airboat adjustment for straight running    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> airboat adjustment for straight running Page: [1] 2   next >   >>
Login
airboat adjustment for straight running - 6/9/2012 3:37 PM
Mikeup
Score: 105
Last Login: 6/17/2013
Status: offline
Now as title says, what adjustments do i need to make so airboat goes straight, thanks.
Hide Signatures
       Post #: 1
RE: airboat adjustment for straight running - 6/9/2012 10:33 PM
rcairboater
Score: 110
Last Login: 6/4/2013
Status: offline
We need additional information such as the length, width and size of motor. All are factors here.
-Gary
Hide Signatures
(in reply to Mikeup)
       Post #: 2
RE: airboat adjustment for straight running - 6/10/2012 3:16 AM
Mikeup
Score: 105
Status: offline
The airboat is 21" long and 14" wide with a 700-8.4 grauper with a single airrudder and will be powered by 2S lipo. The 700 is a guess but has plenty of get-up and go. The airboat is all wood. Thanks for replying.
Hide Signatures
(in reply to rcairboater)
       Post #: 3
RE: airboat adjustment for straight running - 6/10/2012 9:19 AM
Altered1
Score: 106
Last Login: 6/20/2013
Status: offline
Setting the rudder correctly will do it.  You may need a little bit of left to counter rotation of the prop,  but this is minor.  Just make sure there is enough surface area and travel on the rudder.  the boat will turn easier into the rotation of the prop than against it, so allow a bit more travel against it.
If you're really worried, a heading hold gyro will work well too, but this is really not necessary.
Hide Signatures
       Post #: 4
RE: airboat adjustment for straight running - 6/10/2012 3:39 PM
Mikeup
Score: 105
Status: offline
Thanks alot!
Hide Signatures
(in reply to Altered1)
       Post #: 5
RE: airboat adjustment for straight running - 6/11/2012 4:28 PM
asmithnc
Score: 100
Last Login: 6/18/2013
Status: online
Water Rudder.
_____________________________
Member of the RCAA
Custom Rudder Works
Hide Signatures
       Post #: 6
RE: airboat adjustment for straight running - 6/14/2012 9:57 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: asmithnc
Water Rudder.
+10 on the wet rudder. You can ask Dadkins how well my boats turn with a wet rudder. We have ran together a few times.
You can get a good straight run with air rudders but you need to have *zero* slop in the linkages and dual rudders IMO.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to asmithnc)
       Post #: 7
RE: airboat adjustment for straight running - 6/15/2012 5:18 AM
1QwkSport2.5r
Score: 155
Status: offline
I went cheap in the rudder department and made my own. The wood was free and I spend about $6 on the brass parts and used regular electronics solder and flux to assemble the pivot and blade assembly. The rudder strut would be different for each boat depending on the transom shape/configuration.
A break-away is very important - unless you dont mind the transom getting ripped apart if you hit something. I have hit turtles twice, and other than a broken nylon screw the boat came away unscathed. I use captured ball/cup rod ends on the rudder so the linkage doesnt break if the break-away activates.
This is the ideal design IMO. A lathe and milling machine can make a much higher quality piece than what I made, but I dont have a lathe or milling machine.
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 8
RE: airboat adjustment for straight running - 6/15/2012 9:26 AM
Altered1
Score: 106
Status: offline
Great craftmanship there !
Hide Signatures
       Post #: 9
RE: airboat adjustment for straight running - 6/15/2012 11:51 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Altered1
Thanks, Altered!
I have these and some pics of my other rudder I made over on the RCAW forum. Both kamikaze's have one of these rudders. If someone wanted to try one of these, I'd make one for the cost of shipping probably.
Hide Signatures
       Post #: 10
RE: airboat adjustment for straight running - 6/15/2012 5:33 PM
Mikeup
Score: 105
Status: offline
Thanks for pitures. I'm getting ready for cancer operation on the 25 of July but your offering is alot to ask of anyone. I'll wait till i recover from it. Cancer is cured, thank god. I wasn't planning a fancy dan type of water rudder. Thanks for replying.If you make me one , only not a fancy dan, i'll gladly pay for your work and time..I'll make it 2 airudder system in the meantime. No bull on what i just typed, not my way of doing things. You WILL take the money too! Now 2 airudders is a snap in my boat but the flip up of prop has soaked in yet in construction.. I just took a walk and need a nap.
< Message edited by Mikeup -- 6/15/2012 6:20 PM >
Hide Signatures
       Post #: 11
RE: airboat adjustment for straight running - 6/15/2012 10:23 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Mikeup
I'll make you a rudder. Email me a picture if you can, and measurements of the transom. I'll glue up a block of wood when I get back into town. Laminating multiple pieces of wood like I did makes the wood more stable than a single large block. Less warpage that way.
Better yet, give me all of the dimensions of the boat so I can better tailor the strut length. I usually set my rudder so I have 3-3 1/2" in the water so the rudder still bites good in turns. The downside is weedy water is often problematic.
My email address is legalv8s10@comcast.net . We can work out the details later. I could maybe have the assembly done before your surgery.
Good luck on your recovery.
Edit: If you have a decent pond or lake near you, I could bring your rudder to you personally instead of shipping it, and bring a boat or two with me. Just a thought. You're only 4 hours from me. Roughly.
Hide Signatures
       Post #: 12
RE: airboat adjustment for straight running - 6/15/2012 11:50 PM
Mikeup
Score: 105
Status: offline
email add; manningdh2@live.com  airboat is 24" x 12 "wide at top of transom and is tapered to 11" at bottom. Now it is 1 3/4" at transom deep. Pond is moss but i bring a garden rake and pull moss    in and away from area i boat. I get wife to send picture.Pictures are emailed , hope this helps, thanks.
< Message edited by Mikeup -- 6/16/2012 12:22 AM >
Hide Signatures
       Post #: 13
RE: airboat adjustment for straight running - 6/16/2012 1:32 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Mikeup
email add; manningdh2@live.com  airboat is 24'' x 12 ''wide at top of transom and is tapered to 11'' at bottom. Now it is 1 3/4'' at transom deep. Pond is moss but i bring a garden rake and pull moss    in and away from area i boat. I get wife to send picture.Pictures are emailed , hope this helps, thanks.
I got your email with the pictures. I will get something put together and I'll get back to you.
Hide Signatures
       Post #: 14
RE: airboat adjustment for straight running - 6/16/2012 5:21 PM
Mikeup
Score: 105
Status: offline
Ok, got an idea, i have some brass that is a foot long and a1' wide and cut have lenghtwise and also i have a Original rudder. Now if i bend brass and screw into exterior of transom low. take the other bent piece and lay almost beside the the first. Lenght would be close to 5 1/2". Now the transom could be cut inside enough to out a 1 x 2 , 6" long for strenght and cover with 1 3;2" ply-top of transom.I can rivet the 2 long brass pieces for strenght. I have plastic break away bolts. Now for twin airrudders. i can drill  down into 1 x 2 vertical about 4" apart. Slip brass shafts into holes and take some heavier rod and  slide into brass for up right. The airrudders will be stationary and let the water rudder  be the boss. Pretty hard to sync water rudder and airdder. I have a cross member for airrudder  to maintain equal distance. What do you think?-Why need airrudder?s
Hide Signatures
       Post #: 15
RE: airboat adjustment for straight running - 6/16/2012 11:52 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Mikeup
Ok, got an idea, i have some brass that is a foot long and a1' wide and cut have lenghtwise and also i have a Original rudder. Now if i bend brass and screw into exterior of transom low. take the other bent piece and lay almost beside the the first. Lenght would be close to 5 1/2''. Now the transom could be cut inside enough to out a 1 x 2 , 6'' long for strenght and cover with 1 3;2'' ply-top of transom.I can rivet the 2 long brass pieces for strenght. I have plastic break away bolts. Now for twin airrudders. i can drill  down into 1 x 2 vertical about 4'' apart. Slip brass shafts into holes and take some heavier rod and  slide into brass for up right. The airrudders will be stationary and let the water rudder  be the boss. Pretty hard to sync water rudder and airdder. I have a cross member for airrudder  to maintain equal distance. What do you think?-Why need airrudder?s
Basically, if you want your airboat to drive more like a car then you go wet rudder. If you want to be able to slide in corners and fishtail, then you want air rudders. You do not need to run both at the same time. In fact, it would be simpler to do one or the other. I have air rudders for my Big Kamikaze I can bolt on and I just set it up so the linkage for the wet rudder bolts right up to my air rudders so there is no need to change the whole linkage. (I like stuff to be as easy as possible) The best method I found that was light weight and strong was using some very small brass hinges.. Something you might see on a small jewelry box. These are the air rudder pivots. Then I just bent a piece of aluminum to screw the hinges to on top and used two small chunks of plywood that mount to the bottom of the engine stand. I will dig through my photobucket album and see if I have pictures of my setup and post them for you. All of my boats are Glow powered, so my engine mounts are larger and slightly more complex than yours... But the rudder mount doesnt need to be too complicated to be effective.
What material did you use for the transom of your boat?
Hide Signatures
       Post #: 16
RE: airboat adjustment for straight running - 6/17/2012 12:04 AM
1QwkSport2.5r
Score: 155
Status: offline
This is one of my build pics of the big kamikaze. Dual air rudders mounted to the back of the engine stand.
This is how I originally had the air rudder linkages set up. I have since changed the entire linkage around, but I dont have a current photo of it. The bellcrank on the transom originally doubled as the rudder bracket. I could unbolt the rudder blade to run air rudders only or leave the wet rudder on it with the air rudders. The linkage was poorly designed originally as it created some friction and made the servo have to work harder to center it..
All I did differently is instead of having a bellcrank on the hull to drive the air rudder I now just connect the control cable directly to one air rudder blade and this seems to work okay.
Edit: added pictures.
Horizontal mount, big Kamikaze
MiniKaze:
< Message edited by 1QwkSport2.5r -- 6/17/2012 12:33 AM >
Hide Signatures
       Post #: 17
RE: airboat adjustment for straight running - 6/17/2012 3:38 AM
Altered1
Score: 106
Status: offline
Hey 1QwkSport2.5r,
I've been meaning to ask - the white holder for the golden rod on the rudder control line of the Minikaze - where did you get that ?   Did you make that ?
Hide Signatures
       Post #: 18
RE: airboat adjustment for straight running - 6/17/2012 4:16 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Altered1
Hey 1QwkSport2.5r,
I made it myself from aluminum soffit material. It acts as a cable clamp and an anti-buckling device.
Hide Signatures
       Post #: 19
RE: airboat adjustment for straight running - 6/17/2012 7:53 AM
Altered1
Score: 106
Status: offline
It's a great idea, cheers
Altered1
Hide Signatures
       Post #: 20
RE: airboat adjustment for straight running - 6/17/2012 4:27 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Altered1
Altered1
I use Sullivan semi-flex cables (.056" diameter) and I havent had one buckle yet, but I put the holder on there for insurance". Its what I like to call "Redneckin' it". lmao.
Hide Signatures
       Post #: 21
RE: airboat adjustment for straight running - 7/27/2012 11:31 PM
1QwkSport2.5r
Score: 155
Status: offline
Here's a few pics of the rudder strut I'm making..
Raw block, made from 1/8" +/- american cherry and red oak.
Carved it today. Each one I've done I carved differently.
Hide Signatures
       Post #: 22
RE: airboat adjustment for straight running - 7/27/2012 11:46 PM
1QwkSport2.5r
Score: 155
Status: offline
Evidently I had a duplicate post there for some weird reason.
edit: dupe post.
< Message edited by 1QwkSport2.5r -- 7/28/2012 2:30 AM >
Hide Signatures
       Post #: 23
RE: airboat adjustment for straight running - 7/28/2012 1:54 AM
Altered1
Score: 106
Status: offline
I'm guessing here, but are you using a belt sander for the shaping?
Hide Signatures
       Post #: 24
RE: airboat adjustment for straight running - 7/28/2012 2:33 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Altered1
No. I made all of the cuts with my benchtop band saw and did my rough shaping with the band saw with final detail work done with a Dremel and 60 grit sanding drum. I followed with 80 grit sandpaper by hand to remove the scratches from the dremel and now I will drill the holes and get 2-3 coats of epoxy on it to seal it from all water intrusion. When the last coat of epoxy is cured, I'll topcoat the epoxy with polyurethane to drop the sheen from a "sticky" gloss to a slippery satin/matte finish. This makes a HUGE difference in how the water "sticks" to the surfaces.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.154RCU1
