Replacement motor for Pz T-28    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Aircraft Graphic Packages - RTF
Seller:  Mike06659
Details:   $4.99   |  5/7/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> Replacement motor for Pz T-28
Page: [1]
Login
Replacement motor for Pz T-28 - 6/1/2012 7:18 PM
flyrisley@msn.com
Last Login: 3/27/2013
Status: offline
Bent the shaft of the stock motor and would like a "drop-in" replacement...possibly with more power. What suggestion do you gurus suggest?
Hide Signatures
       Post #: 1
RE: Replacement motor for Pz T-28 - 6/2/2012 7:49 PM
Dr Kiwi
Last Login: 5/13/2013
Status: offline
http://thesmithfam.org/blog/2008/11/22/parkzone-t-28-trojan-motor-upgrade/
_____________________________
Dr Phil Millener, Chattanooga, TN
Hide Signatures
(in reply to flyrisley@msn.com)
       Post #: 2
RE: Replacement motor for Pz T-28 - 6/5/2012 3:38 AM
lbarnes
Last Login: 2/19/2013
Status: offline
About 3 yeas ago I went with the 3542 1000Kvr. Lots of power but as stated in earlier post the motor mount will need to be modified.
Here is my testing on this motor:
11.1V 30C - 10x7 APCE - 46oz thrust - 268w - 26A.
This will make your T-28 go vertical. the stock motor is only 168w with the 9.5x7.5 prop.
After about 4 flights the motor mount gave out and I purchased a CNC aluminum motor mount on Ebay for $19.00.
The vibrations went away and I have also since then converted another T-28 with the same motor but 1100Kvr.
The testing results: 3542/1100Kvr
11.1v 30c - 10x7 APCE - 59oz thrust - 412w - 36A.
With the additional 7oz thrust it flys great.
I do really suggest the CNC aluminum mount.
Also, check you ESC some of the older ESC were 30A newer were 25A. I wold suggest a 40A esc with any of the above motors.
The motor is about 2mm longer than the stock so cutting our the cowl to clear the front of the motor will be necessary. This is not a issue and doesnt take away from the apperance of the plane.
larry
Never stop flying the airplane until the rudder meets the cockpit
Hide Signatures
(in reply to Dr Kiwi)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.219RCU1
