RE: Bootlegger?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Bootlegger?
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: Bootlegger? - 1/30/2013 1:21 AM
pitstop000
Score: 105
Last Login: 5/17/2013
Status: offline
Dave Looking Good!
I’m just wondering is the fiberglass top to become a permanent part of the fuse? or will it be removable.
_____________________________
Paul Pappas, AMA 42520
www.NECPO.org
Hide Signatures
(in reply to dphill2)
       Post #: 126
RE: Bootlegger? - 1/30/2013 1:22 AM
tgwhitley
Score: 100
Last Login: 5/24/2013
Status: offline
Dave
I may stop the Typhoon just to build my bootlegger looks great keep posting progress
Tim
Hide Signatures
       Post #: 127
RE: Bootlegger? - 1/30/2013 1:24 AM
PatternPilot
Score: 125
Status: offline
looks good... wish I had a fiberglass deck...
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
       Post #: 128
RE: Bootlegger? - 1/30/2013 4:13 AM
dphill2
Score: 100
Status: offline
Paul,
I have thought about making it removable but the plan was to make it permanent !! What do you guys think ???
Dave...
Hide Signatures
(in reply to pitstop000)
       Post #: 129
RE: Bootlegger? - 1/30/2013 3:46 PM
doxilia
Score: 136
Status: offline
I gave that one a thought too. While having a removable top Arrow style is certainly more practical, it is not quite as elegant as the single fuse.
The main issue I see if making it a single piece fuse is the finish required to the fuse before permanently attaching the deck to it. I suppose there is a way to install the deck as if it were going to be removable (i.e., with some strips down the side top of the fuse to anchor the deck to), tack glue it, sand the job to uniformity, glass the wood and they paint the items separately so one can also finish the fuse area where the deck goes. The only drawback is that the seam would be visible if bonding after paint.
I suppose the alternative would be to finish the fuse interior area before final finish of the exterior so that the deck can be permanently attached and finished together with the fuse. This might be a better option so that the fuse is well blended in finish.
What do you think Dave?
David
Hide Signatures
       Post #: 130
RE: Bootlegger? - 1/30/2013 4:16 PM
PatternPilot
Score: 125
Status: offline
Make it one piece.. less chance for flexing and twisting, plus a much better finish for the plane and you can blend it in and make it seamless.
just my 2 cents if i was building one...
s.
Hide Signatures
(in reply to doxilia)
       Post #: 131
RE: Bootlegger? - 1/30/2013 4:26 PM
dphill2
Score: 100
Status: offline
Guy's,
I think I'm going to make is as close to the orignal Bootlegger as I can !! David a one piece fuse would look as you put it " more elegant" than two piece with a seam showing . I use a product called Aero lite from Aircraft Spruce Co. (its a two part epoxy filler) This stuff is as strong as any product you can buy to fill gaps and seams !! It sands like chalk and is very lite, makes great fillets around the wing,stab and rudder also.. I'm looking forward to blending the top piece in to the balsa sides .
So I guess you have my answer !!
Dave..
Hide Signatures
       Post #: 132
RE: Bootlegger? - 1/30/2013 4:50 PM
dphill2
Score: 100
Status: offline
I've got most of the major parts done and need to start assembly !!
Dave
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 133
RE: Bootlegger? - 2/6/2013 2:50 AM
dphill2
Score: 100
Status: offline
Guy's
Here is the latest on the legger !! Its all framed up and glued together the formers worked out fine after a little adj ! I built the fuse upside down using the stright edge on the top of the sides. After glueing it all together I turned it over in the jig dropped the fiberglas top on and it fit like glove !!! More to come ...
Dave.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 134
RE: Bootlegger? - 2/8/2013 6:02 PM
toddblose
Score: 100
Status: offline
I just found 2 OS 61 VF's so I have ordered the Bootlegger from Don at RCair so I will start on it in the next 2 weeks. I plan on building it with the flat stab
and Steve's scheme
http://toddblose.homestead.com
Team Futaba,CA Models,Neu Motors,FlightPower,Smart-Fly,Tru-Turn
Hide Signatures
       Post #: 135
RE: Bootlegger? - 2/8/2013 11:50 PM
dphill2
Score: 100
Status: offline
Hey Thats great Todd, Glad you found the VF 61's !! Keep in touch on your build when you get started !!
I orded a belly pan for My Southern RC fiberglass Boot from RCaiir and the thing fit just like the orignal.
Dave..
Hide Signatures
(in reply to toddblose)
       Post #: 136
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
