caldera 3.0 - wheels don't turn on the ground    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> caldera 3.0 - wheels don't turn on the ground
Page: [1]
Login
caldera 3.0 - wheels don't turn on the ground - 6/6/2012 12:13 AM
rcenth
Score: 100
Last Login: 5/18/2013
Status: offline
 i have the nitro caldera 3.0 i'm having issues with it, when the caldera is on a block and wheels are not touching the ground if i throttle the wheels will turn but, when i put it on the ground it barely moves just rolls a bit no matter how much i rev. i saw a redcat tutorial saying that if this happens it's an issue with the slipper clutch and needs to be tightned, well i tried to tighten it all the way and then pull out  a couple turns and that didn't work then i tightened it completely and that didn't work. here's a picture of my slipper clutch, is it too far tightened?
anybody know how i can fix this issue?
thanks
Hide Signatures
       Post #: 1
RE: caldera 3.0 - wheels don't turn on the ground - 6/6/2012 12:18 AM
billymare
Score: 105
Last Login: 5/16/2013
Status: offline
Dude....  The Spur gear is stripped....
_____________________________
Redcat''s a-plenty,savage XS,2 Savages,1brushless XL
Sprint2, Blitz, Terra Crusher,ast. planes, helicopters and a LOT m
Hide Signatures
(in reply to rcenth)
       Post #: 2
RE: caldera 3.0 - wheels don't turn on the ground - 6/6/2012 12:57 AM
rcenth
Score: 100
Status: offline
ok i'll change it but, how come the wheels turn when it's on the block? is it because when it's on the ground there's weight that it needs to pull so that's the reason they don't turn on the ground because the spur gear is stripped?
Hide Signatures
(in reply to billymare)
       Post #: 3
RE: caldera 3.0 - wheels don't turn on the ground - 6/6/2012 1:11 AM
nitrosportsandrunner
Score: 296
Last Login: 5/24/2013
Status: offline
did you remove a wheel recently? a drive pin could have fallen out from behind the wheel hex.
also, check all your driveshafts(The ones to the wheels and the center ones)
make sure they are all there.
Then check the drive cups(what the driveshafts go into)
There is a small set screw on them. sometimes these can get loose. check them all and tighten if needed.
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
       Post #: 4
RE: caldera 3.0 - wheels don't turn on the ground - 6/6/2012 1:15 AM
rcenth
Score: 100
Status: offline
no i didn't remove a wheel only engine which was replaced recently.
i tried checking the drive cups as i saw a video of somebody saying to do that for this issue as well but, the thing is that on the caldera the screws that are in the drive cups are just a metal point there's no tip to put in a screw driver or hex key, it looks like this:
quote:
ORIGINAL: nitrosportsandrunner
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 5
RE: caldera 3.0 - wheels don't turn on the ground - 6/6/2012 8:16 PM
nitrosteve22
Score: 100
Last Login: 5/22/2013
Status: offline
The ones you want to take a peak at are the drive cups coming from your center trans to your front and rear diffs,they have the little screws in them. Even after threadlocking I had one come loose on me... It happens...
Hide Signatures
       Post #: 6
RE: caldera 3.0 - wheels don't turn on the ground - 6/6/2012 8:28 PM
rcenth
Score: 100
Status: offline
sorry forgot to update this thread with the help of somebody else here i was able to find those screws i checked two of them and they were both already screwed on real tight so maybe it is the spur gear i'm waiting for it to arrive to install it and see if it solves the issue
quote:
ORIGINAL: nitrosteve22
Hide Signatures
(in reply to nitrosteve22)
       Post #: 7
RE: caldera 3.0 - wheels don't turn on the ground - 6/6/2012 8:50 PM
NewRageRC
Score: 100
Last Login: 4/8/2013
Status: offline
It's the spur gear, period. There is enough friction for it to turn the wheels with no resistance but not on the ground. Can't hurt to check everything else over but the problem is obvious.
Hide Signatures
       Post #: 8
RE: caldera 3.0 - wheels don't turn on the ground - 6/6/2012 8:52 PM
rcenth
Score: 100
Status: offline
ok, great. thanks for the quick replies, now just waiting for the spur gear to arrive!
Hide Signatures
(in reply to NewRageRC)
       Post #: 9
RE: caldera 3.0 - wheels don't turn on the ground - 6/8/2012 1:19 PM
billymare
Score: 105
Status: offline
When you re-installed the engine the mesh was not right.  youtube can be your friend when you need to learn how to set mesh....
Hide Signatures
       Post #: 10
RE: caldera 3.0 - wheels don't turn on the ground - 6/8/2012 5:52 PM
rcenth
Score: 100
Status: offline
yeah i should've paid more attention, i never had issues setting it on the shockwave so I guess I didn't pay attention as much this time to get it set properly. i guess since the caldera goes faster and is a 2 speed it has to be set properly since the gear has a chance of wearing out quicker if not set correctly. honestly i've never had a worn out spur gear before though i'm still new to the hobby so i don't have as much experience as others but, that was on the shockwave, on the caldera it wore out really fast, i mean i really haven't even had a chance to do any proper runs most of the time it was on the block while I was working on figuring out other problems.
quote:
ORIGINAL: billymare
Hide Signatures
       Post #: 11
RE: caldera 3.0 - wheels don't turn on the ground - 6/9/2012 10:29 PM
billymare
Score: 105
Status: offline
We have all destroyed spur gears, it's how we learn....
quote:
ORIGINAL: rcenth
quote:
ORIGINAL: billymare
Hide Signatures
       Post #: 12
RE: caldera 3.0 - wheels don't turn on the ground - 6/12/2012 9:29 PM
rcenth
Score: 100
Status: offline
well i got the spur gear and replaced it and the wheels are turning now but, there's a couple issues now. first of all could somebody please check this quick video clip of me rocking the spur gear while holding the clutch bell to confirm i set it correctly? i want to be extra careful i set it up correctly since they only had a steel spur gear for the caldera and if it's not set properly i don't want the clutch bell to wear out and have to replace that - video link: https://dl.dropbox.com/u/38834766/MVI_0814.MOV
ok first issue, after i put everything back together my brakes aren't responding. i made a video:
how can i fix the brakes?
also i tried to run it anyway and when i throttled the engine died, i was able to run it around in the drive way in small bursts but, when i got it in the alley and hit the throttle harder it died. after that i tried to start it and i can't get it to start.
these are the needle settings redcat told me but, i don't recall the needles being that far in, i couldn't get mine to start last time until the LSN was out about 6 turns. i tried to put everything back to factory settings but, it won't start.
HSN: 3 turns out from fully closed
LSN: 2.5 turns out from fully closed
does that sound right?
that means i turn in the needles all the way (clockwise) like I'm screwing in a screw until it reaches the end, then i back it out those number of turns mentioned?
Hide Signatures
       Post #: 13
RE: caldera 3.0 - wheels don't turn on the ground - 6/13/2012 4:43 AM
rcenth
Score: 100
Status: offline
just to update the thread so nobody tries to figure it out, we got the brake issue resolved, i needed to put tubing in the brake linkage rod so the throttle gear pushes the brake linkage rod far enough to apply the brakes.
still having problems getting it to start but, i was given a tip to put a couple drops of fuel into the carb so going to try that tomorrow
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
