US 41 engine manual    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> US 41 engine manual
Page: [1]
Login
US 41 engine manual - 6/16/2012 10:19 AM
94ultra
Score: 100
Last Login: 6/23/2012
Status: offline
I am trying to locate a pdf of the manual for the US41 gas engine, I have searched a couple of time with no success, does anyone have a copy of the manual in pdf or know of a link??
Thanks in advance
Hide Signatures
       Post #: 1
RE: US 41 engine manual - 6/16/2012 10:42 AM
beepee
Score: 109
Last Login: 5/21/2013
Status: offline
I think I still have a copy of my Quadra manual somewhere in my files. I have both engines and the Quadra manual is good for both. Send me a PM and I will send it back. Meanwhile, I see if I can find it.
Bedford
Hide Signatures
(in reply to 94ultra)
       Post #: 2
RE: US 41 engine manual - 6/16/2012 10:24 PM
WhiteRook
Score: 108
Last Login: 5/20/2013
Status: offline
theres one in the quadra aerow engine forum. if you read the pdf they say run 20:1 gas to oil ?
Hide Signatures
       Post #: 3
RE: US 41 engine manual - 6/16/2012 11:35 PM
w8ye
Score: 318
Status: offline
Quadra manual
http://www.dieselrc.com/download/aerrow_quadra.pdf
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to WhiteRook)
       Post #: 4
RE: US 41 engine manual - 6/17/2012 12:33 AM  1 votes
ahicks
Score: 669
Status: online
quote:
ORIGINAL: WhiteRook
My guess is that's due to the oil commonly available at the time? Today's oils allow 40 and 50:1 to be much more common.
Hide Signatures
       Post #: 5
RE: US 41 engine manual - 6/17/2012 1:29 AM
WhiteRook
Score: 108
Status: offline
probly true . the oils might be better now. I just bought a Q100B used and , do you know what size the threaded holes
are on the mount ? there are 2 non threaded that are mabey 5mm and 2 threaded .
Hide Signatures
(in reply to ahicks)
       Post #: 6
RE: US 41 engine manual - 6/17/2012 3:41 AM
LONGREDDOG
Score: 100
Last Login: 5/18/2013
Status: offline
Can anyone tell me what kit number for the walbro carb. is? I have an older engine (US41) that is new, but would like to replace the kit with one that is compatable with gas mixed with ethanol. Read on an older post that the carb. number should be near the fuel nipple, but did not see one. Thank's in advance for any help!
Hide Signatures
       Post #: 7
RE: US 41 engine manual - 6/20/2012 8:38 AM
94ultra
Score: 100
Status: offline
Thanks for the qutra manual, I forgot the mixture and thought I was using 40:1 but the manual saying 20:1 for regular 30wt oil, I guess 40:1 should be OK if I run amsoil??
Hide Signatures
(in reply to w8ye)
       Post #: 8
RE: US 41 engine manual - 6/20/2012 12:05 PM
beepee
Score: 109
Status: offline
94,
You open a mammouth subject asking about oil. Stand by. I ran mine on off-the-shelf air cooled engine oil (WalMart or elsewhere) at about 32:1. After a while I converted to Amsoil synthetic at 100:1. There has been MANY negative things said about this Amsoil on these pages, but it has worked for me. DO NOT take the Amsoil intended for 100:1 and think you can get away with working it at 50:1. That is not a viable solution. I think Amsoil says you should not go stronger than about 80:1. They have other mixes for stronger ratios.
This engine will respond to most any oil ratio you give it so long as you follow the oil manufacturer's directions, and avoid water-cooled outboard motor oil.
That is just me.
Bedford
Hide Signatures
       Post #: 9
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> US 41 engine manual
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.281RCU1
