Seems like you have purchased old stock from Carlos or somebody and trying to pawn it off on us. Be honest and buisness would go a lot better for you.
Hide Signatures
(in reply to XtremeTurbines)
       Post #: 2
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:12 PM
siddus74
Score: 100
Last Login: 5/18/2013
Status: offline
Those valves look like they are from the ark.
Scott.
_____________________________
siddus74
Hide Signatures
(in reply to david robinson)
       Post #: 3
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:13 PM
747junky
Score: 110
Status: offline
 +1
I totally agree, code red I think we have an imposter amongst us. Lol
King Tech K140F  $2450 and has 34lb thrust and still is smaller than that relic you are trying to sell
Specifications:
Diameter: 113mm ( 4-1/2" ) XJ0
Length: 270mm ( 10-1/2” ) - including starter
Weight: 1650 g ( 3lb. 10oz. )
RPM Range: 33,000 - 123,000 RPM
Thrust: 14 kg - 15° C ( 31 lbs @ 59° F. )
Exhaust gas temp.: 700°C ( 1292° F )
Fuel consumption: 400g / min—average ( 14.1 oz / min )
Fuel: Diesel, Jet A1, Kerosene
Lubrication: 5%, 3 to 5% for Diesel
Maintenance cycle: 25 hours
Hide Signatures
       Post #: 4
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:14 PM
FenderBean
Score: 119
Last Login: 5/22/2013
Status: offline
Man tough crowd around here
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to siddus74)
       Post #: 5
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:18 PM
3dean
Score: 101
Last Login: 5/23/2013
Status: offline
come on xtreme turbines , lets see you get out of
that one
Hide Signatures
(in reply to FenderBean)
       Post #: 6
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:19 PM
XtremeTurbines
Score: 100
Status: offline
Ok guys. The turbine is new. The parts are all manufactured in the US. These were not purchaed from Carlos. He has his own engine. No one is trying to pawn off anything on you. We are not forcing you to buy one. Keeo your comments to yourself if you do not have anything nice to say. If you like Kingtech turbines then please go ahead and buy it. No one is forcing you to anytihng. All the parts are new and not old. Again please keep any bad comments to yourself as this engine is not even in the same rehlm as a RAM turbine.
Thank You
Hide Signatures
       Post #: 7
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:20 PM
Newskin78
Score: 100
Last Login: 4/3/2013
Status: offline
 Tough crowd !!! Absolutly not it's about being realistic that this is a fossil and he is trying to charge $2300 go that thing. Maybe if he had them for sale at $900 like everybody else sells ther RAM and Modellbau 750 for then it would be a steel. The Xicoy ECU cost $200 bucks and kero plug $120 how is this justified with a $2K price tag come man.
I have a New JPX for sale converted to kero and auto start for 3k lol
Hide Signatures
       Post #: 8
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:24 PM
XtremeTurbines
Score: 100
Status: offline
Hey 747 the king tech is only 31lbs of thrust at 123k rpm not 34lbs. My engine runs at 120k and do have engines that are running at 26.5lbs of thrust. Also if you check you will see that the kingtech used 14 ounces per minute and my turbine is only 9! If you are so concerned I can put the engine at 123k and you will get the same 31lbs but that is over kill in my eyes. Again if you guys have nothing nice to say keep it to yourselves.
Thank You
< Message edited by XtremeTurbines -- 6/1/2012 7:47 PM >
Hide Signatures
(in reply to 747junky)
       Post #: 9
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:26 PM
david robinson
Score: 100
Status: offline
 Just because you put together a 750 with new parts and call extreme turbine does not mean its new. The engine is a 750 look at it at least have the originality to anodize the engine in a different color than the old Modellbau /FTE 750. If I build a 1930 beetle with new parts and engine it still is a 1930 beetle just brand new.
Hide Signatures
       Post #: 10
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:28 PM
XtremeTurbines
Score: 100
Status: offline
Ok you guys really have nothing better to do. 10 years ago you guys did the same thing to other turbine manufs that brought out a new turbine when you swore by RAM. Now that RAM is out of the picture for years you only talk about jetcat and jetcentral etc. Believe me these are new turbines. They have new internal and external plus electronics. That makes it a new turbine in case you did not know that. Plus you need to get a check on your numbers. If you can get a kero plug for 120 I will buy 100000 of them. The price for a kero plug from jetcat is $190 and the ECU from Fadec is over $200. SO again if you have no life and nothing better then to try and bash a compnay keep your comments to yourself and watch at your next event an Xtreme Turbine flying jet pass your jet right by!
Hide Signatures
(in reply to Newskin78)
       Post #: 11
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:29 PM
XtremeTurbines
Score: 100
Status: offline
David lets see. The internals are all new. The can is new. The tale cone is new. All electronics are new. I am not sure what you are trying to get at by posting this. But please keep any negative posts to yourself.
Hide Signatures
       Post #: 12
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:34 PM
3dean
Score: 101
Status: offline
your engine produces 24lbs and weighs 3.5lbs
my jetcat p160 weighs 2.9 lbs and produces 3.6lbs
Hide Signatures
       Post #: 13
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:37 PM
bidrseed2
Score: 100
Status: offline
It's usually nice to see to hear about a new manufacturer enter the market.
However I'm struggling to see what's special about your product.
Is the 3.5lb weight engine only or engine and ancillaries?
Also, in my humble opinion, telling the "market" and I mean posters above, and I paraphrase, negative feedback is not welcome, is not a sign of a company I wish to deal with.
Sorry.
Hide Signatures
       Post #: 14
XtremeTurbines
Score: 100
Status: offline
I am not trying to compare my engine to any other company. The engine is a great working engine and works flawlessly.
For the last time if you have nothing nice to say please just keep it to yourselves.
Thank You
Hide Signatures
(in reply to 3dean)
       Post #: 15
siddus74
Score: 100
Status: offline
I wasnt bashing... just commenting that other manufactures are using the nice small new style valves ... when have you choosen to the old larger valves. I dont pretend to know allot about the evolution of micro turbines but the fact that my older wrens and jetcats came with the those larger brass valves and my newer Supersport and Jetcats are supplied with the smaller ones does say to me as it must do to others that maybe you are using older generation parts.
Why are you using the older larger heavier valves when ther other manufactures are going for smaller lighter equivalents?
Scott.
siddus74
Hide Signatures
       Post #: 16
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:40 PM
XtremeTurbines
Score: 100
Status: offline
No one has seen these turbines yet. No one has flown or touched one.  You cannot post negative comments about a product that you have never seen, used or touched. Its not ethical or nice. You are entitled to your opinion after you have used a product not before.
Hide Signatures
       Post #: 17
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:45 PM
XtremeTurbines
Score: 100
Status: offline
Siddus,
When you are a new company and you try to keep the overal price down then you get what you can get. These are not that big. Yes they are the same ones that you and everyone else has in there jets and the size never has caused a problem, Even in the smaller jets. Our jets are getting bigger with a lot more room. The solenoids will not pocess any kind of problem.
Hide Signatures
       Post #: 18
3dean
Score: 101
Status: offline
that wasnt the answer to his question??
Hide Signatures
       Post #: 19
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:48 PM
siddus74
Score: 100
Status: offline
So why are you using to the older style heavier valves? Your closed attitude will not win many customers .... where as you may not be trying to compare your product to other brands surley to break into the market you need to? Anyone wishng to buy a new turbine will be comparing your product to other manufactures ....
Scott.
siddus74
Hide Signatures
       Post #: 20
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:49 PM
Newskin78
Score: 100
Status: offline
You are absolutly right the engine is different look at picture below.  it is clearly shown that the data terminal is different I stand corrected.  It is very obvious that you purchased old stock from somewhere in the RAM, FTE or Modellbau world and you want to make a new engine come to life but that is very hard to do when engines of the same size and weight cost pretty much the same and produce 10-12 more lb of thrust.  And you are wrong my friend there are several people that have Modellbau T750 ( which your engine is ) with Xicoy ECU's here in Colombia and in Argentina. They work great and is a good alternative to throwing it away since they are out of date
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 21
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:52 PM
AndyAndrews
Score: 151
Status: online
Is your weight total weight with all valves or just the turbine? Would you mind providing the diameter and length of your turbine? What kind of fuel pump are you using? I didn't see a picture of it in your package.
Andy
Hide Signatures
       Post #: 22
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:54 PM
XtremeTurbines
Score: 100
Status: offline
They are cheaper. I did answer the question. I am not closed minded at all. You guys all came on here and deciding to bash a new turbine company when you have never seen or used. I am just not into bashing companies as you guys wish to do. The engine is completey different. Sure I used the same packing material that they used as it was from a company in south florida. But all in all you guys should see one and try it out before you can post positive or negative comments.
Hide Signatures
       Post #: 23
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:55 PM
rcjetsaok
Score: 135
Status: offline
Sounds like a plan !!
Danno
< Message edited by rcjetsaok -- 6/4/2012 4:24 AM >
The Hobby Express - Jet Central Tejas
Hide Signatures
(in reply to 3dean)
       Post #: 24
RE: New Turbine Engine Company-Xtreme Turbines!!! - 6/1/2012 7:58 PM
XtremeTurbines
Score: 100
Status: offline
Hello Andy,
The weight is for the turbine with starter. The fuel pump is flightworks.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
