Servos for SFHSS    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Futaba Radios Direct support forum >> Servos for SFHSS
Page: [1]
Login
Servos for SFHSS - 6/14/2012 10:07 PM
kgibson4
Score: 100
Last Login: 5/20/2013
Status: offline
I received my new T8J transmitter on Monday.  Now I have heard that SFHSS mode operates only with digital servos.  Is this true?  The manual seems to indicate that the  included receiver can be used with any J-connector equipped servo.
_____________________________
Ultra Sport Brotherhood #131
Hide Signatures
       Post #: 1
RE: Servos for SFHSS - 6/14/2012 10:48 PM
Bax
Score: 169
Last Login: 5/17/2013
Status: offline
You can use ANY servo on the R2008SB receiver. You must use S-Bus servos on the S-Bus, or an S-Bus decoder for non-S-Bus servos on the S-Bus.
Don't know where the idea comes from that only digital servos will work with an SFHSS receiver.
< Message edited by Bax -- 6/15/2012 4:42 PM >
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to kgibson4)
       Post #: 2
RE: Servos for SFHSS - 6/14/2012 11:03 PM
kgibson4
Score: 100
Status: offline
Thanks, Bax
I was really not interested in changing over all my servos in order to use this Tx.
Hide Signatures
(in reply to Bax)
       Post #: 3
RE: Servos for SFHSS - 6/15/2012 2:30 AM
kgibson4
Score: 100
Status: offline
Bax,
Sorry to nitpick here, but after re-reading your post; could I get some assurance that it is safe to use analog servos with the R2008SB receiver in SFHSS mode?
Hide Signatures
(in reply to Bax)
       Post #: 4
RE: Servos for SFHSS - 6/15/2012 4:42 PM
Bax
Score: 169
Status: offline
Can't make it any more clear, but I did an edit of the post.
Hide Signatures
       Post #: 5
RE: Servos for SFHSS - 6/15/2012 6:23 PM
kgibson4
Score: 100
Status: offline
I'm sorry, let me try to make my question more clear and specific.
Can you safely use ANY servo on the R2008SB receiver with the 8J transmitter in either FHSS mode or S-FHSS mode?
Hide Signatures
(in reply to Bax)
       Post #: 6
RE: Servos for SFHSS - 6/15/2012 8:51 PM
Bax
Score: 169
Status: offline
This is being way over thought. You can use ANY regular servo, digital or analog with that receiver. When we say "that receiver", that means receiver. Mode is irrelevant. If we were going to mention a mode, we would have.
The R2008SB receiver operates on FHSS mode when an FHSS transmitter is present, and S-FHSS mode when an S-FHSS transmitter is present. It does not "care" which servos you use. However, you MUST use S-Bus servos on the S-Bus, or an S-Bus decoder when you use other servos.
Again, we don't know where the idea came from that FHSS and SFHSS affected the servos.
Hide Signatures
       Post #: 7
RE: Servos for SFHSS - 6/15/2012 9:13 PM
kgibson4
Score: 100
Status: offline
Thanks for clearing that up.  I will fly tomorrow with confidence.
Hide Signatures
(in reply to Bax)
       Post #: 8
RE: Servos for SFHSS - 6/18/2012 9:03 PM
ronwc
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: Bax
This is being way over thought. You can use ANY regular servo, digital or analog with that receiver. When we say ''that receiver'', that means receiver. Mode is irrelevant. If we were going to mention a mode, we would have.
The R2008SB receiver operates on FHSS mode when an FHSS transmitter is present, and S-FHSS mode when an S-FHSS transmitter is present. It does not ''care'' which servos you use. However, you MUST use S-Bus servos on the S-Bus, or an S-Bus decoder when you use other servos.
Where the thought came from is that S-FHSS is suppose to be high speed mode (I thought) and most sources say you cannot run analog servos in high speed mode - you have to use digital or you can burn up servos. Is S-FHSS high speed mode, and if it is ok to use all the time with all servos, then what is the FHSS setting used for.
Ron - AMA 1025 - Largo, FL
Hide Signatures
(in reply to Bax)
       Post #: 9
RE: Servos for SFHSS - 6/18/2012 10:12 PM
Bax
Score: 169
Status: offline
There is no high-speed mode in SFHSS air systems. Only the 4PL car system. The airplane systems can use any servo you desire to plug into them.
Hide Signatures
(in reply to ronwc)
       Post #: 10
RE: Servos for SFHSS - 6/19/2012 12:09 AM
ronwc
Score: 100
Status: offline
quote:
ORIGINAL: Bax
Then what is the difference in S-FHSS and FHSS.
Hide Signatures
(in reply to Bax)
       Post #: 11
RE: Servos for SFHSS - 6/19/2012 3:01 PM
Bax
Score: 169
Status: offline
Futaba hasn't told us, but likely it's because FHSS was originally for low-channel car systems, and they decided to come out with the lower-cost airplane systems, and needed a protocol to handle 6-8 channels.
Hide Signatures
(in reply to ronwc)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.516RCU1
