RE: o,s, 32 max    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: o,s, 32 max
Page: <<   < prev  1 2 3 [4] 5 6   next >   >>
Login
RE: o,s, 32 max - 6/17/2012 5:47 PM
airraptor
Score: 130
Last Login: 5/20/2013
Status: offline
Inverted i dont know who you are but just give up on PIG he doesnt get it. He thinks the plane is flying faster down wind than it is upwind. Now from the ground the plane does pass him faster downwind but the plane isnt flying faster.
He did give up on trying to explain how and engine can gain power and RPM flying down wind and lose power upwind. I do know one ting everytime i set the needle on the engine just before takeoff i will turn the plane down wind to get the needle set right LOL I wonder if if when i have an engine on the test stand will gain more RPM also pointed down wind. HUM.....
Pig thanks for all the posts in here. really made me laugh.
_____________________________
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to combatpigg)
       Post #: 76
RE: o,s, 32 max - 6/17/2012 5:50 PM
combatpigg
Score: 376
Status: offline
quote:
ORIGINAL: Lownverted
quote:
ORIGINAL: combatpigg
How much HP does it take to go from 155 mph to 170..? [with a 8x7]
It's a significant amount [almost 1 HP] and it isn't being furnished by the engine. The engine only has enough power to do 155 on it's own in calm air.
There are no free lunches in energy exchange and the engine acts like a watt meter in this case as it registers the energy boost with a measurable jump in rpm. It takes 2.6 HP to do 155 mph with a 8x7 and it takes 3.5 HP to go 170.
The external power is sent through the airframe, through the prop and the engine looks like ''The Hero'' because it was able to spool up in response to this invisible boost...but never forget the fact that the engine ON IT's OWN POWER never could have reached that level of power without outside help.
Works just the same way as in a vertical dive. People who know better can see power getting back fed into the machine from Mother Nature's stored energy.
Wrong, wrong wrong.
The difference in the GROUND speed is the wind. Not extra magic force. The plane is going the same AIRSPEED both ways.
Seroiusly, get a clue. There is no magic gain in HP.
Mount a rubberband motor with a huge prop to the top of one of your planes and fly it both real slow and real fast to witness the transfer of energy both into and out of that motor with your own eyes.
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to Lownverted)
       Post #: 77
RE: o,s, 32 max - 6/17/2012 5:52 PM
iron eagel
Score: 118
Status: offline
quote:
ORIGINAL: iron eagel
I isolated part of your quote above.
Actually Doppler is a pretty good measurement system, because it uses a time reference as it basis for calculations.
This is exactly why its not accurate!
Actually it is very accurate as the time reference is within parts per million ( the error is due to the algorithms used within the program) , Keep in mind that the indicated airspeed in the aircraft can also have a tolerance error of upwards of 5 % as well. The indicated airspeed in two aircraft flying side by side can be off from each other upwards of 10 percent if the tolerance errors for their airspeed indicators are both off by equal amounts positive and negative so as you can see the airspeed indicator isn't gospel either.
Now as far as how you can use the ground based speed readings to determine airspeed is simply factor in the wind plus or minus depending on your direction of travel. If the wind isn't parallel to your direction of travel vector analysis can compensate for the angular momentum.
Either way for our purposes close is good enough, we are not trying to rendezvous two spacecraft in orbit, and need only an indication of speed to get an idea of performance. Bottom line: your airspeed is not a good indication of your actual speed, Like I pointed out in my flight to Maine in a cub. It took me right around eight hours to make the 250 mile trip in the cub with gas, food and rest stops included, I have driven the the same trip in a little as 5 hours by car even dealing with the traffic in Boston, Portland and Augusta so this day I could have gotten there quicker driving.
Hide Signatures
       Post #: 78
RE: o,s, 32 max - 6/17/2012 6:16 PM
combatpigg
Score: 376
Status: offline
quote:
ORIGINAL: airraptor
Your lying sack of BS speed claims never fail to make me laugh.
If I was caught blabbing such a blatant lie about my plane's speed in a public speed forum, I'd probably have to either change screen names or else get back into hot rodding where lying about your power and speed is considered status quo with all the yayhoo-wannabee-tirekickers.
Hide Signatures
(in reply to airraptor)
       Post #: 79
RE: o,s, 32 max - 6/17/2012 6:21 PM
Lownverted
Score: 110
Status: offline
Wrong, wrong wrong.
RPM stays the same, ground speed changes. No magic power
Mach 3 with my hair on fire!
Hide Signatures
       Post #: 80
RE: o,s, 32 max - 6/17/2012 6:30 PM
Dave
Score: 100
Last Login: 5/19/2013
Status: offline
I fly a SIG WONDER with an OS .32SX engine .APC 8x6 propeller 110 + MPH .
Hide Signatures
       Post #: 81
RE: o,s, 32 max - 6/17/2012 6:36 PM
airraptor
Score: 130
Status: offline
quote:
ORIGINAL: airraptor
PIG where did i once in this thread state a Speed claim? Now your calling me a lyer? (Ok I went back and looked I said the LR-1 is around 170mph)
Pig explain to the public again how and engine gains RPM on a downwind pass again. Explain to the public again how an engine Losses RPM on a upwind pass? I find it very funny ho you have nothing better to do than follow me around on the forums and try to debunk my stuff that I say. What ever floats your boat. Glad i give you purpose in here. I am done here I AM GOING FLYING AGAIN.
AMA # 186123
Hide Signatures
       Post #: 82
RE: o,s, 32 max - 6/17/2012 6:50 PM
combatpigg
Score: 376
Status: offline
quote:
ORIGINAL: airraptor
quote:
ORIGINAL: airraptor
You gotta be kidding....How about title of your 190mph video that has thousands of hits..???
Go find a rock to crawl under....pathetic.
Hide Signatures
       Post #: 83
RE: o,s, 32 max - 6/17/2012 9:32 PM
Lownverted
Score: 110
Status: offline
Sorry I'm late to the party, been out pylon racing today. You know CP, those slow planes.
Read up, you might learn something.
http://www.free-online-private-pilot-ground-school.com/navigation-principles.html
A pilot flying in a 70-knot gale would be totally unaware of any wind (except for possible turbulence) unless the ground were observed. In reference to the ground, however, the airplane would appear to fly faster with a tailwind or slower with a headwind, or to drift right or left with a crosswind.
Wikipedia.org
Ground speed can be determined by the vector sum of the aircraft's true airspeed and the current wind speed and direction; a headwind subtracts from the ground speed, while a tailwind adds to it. Winds at other angles to the heading will have components of either headwind or tailwind as well as a crosswind component.
And on and on and on.....
http://www.aerospaceweb.org/question/instruments/q0210.shtml
http://wiki.flightgear.org/Rectangular_Course
oh wait....here is what NASA says, or are you smarter than them too? I think not.
http://www.grc.nasa.gov/WWW/k-12/airplane/move3.html
Gravity is a constant so that can be eliminated from your silly argument, that leaves up wind vs. down only. If you read and pay attention to any of the above you would understand that there is no difference because of the wind either.
Airspeed does not change from up wind to down, ground speed does.
I still suspect that even though the entire collective mind of the aviation world proves you wrong over and over again, you will still refuse to accept this as truth.
Hide Signatures
       Post #: 84
RE: o,s, 32 max - 6/18/2012 1:02 AM
combatpigg
Score: 376
Status: offline
What do any of your sources say about doppler recordings that consistently show higher rpm downwind than upwind. ?
How does Wavoscope create rpm that isn't really there on the downwind leg..?
Just ignore it as "magic"..?
You still haven't addressed this......Mount a rubberband motor with a huge prop to the top of one of your electric or fuel powered planes and fly it both real slow and real fast to witness the transfer of energy both into and out of that rubberband motor with your own eyes.
[/quote]
Hide Signatures
       Post #: 85
RE: o,s, 32 max - 6/18/2012 1:52 AM
airraptor
Score: 130
Status: offline
PIG you are correct in that the rubber ban prop will change speed as the plane speeds up or down but it would not increase in RPM down wind and will not slow down in the wind.
Oh just got in from a great day of flying fly some new planes.
CP i have had "real" telemetry in a plane. I was able to measure head temp, rpm and airspeed of the plane. none of those three area's data changed up wind or down wind as long as i stay fairly level. now the rpm and speed would rise in a dive both upwind and down wind. I did this on a WM t-34 with a OS 46 AX trying to find the best prop. the 46AX would turn the prop at 13,800 on the ground and run right around 15,100 in level flight. The air speed stayed right around 95 through the whole flight when level. i then switched to a engine that spin the same prop at 17,000 on the ground. It would unload to around 18,000-18,200. the flight sped only went up to 115-117. Still thru all this testing never once did the engine gainpower/rpm downwind.
AMA # 186123
Hide Signatures
       Post #: 86
RE: o,s, 32 max - 6/18/2012 3:25 AM
speedracerntrixie
Score: 189
Status: offline
Raptor, sounds like the same argument I have with guys saying that their elevator trim changes from upwing to downwind. Sometimes all the explaination in the world dosen't matter. It's like trying to clean the interior of your car from outside with the windows up.................ain't nothin gonna get inside!   LOL
Hide Signatures
       Post #: 87
RE: o,s, 32 max - 6/18/2012 3:36 AM
Lownverted
Score: 110
Status: offline
Just ignore it as ''magic''..?
CP
You are talking in circles. I have proved over and over again that the airspeed upwind vs. downwind is the same, and that only ground speed changes. In your scenario this can't be true.
Your rubber band motor analogy proves nothing except that you have no clue what you are talking about. There will be NO DIFFERENCE in RPM upwind vs down. Period. Over. Done.
As far as the doppler plots go, what you are seeing is well within the margin of error, but completely opposite of the laws of aerodynamics and physics. You are simply choosing to see what you want to see either because you don't have anyone around to talk to and explain whats really going on, or you know you are incorrect yet are too stubborn to admit it. The plane SOUNDS faster and LOOKS faster because you are a fixed point on the ground. Airspeed, & therefore what the airplane see's is EXACTLY the same. You are confusing airspeed with ground speed.
Here it is plain and clear: It is aerodynamically & physically impossible for an airplane to gain rpm downwind vs up.
You seem like a reasonably smart guy, I'm baffled as to why you don't this? You are the only person I've ever come across in the ENTIRE WORLD who doesn't understand this basic tenet of aviation. You must be some kind of super genius, because everybody else is wrong. Yeah right!
Your turn to prove ME wrong. Find just one site, one shred of credible evidence, something that upholds your claim and I'll listen. Until then you are just a troll. Go away troll.
Hide Signatures
       Post #: 88
RE: o,s, 32 max - 6/18/2012 5:39 AM
combatpigg
Score: 376
Status: offline
quote:
ORIGINAL: airraptor
CP i have had ''real'' telemetry in a plane. I was able to measure head temp, rpm and airspeed of the plane. none of those three area's data changed up wind or down wind as long as i stay fairly level. now the rpm and speed would rise in a dive both upwind and down wind. I did this on a WM t-34 with a OS 46 AX trying to find the best prop. the 46AX would turn the prop at 13,800 on the ground and run right around 15,100 in level flight. The air speed stayed right around 95 through the whole flight when level. i then switched to a engine that spin the same prop at 17,000 on the ground. It would unload to around 18,000-18,200. the flight sped only went up to 115-117. Still thru all this testing never once did the engine gainpower/rpm downwind.
Haven't you flown in a pylon race or just for fun where the plane doesn't unload until it makes the first downwind turn...? No dive involved.
Hide Signatures
       Post #: 89
RE: o,s, 32 max - 6/18/2012 4:35 PM
airraptor
Score: 130
Status: offline
quote:
ORIGINAL: airraptor
depends on how long i fly in to the wind before i mae the down wind turn. the only reason the engine will uload on the down wind is because its still accelerating. now if i took of down wind which i do often the engine will still unload the same when i make the turn upwind. Also if you take off and fly sorta level the engine will accel to max rp min the smae amount of time if flying up wind or down wind. now this is also assuming the engine isnt over propped with a square or over square prop where in some cases then engine will load up and lose some rpm or stay the same. but i dont want to get in that one as it will confuse you more on how planes fly.
Also for the PYLON racing the nelsons, jetts and MB usually are not staged till near the end of the first lap (base leg).
AMA # 186123
Hide Signatures
       Post #: 90
RE: o,s, 32 max - 6/18/2012 5:55 PM
Lownverted
Score: 110
Status: offline
quote:
ORIGINAL: airraptor
So if there was no wind, it would never unload?
Hide Signatures
       Post #: 91
RE: o,s, 32 max - 6/18/2012 11:29 PM
speedracerntrixie
Score: 189
Status: offline
quote:
ORIGINAL: airraptor
Ok now that I am able to read this and not laugh. As the airplane gains speed, the prop becomes more efficient and unloads thus bringing the engine into the power band. This is going to happen if the airplane is turned or not. In fact it may happen sooner going strait as a turn is drag. Problem is I am not capable of flying a 150 + MPH airplane 250 yards away. Are you?
Hide Signatures
       Post #: 92
RE: o,s, 32 max - 6/19/2012 1:48 AM
combatpigg
Score: 376
Status: offline
quote:
ORIGINAL: speedracerntrixie
The planes in question that would wait for the first turn before hitting the pipe always did so right after the turn was complete...regardless of when I decided to turn.
Why would Wavoscope consistently read the upwind frequency [rpm] low..? My recorder is always pointed in the same direction regardless of wind. Both directions of the pass are close to the same distance from the recorder. If the discrepency is small [like a few hundred rpm] I wouldn't try to explain it. In the case of the 2 passes I showed earlier the discrepency is too large to ignore.
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 93
RE: o,s, 32 max - 6/19/2012 2:43 AM
iron eagel
Score: 118
Status: offline
If the plane was going away from you an the microphone while going upwind you would be getting a Doppler shift that is lowering the frequency that you hear. That may possibly explain it, this is just a guess on my part...
from the Wave0Scope manual;
The Doppler effect is caused by the finite speed of sound in the air. If an acoustic source moves trough the air, then in front of it the acoustic waves are compressed, which leads to a higher sound - behind the acoustic source the
waves are stretched, what results in a lower sound frequency
Hide Signatures
       Post #: 94
RE: o,s, 32 max - 6/19/2012 3:19 AM
airraptor
Score: 130
Status: offline
PIG takeoff down wind and then turn upwind the and the engine would still come on the pipe. The turn is adding "G's" the plane and fuel systems so maybe that strain on the fuel draw leaned the engine just enough so that it got on the pipe as you turned. I bet it would do the same taking off down wind and you turn upwind or even pulled up in a climb. You just wont give up huh lol
AMA # 186123
Hide Signatures
       Post #: 95
RE: o,s, 32 max - 6/19/2012 5:28 AM
combatpigg
Score: 376
Status: offline
I just got done reading from a couple of those "quick fact" websites that high pitched sound is prone to being altered with air movement. So the amount of shift might not be effected as much but the frequency can be.
At any rate, Wavoscope does an excellent job of exposing the liars...lol.
Hide Signatures
(in reply to iron eagel)
       Post #: 96
RE: o,s, 32 max - 6/19/2012 5:51 AM
iron eagel
Score: 118
Status: offline
quote:
ORIGINAL: airraptor
The turn is adding ''G's'' the plane and fuel systems so maybe that strain on the fuel draw leaned the engine just enough so that it got on the pipe as you turned. I bet it would do the same taking off down wind and you turn upwind or even pulled up in a climb.
Just like what happens with the control line "stunt" planes?
They don't lean out and come on the pipe until they pull G's when they are doing maneuvers.
Hide Signatures
       Post #: 97
RE: o,s, 32 max - 6/19/2012 6:00 AM
iron eagel
Score: 118
Status: offline
I just got done reading from a couple of those ''quick fact'' websites that high pitched sound is prone to being altered with air movement. So the amount of shift might not be effected as much but the frequency can be.
Exactly... The shift will remain pretty close but the actual frequency can be altered significantly from what the source produced.
Kinda spooky, but not as spooky as quantum entanglement.
Hide Signatures
       Post #: 98
RE: o,s, 32 max - 6/19/2012 12:47 PM
Lownverted
Score: 110
Status: offline
Once again it has nothing to do with wind. Wavoscope reads the upwind passes as slower because it reads GROUND speed, the speed of the airplane relative to the microphone, not what the airplane is doing relative to the surrounding air mass which would be airspeed. That's why you need to average an up and downwind pass to eliminate the false readings due to wind.
Is this really that hard to understand?
Hide Signatures
       Post #: 99
RE: o,s, 32 max - 6/19/2012 4:16 PM
combatpigg
Score: 376
Status: offline
You're talking about air speed and I'm talking about upwind rpm readings that are being recorded lower than what the true rpm [sound frequency] is.
For this to happen, the wind must have an effect on the sound waves.
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
