Kristoffer_E
Score: 100 Joined: 3/28/2011 Last Login: 3/19/2013 From: Sandy,
UT, USA Status: offline
Well, I ran a 2 tanks with only a rear diff, and the ring and pinion are intact, as are the spider gears. So I thimk we are good in that respect. However, the front clutch bearing failed, and needs to be replaced. By failed, I mean it was behaving like a bushing and not actually spinning at all . After 2.5 gallons of runtime and never cleaning the craptastic metal-shielded bearings, it seems many of them are also due for replacement. AvidRC has fancy half-rubber half-metal shielded bearings for $1, so I think I am going to replace every bearing in the truck (diffs, outdrives, tranny, engine, clutch), and I have most of them picked out. However, I've tried to clean the engine multiple times, and I've never managed to remove the crankshaft. There is a metal collet that sits behind the flywheel that does not seem to like me, and refuses to come off. It looks like there is a brass bushing in there that is locking it into place, but I can't tell. If someone could tell me how to remove the mini-flywheel (for lack of a better term) or even what size the front and rear SH .18 bearings are, I'd be most appricitive. Also, when I discovered the abysmal state of the bearings, I figured other stuff needed changed too. I've drained all the shock oil and cleaned all the diffs out, and now I need new stuff to put in there. Does anyone have a recommendation for a good range of shock oil wieghts? I would like to get a few and make my own opinions from there, but I don't know where to start. I think that a 35-45 weight is a good starting point for light bashing use (Little jumps, ie. <3 feet, rocks, bumpy stuff, etc)? Will the Volcano diffs hold silicone oil (I see no rubber seals), or am I stuck with grease? If silicone won't work stock, could I just seal it up with rtv silicone, and be good? Assuming I can use silicone oil, what weight should I start testing with? I hear people reccomend 3k-7k for diffs, is this good? It seems that this project is on hold temporarily while I rebuild my poor, neglected truck. I'll be out of town for the next few weeks, so I'll see what happens that way. Finally, I'm going try to learn SolidWorks enough to model the chassis before I start brazing/welding stuff. Is there any interest in having Redcat parts drawn in SolidWorks? If no one cares, I'll just sketch the stuff I need to lay out a chassis, but if people would actually use models of diffs, trannies, etc. I could try to draw those up in some level of detail. Let me know, especially about the SH.18 bearings or if you are interested in the CAD models. Thanks, Kristoffer EDIT: someone mentioned a 1/8 diff. Would such a diff be able to work with the driveshafts from the 1/10 volcano, or are the drive cups totally different? Or, could a 1/10 drive cup be stuck on the 1/8 diff? Also, people talk about shimming the diffs in these trucks. I never did, and mine were fine. If it were to need shimming, where would I find shims? Also, I seem to be missing 2 of the the shim-looking things that go outside the small (5x10x4) bearings on the outdrives, between the bearing and the the aluminum hex. Where could I find this part; I can't find part numbers for on any of the exploded diagrams?
_____________________________
Eflite Blade CX-2 Redcat Volcano S30
Hide Signatures
