engine out on twin    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> engine out on twin
Page: [1]
Login
engine out on twin - 6/11/2012 10:43 PM
halflight
Score: 100
Last Login: 4/5/2013
Status: offline
please settle a debate..let's say the left engine dies..will the right engine which is still running pull to the right or left
Hide Signatures
       Post #: 1
RE: engine out on twin - 6/11/2012 10:54 PM
mboland
Score: 100
Last Login: 5/13/2013
Status: offline
Just think of all that drag on the dead motor side, and all the thrust on the other side.
That's why you don't turn into the dead motor, cause that's where the plane is wanting to go anyway.
And it better if the right motor dies that the left, just to add fuel to your debate.
_____________________________
It''s the quality of life that counts, not the quantity.
Hide Signatures
(in reply to halflight)
       Post #: 2
RE: engine out on twin - 6/11/2012 11:52 PM
91zulu
Score: 130
Last Login: 5/25/2013
Status: offline
Left..
91-Zulu
Hide Signatures
(in reply to mboland)
       Post #: 3
RE: engine out on twin - 6/12/2012 1:25 AM
dasintex
Score: 126
Status: offline
I agree, if the Left Engine goes out, the plane will pull to the Left; I think of it like a tracked vehicle, if the left track is neutral and the right track is pulling, the tank or bulldozer will pull to the Left; I have a twin and the Left Engine has gone out, and to keep it flying straight, you have to use right rudder, making left turns is easy, just let the rudder go to neutral and the plane will turn to the left
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
(in reply to 91zulu)
       Post #: 4
RE: engine out on twin - 6/12/2012 4:40 AM
Chuck54sd
Score: 100
Status: offline
Turn into the good engine..... Luke.... don't go to the dark side.
-Chuck
Hide Signatures
(in reply to dasintex)
       Post #: 5
RE: engine out on twin - 6/12/2012 5:45 AM
JohnBuckner
Score: 342
Last Login: 5/26/2013
Status: online
Left of course and the required corrective action among others is right rudder and not right aileron.
The old full scale training phrase to indentify just remember dead foot - dead engine. Of course with our Rc aircraft we don't have the that luxury.
John
"Keep your controllines tight"
Hide Signatures
(in reply to Chuck54sd)
       Post #: 6
RE: engine out on twin - 6/18/2012 6:16 PM
aerowoof
Score: 171
Last Login: 4/1/2013
Status: offline
not only will it turn to the left the wing tip with the dead engine will drop and the wing tip with the good engine will rise.
Hide Signatures
(in reply to JohnBuckner)
       Post #: 7
RE: engine out on twin - 6/20/2012 12:25 AM
maxpower1954
Score: 100
Last Login: 5/23/2013
Status: offline
And of course, it's also a function of speed. An engine failure in normal cruise doesn't lead to an immediate yaw (at least in most of them!) As the speed decays, the turn becomes more pronounced.
Russ Farris
Hide Signatures
(in reply to aerowoof)
       Post #: 8
RE: engine out on twin - 6/24/2012 6:05 AM
Thisstrangeengine
Score: 100
Last Login: 12/26/2012
Status: offline
The plane will go left. Apply right rudder and dont kill the other engine. Those still props will add alot of drag and slow you down quickly. I know this from experience! I made that mistake with my Cessna Bobcat almost 20 years ago.
Nosen Cessna 310 Club Member #54
Hide Signatures
(in reply to maxpower1954)
       Post #: 9
RE: engine out on twin - 6/24/2012 6:24 AM
mboland
Score: 100
Status: offline
I don't want to sound like I'm nit picking, but strictly speaking, an idling prop will produce more drag than the stationary ones.
Strange but true, I had to read the maths on it before I would believe it.
Hide Signatures
(in reply to Thisstrangeengine)
       Post #: 10
RE: engine out on twin - 6/27/2012 10:29 PM
Rocketman_
Score: 110
Status: offline
quote:
ORIGINAL: mboland
... strictly speaking, an idling prop will produce more drag than the stationary ones.
I can agree with that. I'd been flying a lightly loaded OS 1.60 powered 3D model for several years before the day the pressure pulse line slipped off the fuel pump and turned it into a glider. The engine went dead but the model didn't appear to be losing much altitude so I just kept flying it all over the place until it looked like it was time to make a landing approach.
Well, it wasn't time yet and the model flew right past me about waist high at a speed well above my normal landing speed when the engine is idling. Frantically I got the wheels down on the runway but it still rolled off the end of the runway and flipped in the tall grass. Yep, I can agree with that quote above.
NORTHEAST R/C MODEL CLUB
http://www.nrcmc.org/
Hide Signatures
       Post #: 11
RE: engine out on twin - 7/19/2012 8:15 AM
dkm
Score: 100
Last Login: 5/21/2013
Status: offline
On a twin, if the left engine dies the centre of thurst moves towards the right engine. The centre of drag will move slightly left giving a resultant left yaw and left roll.
Unlike being in the cockpit an R/C pilot will not feel the yaw so "dead foot dead engine" does not apply. But an uncommanded roll (hopefully with engine noise loss)
will be the give away for the failure.
So as the model rolls, first react to the roll with right aileron, reconigise the engine failure (sound,performance etc,), put full right rudder (the direction of the aileron input).
Lock the right rudder input and ease off the aileron to neutral.
Balance rudder input to throttle, power on-rudder on, power off-rudder off.
Do not throttle back and keep the nose level to maintain speed. Speed is your friend, never fly a twin slow or use high nose attitudes at low speed.
Hide Signatures
(in reply to Rocketman_)
       Post #: 12
RE: engine out on twin - 7/29/2012 4:20 AM
Pilot P51
Score: 100
Status: offline
I am real pilot and I also have a real twin.
There are a number of things the pilot has to do when flying a scale twin verses flying a R/C plane when it comes to flying with one engine. The main thing is to get the plane on the ground in one piece.
Another helpful hint in flying an R/C twin, when you do lose the engine try to make your turns in the same direction the engine is running to get back to the runway, if possible. The plane will want to yaw or turn into the engine that has stopped working. Turning in the opposite direction you have a less chance of spinning the plane into the ground when making the turns.
I have seen this happen more than once. Were a pilot will recover from a lost engine but as soon as he starts his turn back to the runway he turns the plane and into the ground it goes.
Hope this helps.
Walts
Hide Signatures
(in reply to dkm)
       Post #: 13
RE: engine out on twin - 10/24/2012 2:44 AM
valleyk
Score: 101
Last Login: 5/14/2013
Status: offline
I've seen alot of twins spin to the ground on one engine. The problem is its hard to know which engine is out or if an engine is out. Would be nice if someone could come up with a sensor on each engine that could tell the transmitter  to sound off a beep and flashing light telling the pilot what side is out. I think for very expensive twins this would be ideal.
Hide Signatures
(in reply to Pilot P51)
       Post #: 14
RE: engine out on twin - 10/24/2012 4:00 AM
91zulu
Score: 130
Status: offline
We go by feel. The plane will yaw as soon as an engine goes out. Now how much of a yaw depends on how far apart the engines are. The further apart the more violent of a yaw you will get. That is why they saw if you going to fly twins you better be a rudder pilot, because when an engine go out and you feel a twitch your rudder finger has to be instantaneous or else you in trouble. It has to be a reflex action, not something you have to think about.
91-Zulu
Hide Signatures
(in reply to valleyk)
       Post #: 15
RE: engine out on twin - 10/24/2012 6:26 AM
Roary m
Score: 107
Status: offline
An engine out is something like getting a flat tire on your car while you are driving. It is a matter of compensating and taking corrective action.
Hide Signatures
       Post #: 16
RE: engine out on twin - 10/27/2012 6:18 AM
invertmast
Score: 193
Status: offline
In single engine ops with a multi engine airplane, airspeed is king! Without it, its going to spin in. If your in level cruise, add the rudder input and power quickly (not instantly, quickly, its more important to be accurate and fast, that it is to be instant and wrong!). If you are in a climb, quickly add the correct rudder input, get the gear up and lower your rate of climb (remember, airspeed is KING!). If you ever find yourself in a situation where you have full rudder input and the airsplans is yawing in the opposite direction, Immediately lower the nose and reduce the power (you are at at under the minimum controllabable single engine airspeed), to increase your airspeed, slowly add power as the airspeed increases and then start a slow climb again.
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to Roary m)
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
