Painting a Hot section how to    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Painting a Hot section how to
Page: [1]
Login
Painting a Hot section how to - 6/5/2012 1:08 AM
LGM Graphix
Score: 166
Last Login: 5/21/2013
Status: offline
Hey guys,
I took these pictures a few weeks ago while doing this with the intent of doing a how to on this subject but forgot all about it, so here it is. Simply put, it's how I do a hot section on exhaust nozzles, I love the way it looks and it's easy to do.
What you'll need:
Aluminum Ducting tape (I prefer this over flite metal for this application as it is stickier, a little thicker, and allows some harsher sanding)
Xacto Knife
Masking tape
Airbrush (I used an Iwata HP-CR for this exerciese)
Mr Clean Magic Eraser
Paint colors - Black, Pthalo Blue Candy, Root Beer Candy
320 grit sand paper
Patience
Since RCU is acting lame and I can't upload pictures, I had to use photo bucket, that's alright though, it'll work fine
Step 1.
Here is the aluminum ducting tape I use, it's 2" wide which is plenty wide for doing nozzles and hot sections. Notice there is already a "grain" to the tape, I try to apply it so the grain is already going the direction I want.
Step 2.
Begin by taping off with masking tape the area's you don't want the aluminum tape to stick to. Once this stuff sticks, there is no getting it off. Use the masking tape so that you can remove the excess!!!!
Step 3.
Start placing the tape where it needs to be, cut the excess off with a sharp exacto blade and just use your thumb to press it all down. Don't get to hell bent on burnishing it down like flite metal, you'll just put marks in it, it's thicker and softer than flite metal.
Step 4.
Using a hex head driver I pressed in fastener shapes where they needed to be on the nozzles
Step 5.
Hex heads in the nozzle
Step 6.
Here is the metal section on the fuselage. Don't worry about there being bumps, wrinkles, etc, that will all go away in the next steps.
Step 7.
Next mask off one panel at a time in preparation for sanding
Step 8.
Sand in the direction of the metal grain. This particular jet is a Mig 29 and after looking at multiple images of the nozzles I wanted to keep it pretty rough looking. I started with 320 grit to knock down the bumps and scrapes, then went to 400 grit just to smooth it off a bit. Continue with progressively finer grits of paper if you want to have a smoother look.
Step 9.
If all of your sanding will be in the same direction, you don't need to mask off the adjacent panels, just be careful not to sand through any corners.
_____________________________
remember when people actually BUILT their airplanes?
Hide Signatures
       Post #: 1
RE: Painting a Hot section how to - 6/5/2012 1:20 AM
LGM Graphix
Score: 166
Status: offline
Ok, now for the fun part.
Break out your airbrush. All of your paint for this will be over reduced, we want to use it more as a wash than an actual pigmented paint. The black in particular. I am using PPG black in this case and SEM Candy's. The SEM Candy Concentrates are mixed with a PPG mixing base and reduced. You can use DBC500 or any of the clear carriers designed for Candy's.
Step 1.
Start airbrushing your black on the sanded aluminum. Spray in the direction of the grain, but don't worry about even coverage. We don't want that, concentrate the black heavier where the nozzle would be dirtier from soot and crap in real life, along seams, in rivets, etc.
Step 2.
Take your Mr Clean Magic Eraser and start rubbing down the part, again, always in the direction of the grain. This will remove most of the black leaving deposits in the sanding scratches, valley's, rivets, grooves etc.
Step 3.
Now take your Pthalo blue candy, over-reduced as well and spray the area's where the blue should be, look at reference photo's to determine where the metal will blue the most.
Step 4.
Rub down the blue with the magic eraser now.
Hide Signatures
(in reply to LGM Graphix)
       Post #: 2
RE: Painting a Hot section how to - 6/5/2012 1:25 AM
LGM Graphix
Score: 166
Status: offline
Step 5.
Now take your over reduced root beer candy and airbrush around the blue, let the root beer go well into the blue to help pull back the blue color around the edges, this will let the root beer blend better in with the blue.
Step 6.
Again, rub it down with the magic eraser
Step 7.
Spray some black back in so that there is a "soot" over some of the color again, this will actually richen the color a little and add some depth to it.
Step 8.
Clear coat with a satin clear (not flat, not gloss) and sit back and enjoy your efforts
Hide Signatures
       Post #: 3
RE: Painting a Hot section how to - 6/5/2012 1:29 AM
FenderBean
Score: 119
Status: offline
very nice, I like your style thanks for sharing!
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
       Post #: 4
RE: Painting a Hot section how to - 6/5/2012 1:42 AM
readyturn
Score: 115
Last Login: 5/20/2013
Status: offline
Jeremy,
Great info as usual.
Rick
Hide Signatures
(in reply to FenderBean)
       Post #: 5
RE: Painting a Hot section how to - 6/5/2012 2:11 AM
hooker53
Score: 100
Status: offline
Jeremy. That's the best one I've seen yet. Thanks for posting this. I wish we had a Sp sticky for tips like this.
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
(in reply to readyturn)
       Post #: 6
RE: Painting a Hot section how to - 6/5/2012 2:15 AM
invertmast
Score: 193
Status: offline
Damn jeremy, those look fantastic! If you want another pair of nozzles to practice on, ill send you some F14 ones. Lol
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
       Post #: 7
RE: Painting a Hot section how to - 6/5/2012 2:23 AM
LGM Graphix
Score: 166
Status: offline
Hey Thomas,
I don't think I need them to practice on, but I'd be happy to do a set for ya for a small fee haha
Hide Signatures
(in reply to invertmast)
       Post #: 8
RE: Painting a Hot section how to - 6/5/2012 2:41 AM
kev-o
Score: 100
Status: online
looks awesome J as usual
if ya aint burnin well?
Hide Signatures
       Post #: 9
RE: Painting a Hot section how to - 6/5/2012 2:43 AM
Greg Wright
Score: 102
Status: offline
Jeremy those look very cool. If you ever want to give it a go with the real titanium i used on my F-100 here is the web site to order it from. Titaniumgoat.com
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Greg Wright
Not a Horizon team member/ But would love to be one!!!!!!!!!!!! BVM Jets/Jetcat
Hide Signatures
       Post #: 10
RE: Painting a Hot section how to - 6/5/2012 3:10 AM
LGM Graphix
Score: 166
Status: offline
Hey Greg,
I still say that yours is the BEST looking F100 hot section I have ever seen, brilliant my friend!
Hide Signatures
(in reply to Greg Wright)
       Post #: 11
RE: Painting a Hot section how to - 6/5/2012 3:11 AM
invertmast
Score: 193
Status: offline
quote:
ORIGINAL: LGM Graphix
Hey Thomas,
I will definitely take you up on that offer once I have a need for them to be painted!
Thomas W.
Hide Signatures
       Post #: 12
RE: Painting a Hot section how to - 6/5/2012 4:03 AM
Ron101
Score: 116
Status: offline
wow!! that looks great
thanks for the tips
"It''''s not personal, Sonny. It''''s strictly business."
Hide Signatures
       Post #: 13
RE: Painting a Hot section how to - 6/5/2012 4:48 AM
sideshow
Score: 107
Status: offline
Those look like $hit!
Awesome! They definitely have that Russian abused look to them.
btw...I like the photo bucket pics better than uploading, they're all full size already.
Thanks!
eeeexcelent...
Bob Convery
Hide Signatures
(in reply to Ron101)
       Post #: 14
RE: Painting a Hot section how to - 6/5/2012 3:53 PM
LGM Graphix
Score: 166
Status: offline
quote:
ORIGINAL: sideshow
Thanks!
Hey Bob,
I had to read that first line a few times haha. I hope by "those look like $hit" you mean the good kind of $hit, lol. Even when I found pictures of a near factory fresh Mig, they look old and abused haha. Love it though, makes for a much more interesting model I think.
Hide Signatures
(in reply to sideshow)
       Post #: 15
RE: Painting a Hot section how to - 6/5/2012 4:11 PM
pbusa1400
Score: 105
Last Login: 5/19/2013
Status: offline
Wow!!! That looks great.
Pablo
Elite Aerosports - ShockWave
Team Horizon
Hide Signatures
       Post #: 16
RE: Painting a Hot section how to - 6/5/2012 4:47 PM
basimpsn
Score: 120
Status: offline
Wow Im jealous..Very nice work
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
       Post #: 17
RE: Painting a Hot section how to - 6/5/2012 7:48 PM
RCISFUN
Score: 105
Status: offline
quote:
ORIGINAL: hooker53
All you have to do is subscribe to the thread and it will be stored in your fourm settings
Awesome work as usual, I subscribed for future reference!
Click for fullsize
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
(in reply to hooker53)
       Post #: 18
RE: Painting a Hot section how to - 6/5/2012 8:27 PM
JeffH
Score: 114
Status: offline
While the real titanium is perfect, your paint is the best I have ever seen. If you look at the way the titanium turned colors, yours duplicated it perfectlly. I bet from 5 feet, you can't tell that yours isnt real titanium.
Hide Signatures
(in reply to RCISFUN)
       Post #: 19
RE: Painting a Hot section how to - 6/5/2012 9:30 PM
DelGatoGrande
Score: 105
Status: offline
on my 1/5 Miraze 2000 i sprayed direct full coats and the i was sanding down to get the color change.
First coat primer, then thick coat of silver,then metal blue ,then one we call bronz (like gold)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
(in reply to JeffH)
       Post #: 20
RE: Painting a Hot section how to - 6/5/2012 9:34 PM
DelGatoGrande
Score: 105
Status: offline
...after the careful sanding has finished, i mix of black and brown oil paint makes it more real.
photos don't give justice of the final result..
http://www.rcuniverse.com/forum/m_10807259/anchors_10807259/mpage_1/key_aviation%252Cdesign%252Cmirage%252C2000/anchor/tm.htm#10807259
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to DelGatoGrande)
       Post #: 21
RE: Painting a Hot section how to - 6/6/2012 12:54 AM
dbsonic
Score: 100
Status: offline
Darn. I just painted my tail cone flat blk. Had I seen this I would have gone this way. Nice work guys. thanks for sharing.
Hide Signatures
       Post #: 22
RE: Painting a Hot section how to - 6/6/2012 2:00 AM
LGM Graphix
Score: 166
Status: offline
Oops, found one more picture of the nozzle from underneath with the rest of the hot section, this is probably my favorite part actually!
Hide Signatures
(in reply to dbsonic)
       Post #: 23
RE: Painting a Hot section how to - 6/6/2012 10:18 PM
RalleKnalle
Score: 100
Last Login: 5/8/2013
Status: offline
very nice....
Jeremy, that´s a great idea.....going to use that tape too. will try...
George, nice job...you haven´t sent me that pictures!!!
have tried a new procedure to paint nozzles...will be published in the new issure of the JP magazin. I guess it does work fine on that bare metal tape too.
Ralle Tailor MD
Hide Signatures
       Post #: 24
RE: Painting a Hot section how to - 6/7/2012 4:45 AM
sideshow
Score: 107
Status: offline
Looks great and I really like the big photo bucket pics...
eeeexcelent...
Bob Convery
Hide Signatures
(in reply to RalleKnalle)
       Post #: 25
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
