cant believe it!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> cant believe it!
Page: [1] 2   next >   >>
Login
cant believe it! - 6/9/2012 4:02 AM
t-max97
Score: 168
Last Login: 5/22/2013
Status: online
I just got a new o.s .46 la and no matter how much I richen it it runs very hot so I took It apart and theres not a head gasket on it and it didn't come with an exhaust gasket either! I pretty surprised an os engine would be missing a gasket . I called then and they are sending me a gasket but the more I think about it i think I should get my engine replaced just to be safe. Do you think I should get it replaced?
_____________________________
If you dont know what your doing, its best to do it quickly.
Hide Signatures
       Post #: 1
RE: cant believe it! - 6/9/2012 5:06 AM
Lnewqban
Score: 163
Last Login: 5/6/2013
Status: offline
I would ask for replacement under warranty.
Lnewqban - "The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge." - E. H.
Hide Signatures
(in reply to t-max97)
       Post #: 2
RE: cant believe it! - 6/9/2012 5:16 AM
t-max97
Score: 168
Status: online
I think that would be the smart thing to do I just hate having to wait even longer before i can fly my plane lol.
Hide Signatures
(in reply to Lnewqban)
       Post #: 3
RE: cant believe it! - 6/9/2012 7:32 AM
Ernie Misner
Score: 130
Last Login: 5/20/2013
Status: offline
Look for any score marks on the piston or liner before you decide whether to keep it or not.
Ernie Misner
Hide Signatures
       Post #: 4
RE: cant believe it! - 6/9/2012 12:42 PM
Hobbsy
Score: 650
Last Login: 5/21/2013
Status: online
It should not have an exhaust gasket, I have four LAs, I'll check for head gasket. I'm pretty sure it should have a aluminum looking head gasket. I'll be back.
When you first pop the head off it appears to not have a gasket but gently prying upward in one of the bolt holes will get this.
Click to see fullsize image.
Click for fullsize
< Message edited by Hobbsy -- 6/9/2012 1:30 PM >
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 5
RE: cant believe it! - 6/9/2012 1:17 PM
fizzwater2
Score: 124
Status: offline
the LA is a bushing engine, right? How much oil is in your fuel?
No matter where you go, there you are!
Hide Signatures
(in reply to Hobbsy)
       Post #: 6
RE: cant believe it! - 6/9/2012 1:38 PM
earlwb
Score: 584
Status: offline
Did you buy the engine from a USA dealer? Or was it bought overseas and shipped in? Did you buy the engine used from someone else?
The overseas engines are setup with high compression as they do not use nitromethane in their glow fuel like most everyone does in the USA.
So using more than 5% nitromethane in a engine setup for no nitro glow fuel is not good on the engine.
What brand fuel are you using and what nitro-percentage is in the fuel?
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to fizzwater2)
       Post #: 7
RE: cant believe it! - 6/9/2012 6:01 PM
aspeed
Score: 105
Status: offline
Sometimes the head gaskets are squished inside the head groove and you can't see them.  I check for the gap between the head and piston and if it is around .015" you likely don't need a gasket at all unless it is burning plugs out.  It is just another source for leaks if it is machined properly. I never use exhaust gaskets anyway.  It shouldn't be running hot though.  I have a .40 LA that gets hot too.  I just run it on the verge of a 4 stroke and it is good.
Hide Signatures
(in reply to earlwb)
       Post #: 8
RE: cant believe it! - 6/10/2012 12:42 AM
t-max97
Score: 168
Status: online
Im sorry guys I feel really stupid lol it was there it was just stuck to the top. And I took the plane to the club for the first time today and it ran fine when it was in the air. lol
Hide Signatures
(in reply to aspeed)
       Post #: 9
RE: cant believe it! - 6/10/2012 1:17 AM
llindsey1965
Score: 111
Status: offline
guys i know this has nothing with the thread but i need help!!!!  i have a 1/4 scale great planes patty wagstaff that i ran over my wingtube and it is no good been looking for a tube for 2 months now  ,,  measurement is  30.4 mm  or  1 3/16   x  665 mm  or  24  3/16   i will take either alum or composite thanks  , hope you can help   my email is   llindsey832@gmail.com  other wise my plane is garbage have tried everywhere on the internet they are on back order from tower and great planes have been for 2 months
Hide Signatures
       Post #: 10
RE: cant believe it! - 6/10/2012 1:42 AM
Lnewqban
Score: 163
Status: offline
Any machine shop could fabricate one aluminum tube with those dimensions from a tube of bigger exterior diameter and heavy duty walls.
Hide Signatures
(in reply to llindsey1965)
       Post #: 11
RE: cant believe it! - 6/10/2012 1:48 AM
llindsey1965
Score: 111
Status: offline
tried that they said it is a odd ball size     was hoping someone somewhere would know someone that had one  Thanks
Hide Signatures
       Post #: 12
RE: cant believe it! - 6/10/2012 2:42 AM
thepamster
Score: 115
Status: online
This place sells wing tubes though your dimentions seemed odd.
http://www.tntlandinggear.com/
The Pamster
AMA 202345
Hide Signatures
       Post #: 13
RE: cant believe it! - 6/10/2012 3:12 AM
LARRYKOP
Score: 105
Status: online
Go to home depot or Lowes and get a piece of 1 1/4" Dowel Rod and then get some body to turn it down on a Lathe. I'm about 100 miles from you if you can't find anybody else. I have a lathe.
LARRYKOP@AOL.COM
Larry Kopecky
Hide Signatures
       Post #: 14
RE: cant believe it! - 6/10/2012 3:28 AM
blw
Score: 655
Status: offline
quote:
ORIGINAL: t-max97
No problem. The thread probably caused a lot of readers to think. Glad you asked.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 15
RE: cant believe it! - 6/10/2012 4:14 AM
t-max97
Score: 168
Status: online
lol yeah trying to figure out what the problem was when there wasn't one.
Hide Signatures
(in reply to blw)
       Post #: 16
RE: cant believe it! - 6/10/2012 12:10 PM
OliverJacob
Score: 110
Status: offline
I have a Great Planes Extra 300 Patty Wagstaff. And  I just measured the tube - it is 30mm. Yours might have been bent.
Hide Signatures
       Post #: 17
RE: cant believe it! - 6/10/2012 12:47 PM
Hobbsy
Score: 650
Status: online
I am a fan of the LA series because of their simplicity and user friendliness, they are built tough and their conservative porting makes for a great Diesel conversion.
Click for fullsize
Hide Signatures
       Post #: 18
RE: cant believe it! - 6/10/2012 1:08 PM
the pope
Score: 101
Status: offline
The ones Ive seen had enough go to pull a trainer around pretty good . Good enough that I bought one and seeing it weighs about the same as a 25 Im gonna whack it on one of that size planes . Oh yea the ones Ive seen were abused pretty badly and kept coming back for more . Cheers the pope
Hide Signatures
       Post #: 19
RE: cant believe it! - 6/10/2012 2:37 PM
mike109
Score: 148
Status: offline
G'day
I've had a couple of LA 46s. And I have recommended them to a couple of learners. I like their simplicity, I like the fact that they are pretty tough and survive crashes better than the more complex ball raced engines. I like their economy and they are a reasonable price too. They are also very reliable.
I used to have one in a World Models Skyraider Mach 1. I rarely got to fly it. Everyone else liked to fly it so much that I rarely got to. My club president loved to borrow it to show newcomers what it was like to fly a model.
There is a diesel converted one that turns up at the Cowra Diesel Weekend every year. It really screams and has been doing it for about 6 years now. The bloke made his own diesel head for it.
Cheers
Mike in Oz
"I just had no control. Must be the radio." Club Saito #597 Kadet Brotherhood #66
Hide Signatures
(in reply to the pope)
       Post #: 20
RE: cant believe it! - 6/10/2012 4:36 PM
snir2001
Score: 100
Status: offline
Well, the crankcase build quality of the OS's is very good, you do NOT need any exhaust gasket.
But, again, the last good OS was the SF series, since than they become worse and worse...
I said it once and I will say it again, get yourself an ASP (AKA Magnum, AKA SC, AKA Evolution) from HobbyKing, they run BETTER than OS (if break-in properly).
You know what? for the money, get two of them...
The are simple, reliable, cheeeeep... the best value for money, and run perfect. It's ain't Rossi nor Webra, but hey, neither OS...
I have some OS's, I cherish and love my OS FSR and OS SF, but the FX and AX went where they belong, to the trash.
Hide Signatures
(in reply to mike109)
       Post #: 21
RE: cant believe it! - 6/10/2012 5:20 PM
llindsey1965
Score: 111
Status: offline
the part is gpma 2328  and it gives the dimensions  and yes i bent mine it got ran over  on tower hobbies
Hide Signatures
(in reply to snir2001)
       Post #: 22
RE: cant believe it! - 6/10/2012 5:21 PM
llindsey1965
Score: 111
Status: offline
thanks larry will try that  thought a wood dowell might add extra weight
Hide Signatures
(in reply to LARRYKOP)
       Post #: 23
RE: cant believe it! - 6/10/2012 6:24 PM
Hobbsy
Score: 650
Status: online
Here's another that makes a fine Diesel, I had the head for 3 or 4 years before I could come up with the .61SF engine.
Click for fullsize
Hide Signatures
       Post #: 24
RE: cant believe it! - 6/10/2012 8:58 PM
blw
Score: 655
Status: offline
I agree about the Evolutions. Just my opinion, but they seem to be designed as the top end offerings from Sanye over Magnums and ASPs. I wouldn't knock either of those either. I've run most of the line and they all seem to be hot engines at reasonable prices. OS engines aren't priced to be repaired, imo.
Coach Pat Dye
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> cant believe it!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
