Need help with charger settings on my Lead Acid battery    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Need help with charger settings on my Lead Acid battery
Page: [1]
Login
Need help with charger settings on my Lead Acid battery - 6/6/2012 9:41 PM
Flyboy1958
Score: 105
Last Login: 5/23/2013
Status: offline
I was just wondering what settings I should be using on my icharger 206B with my Hanger 9 12v 7Ah sealed battery? I set the charger for PB and when I plug in 12V it comes up as a 6 cell battery, which I guess it is then. Now for the charge rate, should I be using .70mAh or 7.0 or what? I charged it for about 45 minutes using .70mAh and it still seems almost dead. I don't know much about charging or batteries. Thanks.
Hide Signatures
       Post #: 1
RE: Need help with charger settings on my Lead Acid bat... - 6/6/2012 9:42 PM
Flyboy1958
Score: 105
Status: offline
My wall wart charger doesn't work any longer.
Hide Signatures
(in reply to Flyboy1958)
       Post #: 2
RE: Need help with charger settings on my Lead Acid bat... - 6/6/2012 10:09 PM
Goldenduff
Score: 114
Last Login: 5/24/2013
Status: offline
700mah
You might have the peak detection set too sensitively- basically the charger prematurely detects a peak voltage and stops charging.
Try charging at 700mah for 10hrs or so, should get around 13-14v when fully charged I think!
_____________________________
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
       Post #: 3
RE: Need help with charger settings on my Lead Acid bat... - 6/6/2012 10:32 PM
Flyboy1958
Score: 105
Status: offline
I just looked at the charger screen again and it is set at .70 A I thought it was mAh but it just says A for amps I guess. So should I set it at 7.0 A ?
Hide Signatures
(in reply to Goldenduff)
       Post #: 4
RE: Need help with charger settings on my Lead Acid bat... - 6/6/2012 10:38 PM
Goldenduff
Score: 114
Status: offline
No! Charging at 7amps is charging at 1C, you need to charge at 0.1C so 0.1C x 7000mah= 700mah. That's 0.7amps. Should take around 10hrs.
Hide Signatures
       Post #: 5
RE: Need help with charger settings on my Lead Acid bat... - 6/7/2012 2:09 AM
Flyboy1958
Score: 105
Status: offline
Thanks, I set the charger at .70A so I'll see how that goes.
Hide Signatures
       Post #: 6
RE: Need help with charger settings on my Lead Acid bat... - 6/7/2012 1:53 PM
Rodney
Score: 174
Status: online
Yes, set it at 0.1C or 0.7amps. you will ruin a Pb if you charge it to fast. You should not have to worry about overcharge as your charger, if designed to charge Pb cells, will limit the voltage it gets charged to. This will be about 13.7volts for a 6 cell battery.
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.156RCU1
