Why not transport your fully assembled aircraft to the field?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Why not transport your fully assembled aircraft to the field?
Page: [1] 2 3 4 5   next >   >>
Login
Why not transport your fully assembled aircraft to the ... - 6/13/2012 4:28 PM
ForcesR
Score: 105
Last Login: 2/22/2013
Status: offline
I finally solved the problem of transporting, assembling and disassembling an aircraft at the flying field. This method also gets a lot of thumbs up from passerby’s while on the highway
Roger
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ForcesR -- 6/14/2012 6:23 PM >
Hide Signatures
       Post #: 1
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 4:54 PM
oriole
Score: 100
Last Login: 5/25/2013
Status: offline
Okay, I'll bite. What keeps the Plane and Stand from flying out of the back of the truck at 60 MPH?
Oriole
Hide Signatures
(in reply to ForcesR)
       Post #: 2
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 4:57 PM
All Day Dan
Score: 151
Status: offline
Roger, that's not a good idea. You are putting a lot of stress on all of your surfaces. Dan.
_____________________________
Dan
Hide Signatures
       Post #: 3
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 6:17 PM
ForcesR
Score: 105
Status: offline
The cradle is held in place in the truck bed by four lashings on each of the four corners of the cradle, the lashings are connected to the tie down points in the truck bed. The cradle also has forty pounds of weight attached to it for extra security (flat cinder blocks).
The plane is held in the cradle by two lengths of ½” hardwood dowels covered with ¼” thick foam. Each dowel is designed to fit into a clevis at each end of the cradle. The two dowels straddle the top of wing and this is what actually keeps the plane held in the cradle. The cradle is padded and is designed to allow the plane a slight amount of wing roll movement; ½” up and ½” down. The Velcro straps seen in the photos keep the two dowels from popping out of the clevises during wing roll movement.
Stress on the flight control surfaces is not a concern due to no power being applied to the flight control servos during transport; therefore the flight control surfaces are free to move up or down if subjected to air turbulence over their surfaces. Flight control surfaces are subjected to much more stress during actual flying due to the servo’s deflecting the flight controls in the air stream.
Roger
Hide Signatures
(in reply to All Day Dan)
       Post #: 4
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 6:26 PM
DiscoWings
Score: 102
Status: offline
unsafe....
"Hi,You are 100% correct but are also 100% wrong... "
- rcflip
Hide Signatures
       Post #: 5
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 6:39 PM
ForcesR
Score: 105
Status: offline
quote:
ORIGINAL: DiscoWings
unsafe....
Unsafe, then explain and enlighten me as to why you think this transportation system is unsafe?
Hide Signatures
(in reply to DiscoWings)
       Post #: 6
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 8:33 PM
BobH
Score: 116
Status: offline
Doesn't appear unsafe nor does it appear to pose a danger to your plane. Use it.
BobH.
Hide Signatures
       Post #: 7
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 8:53 PM
luckyb
Score: 100
Last Login: 5/16/2013
Status: offline
Saw an elderly gentleman transport a giant scale P-38 on his van. A red one called " Yippee". The same setup. We helped him clear it off the center lane of I 95. After that he just needed a small box for it. Saw another guy strip every servo in the plane from the same thing. Not a particularly good idea. Just my opinion............Doug
" We didn''t come here to drop paper"......Buzz Rickson
Hide Signatures
(in reply to BobH)
       Post #: 8
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 9:42 PM
Meschmidt
Score: 100
Last Login: 5/23/2013
Status: offline
Unsafe because of all the passerby's oogling over it and causing wrecks. Ha!
Hide Signatures
(in reply to luckyb)
       Post #: 9
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 10:17 PM
3136
Score: 135
Last Login: 5/21/2013
Status: offline
There wouldn't be much air flowing over it, it's not directly in the path of travel (ie behind the cab)
It does look like your wings stick out a little though, that would be my only concern.
I'm just finishing a 1/4 Se5a and planned to transport it in my trailer on an angle, it will fit.
But thinking about it, I like to check all the servos, fuel system, batteries and pull cables before each flight so it will probably still be assembled at the field.
You could always teach a squirrel how to fly and get him to transport it there for you
regards Mark
Hide Signatures
(in reply to Meschmidt)
       Post #: 10
RE: Why not transport your fully assembled aircraft to... - 6/13/2012 11:33 PM
ticketec
Score: 105
Last Login: 5/24/2013
Status: offline
This is how I have to transport my model to the field because it just does not fit in the car.
The model flies faster than the 80 kmh that I get to going to the model field, The control surfaces are neutral so there is minimum load applied to the unpowered servos.... what is happening during the trasportation of the model that would be any different to the flight loads?
The only drama I could see on ForcesR's setup is that the outboard sections of the wing are in the airstream and therefore producing lift, which will be adding loads to the wing mid and root sections.... other than that, Can't see all fuss???
Dave
Click for fullsize
Hide Signatures
(in reply to 3136)
       Post #: 11
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 12:06 AM
SprinklerTech
Score: 112
Status: offline
Ha, that's great Dave.
Roger,
The only concerns I would have are the wings as things get kicked up from the road. My windshield has some comments on that one.
The other thing is people following me to my house to get a 5 finger discount later when I'm at work.
Either way, I wouldn't tell you you're wrong, do what ya gotta do!
Tim
Hide Signatures
(in reply to ticketec)
       Post #: 12
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 12:15 AM
Live Wire
Score: 6329
Last Login: 5/26/2013
Status: online
I do not recommend puting a plane in the back of a truck, but if it won't stand the stress of low speed you better leave it on the ground
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
(in reply to SprinklerTech)
       Post #: 13
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 12:58 AM
lopflyers
Score: 140
Status: online
I like both ways, the only thing I see wrong is that to avoid the 5 mins that takes to put the wings together at the field, you are only bringing ONE.
I always bring at least two if not three planes in my RAM pick up truck
Keep your wings level
Club Saito Member #693
Hide Signatures
(in reply to Live Wire)
       Post #: 14
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 1:16 AM
mistermnkim
Score: 100
Status: offline
This is what I use
Click for fullsize
club saito #625 CG Ultimate brotherhood #19 SPITFIRE brotherhood #91
Hide Signatures
(in reply to lopflyers)
       Post #: 15
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 1:42 AM
thepamster
Score: 115
Status: offline
This probably would not happen in the friendly nation of Canada but here I would be concerned of teenagers deciding to throw a beer bottle at your plane while driving down the road.
I also don't want anyone to know what I am transporting to and from the field.
The Pamster
AMA 202345
Hide Signatures
(in reply to mistermnkim)
       Post #: 16
oliveDrab
Score: 105
Status: offline
Can't tell what that is? A trailer? A box on the bed of a pickup?
I built a 4-Star 120 with an 81" wingspan. I figured the wing would fit katty-korner in the back of my Nissan Frontier (72" long bed with a camper shell on top). WRONG!!! Doesn't fit! The only way it fits is to stick the last 6 inches out the back with the camper shell door partially open.
I know, I know - shoulda built the wing in two halves.
"No, no, no........you misunderstand. We make nothing but model airplanes"
Hide Signatures
       Post #: 17
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 1:45 AM
Iflyglow
Score: 122
Status: offline
They maybe are not fully assembled, but they are transported safely, and the trailer cost me under $500 total to build (Including AGM Deep Cycle Battery, and I can transport two IMAA Big Birds. I also still get 30mpg pulling it with a Corolla. The trailer with planes weighs 450 lbs total.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 18
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 2:12 AM
RCER88
Score: 124
Last Login: 4/15/2013
Status: offline
Depending on the wingspan. You may need an oversize load sign and yellow flashing lights. "over size in most states is anything over ten foot wide or 120 inches." You may even require permits. If the right D.O.T. Officer sees you he could pull you over and give you a ticket. Oversize fines are steep. If you are under 102 inches you are fine. No permits, lights or signs required.
I will just continue to carry mine in pieces and assemble at the field.
Hide Signatures
(in reply to Iflyglow)
       Post #: 19
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 2:19 AM
pmerritt
Score: 167
Status: offline
DUMB DUMB DUMB.  The turbulence from the air flow off the car body puts unusual stress on this airframe not to mention every trip to the field is wind stress that we know will eventually cause failure.  If you don't have the vehicle to transport, don't build and fly larger scale planes that need the appropriate vehicle.  Disassemble if needed.  Fly smaller planes that are safe to transport.  NOT TO MENTION, anythiing that flies off this plane, or the plane itself could cause someone behind you to lose control, panic, or make a sudden change in lanes. And I can guaranty  you WILL be responsible for any and ALL damages or have to live with someone getting hurt or killed dodging airplane parts.
There have been people killed from dodging couch cushions, mattresses, aluminum ladders, plastic buckets that fly off the back of vehicles.  Can you live with that?
  Thumbs up from passing motorists is false accolade!  THINK.  BE SMART!  It's not worth a thumbs up to transport a balsa framework like this.  It's a lose/lose proposition!
Intelligence is similar to a dress code. Dont attend a black tie affair wearing cutoffs and a tank top. Know your facts
Hide Signatures
       Post #: 20
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 3:04 AM
radfordc
Score: 100
Status: offline
Wow, the net nannies are all over this one.
Hide Signatures
(in reply to pmerritt)
       Post #: 21
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 3:24 AM
pkoury
Score: 110
Status: offline
Anybody remember the original Byron Pitts? One of the options was a rack you mounted on the truck of your car to carry the assembled biplane to the field.
Hide Signatures
(in reply to radfordc)
       Post #: 22
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 3:25 AM
G.Barber
Score: 131
Status: offline
I also built a trailer for hauling my planes to the field. Final cost (including $109.00 for a permanent license) was just under $800.00
The trailer frame was built from 2" square tubing, and has a final dimension of 4'x8'. It is 43" tall inside.
I've been thinking about doing an article on the trailer - anyone interested? I took pictures as I built it...
Click for fullsize
Click for fullsize
Ultra Sport Brother #68
Cub Brother #62
Even the smallest good deed is better than the greatest intention.
Hide Signatures
       Post #: 23
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 3:35 AM
glazier808
Score: 291
Status: online
a buddy at our field used to haul his big spit that way, swore it was full proof.
That was until one day he showed up at the field, and got out of his truck cussing up a storm...he then pull what was left of the wings out of the cab(he had stopped and picked up the two pieces....welll 2 big pieces anyways). He then pulled the fuse, (which at this point looked like a limp noodle) off the mount.
He said everything was fine, then it just started wobbling in its mount and then kinda exploded out of the back of his truck before he could even get it stopped...
good thing was, that the wing did'nt really hurt the car behind him that it hit(the wing). (and they didnt crash trying to avoid it.)
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to G.Barber)
       Post #: 24
RE: Why not transport your fully assembled aircraft to... - 6/14/2012 3:45 AM
daisy shoot
Score: 105
Last Login: 5/13/2013
Status: offline
quote:
ORIGINAL: radfordc
Absolutly!
Have any of you even been in the back of a truck while it barrels down the road?
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
