Is this a good field box set?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Is this a good field box set?
Page: [1] 2   next >   >>
Login
Is this a good field box set? - 6/12/2012 7:42 PM
DMalyuta
Score: 100
Last Login: 7/2/2012
Status: offline
http://www.ebay.ch/itm/NEW-Hobbico-Ultra-Tote-Field-Box-Complete-Combo-HCAP5105-NIB-/290683876900?pt=Radio_Control_Parts_Accessories&hash=item43ae1bf624#ht_885wt_1130
Please give comments on the parts that this set has, and whether there are any major ones missing (apart from screwdrivers, etc. which I have)
Daniel.
_____________________________
Thumbs up to those fighting gravity!
Hide Signatures
       Post #: 1
RE: Is this a good field box set? - 6/12/2012 8:48 PM
huck1199
Score: 115
Last Login: 5/18/2013
Status: offline
Most guys at our field use a hand held glow ignitor,  hand crank fuel pump and lipo powered starter motors.  We got tired of carying a heavy  tote box.  We carry spare parts in a plastic tackle box.  Tote boxes with a heavy 12 volt lead acid battery are on the way out.
Hide Signatures
(in reply to DMalyuta)
       Post #: 2
RE: Is this a good field box set? - 6/12/2012 9:14 PM
Gray Beard
Score: 314
Last Login: 5/21/2013
Status: offline
It's hard for those of us in the states to really say if something like that is any good, we don't know what you can and can't get. You see very few boxes like that at the field these days here. It's too easy for us to convert our starters to 18 volts and be power panel free, almost no one uses the panel these days. As huck said, you can use as hand pump for the fuel, a glow igniter for the plug and a battery installed on your starter. How you carry your tools and STUFF is up to you.
I carry way too much stuff to the field but guess who the guys come to when they need something.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to huck1199)
       Post #: 3
RE: Is this a good field box set? - 6/12/2012 9:26 PM
fledermaus
Score: 105
Last Login: 3/4/2013
Status: offline
Speaking of LiPo powered engine starters - I have a 12V Torquemaster 90 starter that I have been running off a Pb/acid battery and I'd like to make an integrated battery pack for it. It only has to start engines in the 0.35 - 0.91 size range, no really big monsters.
Question: If I run it on a 4S (14.8 V) pack it should be ok, but what battery capacity should I aim for?
Hide Signatures
(in reply to Gray Beard)
       Post #: 4
RE: Is this a good field box set? - 6/12/2012 9:36 PM
huck1199
Score: 115
Status: offline
4s will be fine. I run 2 parallel 3s 2200 on my acient Royal starter.
Hide Signatures
(in reply to fledermaus)
       Post #: 5
RE: Is this a good field box set? - 6/12/2012 9:47 PM
DMalyuta
Score: 100
Status: offline
 Gray Beard, you're right on the money- I could get a lipo-powered starter, but the thing would cost me double what this entire set off of ebay costs. Here is Switzerland, what you guys get for x dollars we get for 3x dollars- and with a much more limited choice. Searching for stuff you need when you have only one medium-sized local hobby store becomes an art. I am trule jealous of US guys because of this- you have everything!
Daniel.
P.S. Just how dangerous are lead acid batteries and what precautions should I take? I've done a fair bit of environmental chesmitry for exams recently, and it had scary stuff about lead and its health effects- going from stomach burns to cancer.
Hide Signatures
       Post #: 6
RE: Is this a good field box set? - 6/12/2012 10:03 PM
huck1199
Score: 115
Status: offline
Check out HobbyKing.com for your lipos, use the German warehouse (DE).
Hide Signatures
       Post #: 7
RE: Is this a good field box set? - 6/12/2012 10:51 PM
DMalyuta
Score: 100
Status: offline
AHa! Thanks for pointing out this site, huck! I might be getting some other stuff off of it, but can't find any tote box or starter that works on lipos, etc.
Daniel.
Hide Signatures
       Post #: 8
RE: Is this a good field box set? - 6/12/2012 11:04 PM
KitBuilder
Score: 131
Status: offline
I;m going to move to a lipo for my starter. .you wont find a starter that works with lipos out of the box in terms of the connectors. You'll hve to put compatible ends on each side (battery and starter)
My gel cel recenlty died and im going to switch to a hand pump for fuel... keep my handheld glow starter and run my starter off a lipo. Wont need the power panel at that point either.
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
       Post #: 9
RE: Is this a good field box set? - 6/13/2012 12:28 AM
Gray Beard
Score: 314
Status: offline
Photos first
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to KitBuilder)
       Post #: 10
RE: Is this a good field box set? - 6/13/2012 12:40 AM
Gray Beard
Score: 314
Status: offline
All you need, need is a big word though. A starter, a glow driver and a can of fuel. However, this box is what I haul with me to the field. It's a rolling tool box and was needed for different fields I have flown at, not at the dry lake bed I fly on today. Everything is in that box and it weighs a ton!! I used to fly big events and you had to have a box full of stuff or be able to park close.
The needed items, all three of them. John Buckner came up with a battery pack from a place here called Harbor Freight for the starter. It converts the starter to an 18 volt and my starter now rolls over the 30cc DLE engines, {some times} the battery is a Nicad pack and cost between 10 and 12 dollars, the charger is a fast charger and costs 5 dollars. Pack number is 67029 and the charger number is 67031. So, you can see it doesn't cost a bunch in the states, the glow driver with a charger and battery is about $20.00 and I gave $10.00 for the hand pump on the free can.
Buying the complete package may be your best bet, all it requires are the big three items. I do use the power panel in the winter when my engines are a b it harder to start so it could be a good thing for you. It puts out more power then the little glow stick but requires a 12 volt battery. I see one is included in that box but they need replacing about every year or so.
Gene
WOW, posted two photos and a quick post without getting a time out or error 500!!!!!!!!!!!!
Hide Signatures
       Post #: 11
RE: Is this a good field box set? - 6/13/2012 1:12 AM
llindsey1965
Score: 111
Last Login: 5/20/2013
Status: offline
dont need the power box as i use gas engines  have a hand pump and carry my spare parts in a plastic tote box  , i use to use hand glow packs no need for power panel and always started engines with a chicken stick or battery starter remote with its own battery  that way you dont have to tug and tote those heavy flight boxes    anyway just my 2 c worth
Hide Signatures
       Post #: 12
RE: Is this a good field box set? - 6/13/2012 2:34 AM
vicman
Score: 189
Status: offline
Once you put 4s on a starter you won't think about anything else! One of the best things I ever did.
I also split a good cell of a semi puffed pack and made a lipo igniter...Wow what a great thing! I charge both about 3 times a year and they always work.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
(in reply to llindsey1965)
       Post #: 13
RE: Is this a good field box set? - 6/13/2012 2:52 AM
Gray Beard
Score: 314
Status: offline
All my glow engines are 4 strokes except one. Most of them will hand start really easily during the summer but I still like a starter. Especially for that day they decide not to start so easily! It happens. I also fly with gas and most the time they too are easy to hand start. I rebuilt a couple of carbs this last year and they didn't want to draw gas right away so I borrowed a converted drill and they lit right up, the starter was a huge help!!
In the cold temps of Sweden I'm thinking a hot glow driver and an electric starter are something I would want to have in my flight box. I have a fuel can and an electric pump in my flight box and love the electric pump. Iuse the bigger four strokes and have big fuel tanks, I don't like hand pumping my fuel. But I have the hand crank pump too. Try not to use it but I have it.
Hide Signatures
(in reply to vicman)
       Post #: 14
RE: Is this a good field box set? - 6/13/2012 2:05 PM
llindsey1965
Score: 111
Status: offline
GB i dont like using electric pumps on my gas , just my choice  , i use hand crank pump  i too have large capacity tanks for my  50 cc 80cc and 150cc engines ,  and electric starters i dont like cause if you hydraulic you bend a rod , like i said it is my preference  , i bent a couple of rods when i flew nitro  , went to gas  1) fuel is cheaper    2)  easy to crank   3)  readily aviable power  4) less of a mess to clean up  5)  more power  6) even and smooth power transitions  7)  plugs last longer than glow plugs  8) less maintianance  9)  great deep sounds   10)  good idle
Hide Signatures
       Post #: 15
RE: Is this a good field box set? - 6/13/2012 2:39 PM
fledermaus
Score: 105
Status: offline
quote:
ORIGINAL: DMalyuta
Don't worry about the contents of the lead acid battery UNLESS you foolishly try to cut it open. The contents won't jump out of the casing of the battery and bite you.
Lead is indeed toxic, but it has to get inside you in order to affect you. If you don't expose yourself (or others), it won't hurt you (or others). You can handle lead metal without any hazard, but you have to avoid ingesting it - for example, indoor gun ranges often have microscopic lead dust in the air that people can inhale. That's not good. BUT: your starter battery should not produce any lead dust.
The acid gel in the battery can indeed cause skin burns, but again only if it contacts your skin. Don't break open the battery.
And, when the battery is dead, take it to someplace that can recover the lead and dispose of it properly, don't just throw it in the trash.
Hide Signatures
       Post #: 16
RE: Is this a good field box set? - 6/13/2012 2:54 PM
countilaw
Score: 219
Status: offline
quote:
ORIGINAL: DMalyuta
Daniel.
Before running to this site and spending a lot of  money,     do  your research.       There are  thousands of complaints against them.
Check    RC  truth  dot com    in the     Hobby King    section.      or   Check the vender section of the other site.
Frank
It''s a hobby, not a job.
Hide Signatures
       Post #: 17
RE: Is this a good field box set? - 6/13/2012 3:31 PM
rowdog_14
Score: 107
Last Login: 4/29/2013
Status: offline
I love wood flight boxes. It does get heavy after you add a gallon of fuel and the big battery for the panel, other than that I have everything I need in that flight box to do any repairs at the field and not have to go home. I will post a picture of mine when I get home.
THE T.R.U.T.H
Hide Signatures
(in reply to countilaw)
       Post #: 18
RE: Is this a good field box set? - 6/13/2012 3:42 PM
OliverJacob
Score: 110
Status: offline
I think that is a good Starter setup. Now it depends on what engines you want to use in the future and you will get a different box.
The lead acid battery here is sealed and safe to use. The acid is more of a health risk, but it is contained and you had to use excessive force to get the battery to break open.
I have a huge box on wheels with a small car battery, this provides enough amps to run the starter for the bigger gassers and I charge in only 2-3 times a year.
It also hold all kind of tools and spare parts, since the field is 40 minutes away I don't want to run home to get some screw, servo, battery if needed.
Every rc pilot I've seen has a field setup, you'll get lots of different opinions here.
I have bought from this seller on e-Bay and would do it again.
Hide Signatures
       Post #: 19
RE: Is this a good field box set? - 6/13/2012 4:32 PM
Twin_Flyer
Score: 108
Status: offline
If your a member of a local club, ask around. You will probably be able to find some of that stuff second hand cheap.
I just did built my own self-powered starter motor using an 18volt battery from harbor Fright. Works GREAT and as i dont fly electric, i dont have a lipo charger.
A simple plastic tool box from home Depot or the like will serve as a cheap flight box, or even a small crate lined with heavy cardboard or wood.
Bill S.
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
(in reply to OliverJacob)
       Post #: 20
RE: Is this a good field box set? - 6/13/2012 5:27 PM
jessiej
Score: 144
Status: offline
[/quote]
My cars, motorcycles, boats, lawn mowers, farm equipment and model starters have used lead-acid batteries all my life and I have never had any accident with them. With a bit of effort, however it would be possible to get an acid burn or even a hydrogen explosion.
jess
Hide Signatures
       Post #: 21
RE: Is this a good field box set? - 6/13/2012 5:45 PM
Twin_Flyer
Score: 108
Status: offline
old technology today.
I would use any 12 volt gel cell over the old style lead acid because the gel cell can be mounted upside down and not leak.
Also, it will last a lot longer, and its not that much more expensive.
Bill S.
Hide Signatures
(in reply to jessiej)
       Post #: 22
RE: Is this a good field box set? - 6/13/2012 9:07 PM
flycatch
Score: 118
Last Login: 5/17/2013
Status: offline
Excellent choice. Don't listen to all the BS being posted.
Hide Signatures
       Post #: 23
RE: Is this a good field box set? - 6/14/2012 12:55 AM
Gray Beard
Score: 314
Status: offline
quote:
ORIGINAL: llindsey1965
We are speaking to the OP and he is using a glow engine and cares less about gassers, I too hand crank my gas but the OP may want to know about electric pumps also. I wouldn't recomend one to him due to price and if you are only flying a couple of normal glow planes I find hand cranks just fine. {And Cheap}
I fly with a lot of people and most use an electric starter, to date I haven't seen an engine broken by one, Not in a lot of years anyway. After filling a tank the normal thing to do is hand flip the prop to make sure it isn't flooded. When the weather gets cold like, I don't know, maybe Switzerland, an electric stater could make starting an engine a big bunch easier? I know when it is in the high 20s and low 30s in Vegas my engines don't like to hand start very well. At 100+ therre is no problem.
A nice flight box like that with the items require could be a very nice thing to have?
I would do as Frank mentioned and do a back ground check on this site offering the box just to be safe.
Hide Signatures
       Post #: 24
RE: Is this a good field box set? - 6/14/2012 1:42 AM
Live Wire
Score: 6329
Status: offline
quote:
ORIGINAL: jessiej
jess
Open the hood of your car, truck or check you motorcycle They all hae one
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
