RE: Why not transport your fully assembled aircraft to the field?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Why not transport your fully assembled aircraft to the field?
Page: <<   < prev  1 2 3 4 [5]
Login
RE: Why not transport your fully assembled aircraft to ... - 6/20/2012 3:02 PM
da Rock
Score: 265
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: 1wolf
I'm all for it!
Now that is a decent collection of bombers. You've also got the strongest mosquito netting I've ever seen.
It really does look like your trailers might be more than the average pickup truck can handle.
Awesome collection for sure.........
_____________________________
Good flying wit ya today
Hide Signatures
(in reply to 1wolf)
       Post #: 101
RE: Why not transport your fully assembled aircraft to ... - 6/20/2012 7:03 PM
Me410
Score: 100
Last Login: 5/15/2013
Status: offline
I have transported my 60" and 70" warbirds assembled  with the retracts up. The plane sits in a  2 x 4  cradle I built and the  plane is held to the cradle with bungy cords.  I do travel 60MPH for about 10 miles. I have never had a problem , but now I am thinking , just how much turbulence is there when the plane is low  in the  box.  My new 2011 1/2 Ton Chev truck has a deeper box than my old chev.
The wieght of the cradle seems to secure the plane ok.  But again, I don't  know how strong the forces are on the floor of the box?
I know, I know,  buy a canopy or box cover,  and I think I will soon.
But my question is,  how bad can the air flow be on the  truck box floor?
Tom
Hide Signatures
(in reply to da Rock)
       Post #: 102
RE: Why not transport your fully assembled aircraft to ... - 6/20/2012 9:09 PM
vertical grimmace
Score: 154
Last Login: 5/26/2013
Status: offline
I do it all the time. I just throw my plane in the back of my pick up. I do have a camper shell on it though. Great investment. I can fit a 1/4 scale DR1 tripe in there.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to Me410)
       Post #: 103
RE: Why not transport your fully assembled aircraft to ... - 6/21/2012 12:12 AM
Me410
Score: 100
Status: offline
Vertical:
By camper shell, do you mean canopy?  I suspect that's what you mean.
I have a full fiberglass canopy from my old 1991 chev pick up, but it does not fit my new 2011 Chev. Both short boxes, but out by a couple of inches.
I don't like loading planes with a canopy anyway, too much crawling around.
But i think I have found just the thing.  It's a soft folding tonnue cover that seals the top of the box,  folds back in three parts. very light but strong, easy to take off, etc.
With  the deep box of the new trucks most of my planes will sit below the rails.
See  " Trifecta by Extang"  or  Torzatop or Tonno pro.
BTY Vertical, saw a pic of your Pica FW190 D with the DLE 20. looks great.  I had one for many years with a OS914S. One of the best flying warbirds i have ever owned.
Tom
Hide Signatures
(in reply to vertical grimmace)
       Post #: 104
RE: Why not transport your fully assembled aircraft to ... - 6/21/2012 3:20 PM
ForcesR
Score: 105
Last Login: 2/22/2013
Status: offline
quote:
ORIGINAL: Me410
Tom
Me410, as long as you do not exceed 105kph, the cradle is secured safely in the truck box and the aircraft is safely attached to the cradle, then you will have no problems with transporting a fully assembled aircraft.
Keep your speed below 105kph; this will ensure you are well below the envelope where wind turbulence in the truck box will not introduce wing or horizontal stab flutter. Flutter is what causes catastrophic internal structural failure of the wing and or horizontal stab.
If you drive at an excessive speed you will enter the envelope where excessive wind turbulence over the cab will drop down onto the wing. The wind turbulence will then travel rearward along the upper surface of the wing until it drops off at the rear of the wing and onto the truck bed floor; there it is redirected forward and upward on to the bottom surface of the wing. With the excessive wind turbulence acting on the upper and lower wing surfaces simultaneously, the wing is forced into a rapid forward and aft twisting motion, known as flutter. This flutter will be heard as a high pitch buzzing sound and will destroy the internal structural support of the wing in a matter of seconds.
I have been transporting fully assembled aircraft in the back of my pickup to and from the flying field for well over a year with no problems. I never exceed 105kph (65mph), and the distance I travel each way to and from the flying field is 48km or 28 miles.
Just about any cargo can be safely transported; if you do your homework first, understand the do and don’ts, and of course mitigate and accept the risks involved.
This will be my final post on this issue. If I would have known what a hornet’s nest I was stirring up, I would never have posted in the first place. Hopefully this thread will now just die and go away!
Roger
Hide Signatures
(in reply to Me410)
       Post #: 105
RE: Why not transport your fully assembled aircraft to ... - 6/21/2012 4:53 PM
carlbecker
Score: 100
Last Login: 4/29/2013
Status: offline
Roger, I don't mind the hornet's nest stirred up. It is much better now that you have given specifics. I just will not do it. You might give someone an even better transport idea!
Hide Signatures
(in reply to ForcesR)
       Post #: 106
RE: Why not transport your fully assembled aircraft to ... - 6/21/2012 6:00 PM
Me410
Score: 100
Status: offline
I agree, this is not a hornets nest, infact  it's good info.
I have heard stories of planes flying out of trucks and off roof racks.
I plan on making improvements with my transportation setup as I think it's marginal and  my planes are getting bigger and more expensive . And I think I have been alittle slack at times.
Cheers
Tom
Hide Signatures
(in reply to carlbecker)
       Post #: 107
RE: Why not transport your fully assembled aircraft to ... - 6/23/2012 1:21 AM
417mack
Score: 100
Last Login: 4/24/2013
Status: offline
 If one is worried about parts flying off or servo damage why not cover the plane with a tarp or blanket removing the stresses of lift and turbulance.
Hide Signatures
(in reply to Me410)
       Post #: 108
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
