stop tire ballooning forever!!! Much better than gorilla tape !!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> stop tire ballooning forever!!! Much better than gorilla tape !!!
Page: [1]
Login
stop tire ballooning forever!!! Much better than gorill... - 6/19/2012 12:40 PM
BigLupton
Score: 100
Last Login: 9/23/2012
Status: offline
Found a new better way to prevent tirez from ballooning and ultimately keeping them from ripping off the rims. I start by turning the tires inside out and then cleaning with denatured alcohol with a scotch brite pads with the rough abrasive side. Once dry I apply a single layer of extra thin drywall tape overlapping by exactly one inch. I then use a high quality rubber cement to brush on a layer just enough to completely cver the tape. Once it is dry to the touch but still sticky I apply another layer of drywall tape with exactly one inch of overlap exactly 180 degrees from the overlap of the first layer of tape (to maintain perfect balance of tire). Then brush on anotherthin coat of rubber cement just enough to cover and a little off the edges of tape. This method it ten times lighter than any duck or gorilla tape methods. It is much more balanced and much more durable while still allowing the tire to flex over rocks and terain almost like before done. My revo 3.3 converted to brushless with hobbywing sc8 system on 4 cell can be geared for 65 mph and hold it off ground and full rev with absolutely no ballooning or stretch. Have almost ten hours of running with this done to set of badlands and still holding perfect. Before I would rip a tire or two off every run. Have not haf even a small section off tire come unglued since done. Try it and you will be just as impressed as I am!!! Will post picks tomorow of how it looks glued to inside of tire. And about to redo a set so will do a step by step with picks and post as I go. Thanks everyone for all the great info along the years, never posted but when I came up with this idea I had to share the info to try to give back to my community.
Hide Signatures
       Post #: 1
RE: stop tire ballooning forever!!! Much better than go... - 6/19/2012 12:54 PM
Foxy
Score: 2012
Last Login: 5/21/2013
Status: offline
NOOOOO, I like my pizza cutters, makes for dramatic photography
_____________________________
So, you got a smartphone. You now have virtually unlimited access to the collective acquired knowledge of the entire human race in the palm of your hand, and you use it to... play Angry Birds while sitting on the toilet. Way to go!
Hide Signatures
(in reply to BigLupton)
       Post #: 2
RE: stop tire ballooning forever!!! Much better than go... - 6/19/2012 4:54 PM
BigLupton
Score: 100
Status: offline
I thought it was kinda cool too until I ripped a couple sets of tires off the rims from ballooning costing me almost $100 dollars, lost its fun factor real quick!!
Hide Signatures
(in reply to Foxy)
       Post #: 3
RE: stop tire ballooning forever!!! Much better than go... - 6/19/2012 5:13 PM
pyromatic177
Score: 255
Last Login: 4/18/2013
Status: offline
Indeed if i had a racer where everything has to be precise i would do that. But using gorilla is a lot easier
!!!Bash Like There''s No Repair Bills!!!
Hide Signatures
       Post #: 4
RE: stop tire ballooning forever!!! Much better than go... - 6/19/2012 6:39 PM
Foxy
Score: 2012
Status: offline
quote:
ORIGINAL: BigLupton
Not ripped one yet, what tires are we talking about? Revo stockers? No experience with 'em but I find it pretty hard to get the tire off the rim of the Savage, with its stockers or with the truggy tires. This car will do standing double backflips if it grips just right...6S of course...
Hide Signatures
       Post #: 5
RE: stop tire ballooning forever!!! Much better than go... - 6/19/2012 6:47 PM
pyromatic177
Score: 255
Status: offline
Ha sweet Savage Foxy
Hide Signatures
(in reply to Foxy)
       Post #: 6
RE: stop tire ballooning forever!!! Much better than go... - 6/19/2012 7:28 PM
Foxy
Score: 2012
Status: offline
To the OP, please don't misunderstand, I'm not saying your idea is without merit, on the contrary, it's a great post for people who are having this problem. But I haven't found it necessary on the Savage yet. No doubt it wuld be really important with Big Joes and other 'stretchy' tires.
But I do like the pizza cutter look.
Hide Signatures
(in reply to pyromatic177)
       Post #: 7
RE: stop tire ballooning forever!!! Much better than go... - 6/19/2012 8:36 PM
LaTuFu
Score: 275
Last Login: 8/31/2012
Status: offline
Or just run some big industrial strength O-Rings on the outside.  No ballooning, no additional weight from tape, cement, etc.
Like the Thunder Tiger MT4 G3? Check it out on wondertiger.com
Hide Signatures
(in reply to Foxy)
       Post #: 8
RE: stop tire ballooning forever!!! Much better than go... - 6/19/2012 10:14 PM
BigLupton
Score: 100
Status: offline
Was a big problem with the traxxas sport track tires and some other thin stretchy tires. I also do speed runs on asphalt so when getting above 60 mph and running on the thin little strip of pizza cutter it was near impossible to control. Also seemed much more balanced than the tape method. No wobbling at speed. Don't doubt those pre glued tires won't tear off but unfortunately no matter how hard I try I've had trouble with tires i glue separating in little areas then when hit just right tear the tire. My badlands seem a lot tougher though. Just thought people might want a lighter more balanced and more durable method. Thanks for the replies!
Hide Signatures
(in reply to LaTuFu)
       Post #: 9
RE: stop tire ballooning forever!!! Much better than go... - 6/19/2012 10:48 PM
pyromatic177
Score: 255
Status: offline
O yeah it does help to know this new method. I might just use it for the new tires on my 1/8th buggy
Hide Signatures
       Post #: 10
RE: stop tire ballooning forever!!! Much better than go... - 6/21/2012 3:02 AM
nastyboys727
Score: 105
Last Login: 5/22/2013
Status: offline
well biglupton i think your way is great im gonna try it myself but if yall dont know by now there is a set of belted 17mm wheeles for trucks thay are slick rubber made by inpanema im not sure on if thats how its spelled but the wheels look awsome
tru to this not new to this
Hide Signatures
       Post #: 11
RE: stop tire ballooning forever!!! Much better than go... - 6/21/2012 3:45 AM
pyromatic177
Score: 255
Status: offline
No i didn't know about those tires. Can you post a link?
Hide Signatures
(in reply to nastyboys727)
       Post #: 12
RE: stop tire ballooning forever!!! Much better than go... - 6/21/2012 5:03 AM
BigLupton
Score: 100
Status: offline
Didn't know they had those. Do they come in mt sizes and treads? How much? Link please!
Hide Signatures
       Post #: 13
RE: stop tire ballooning forever!!! Much better than go... - 6/22/2012 12:44 PM
LaTuFu
Score: 275
Status: offline
They are not cheap.  $150 a pair or something like that, iirc.
http://www.ipanemasports.com/Pages/MonsterTruckSlicks.aspx
Hide Signatures
       Post #: 14
RE: stop tire ballooning forever!!! Much better than go... - 6/22/2012 1:19 PM
TheKennyKiller
Score: 462
Last Login: 1/23/2013
Status: offline
If I had a dollar for every Savage tyre I have seen rip or just blow up on 6S on youtube I would have at least 20 bucks. Not saying they are no good or anything I'm just saying I've seen it a lot.
Do you even RC?
Hide Signatures
       Post #: 15
RE: stop tire ballooning forever!!! Much better than go... - 6/28/2012 7:45 AM
jspeed
Score: 100
Last Login: 11/19/2012
Status: offline
Ipanema Monster truck belted slicks do not balloon out.
They retail for about $150 a set of four.
Size is 139mm tall and 87mm wide!
Try them, you'll like them too.
Hide Signatures
(in reply to TheKennyKiller)
       Post #: 16
RE: stop tire ballooning forever!!! Much better than go... - 6/28/2012 7:54 AM
jspeed
Score: 100
Status: offline
Here's some more Ipanema Monster slick pics on a Savage.
Hide Signatures
(in reply to jspeed)
       Post #: 17
RE: stop tire ballooning forever!!! Much better than go... - 6/29/2012 6:14 AM
The_Shark
Score: 494
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: LaTuFu
yep, so those at the shop, $145/set.
Signature
(Max. 125 chars. 2 lines max)
Hide Signatures
       Post #: 18
RE: stop tire ballooning forever!!! Much better than go... - 6/29/2012 6:16 AM
The_Shark
Score: 494
Status: offline
shoe goo and fiberglass window screen ive done before, works great.
Signature
Hide Signatures
(in reply to The_Shark)
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
