Prop Strut    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> Prop Strut Page: [1]
Login
Prop Strut - 6/19/2012 5:44 PM
wholehog
Score: 100
Last Login: 5/15/2013
Status: offline
Does anyone know if someone makes a replacement liner for a 1/12 scale pro boat prop strut. I have worn out  one or two,and it's a shame to through them away if they can be relined with a new bushing. Thanks.
Hide Signatures
       Post #: 1
RE: Prop Strut - 6/19/2012 7:11 PM
toyotatruckin
Score: 100
Last Login: 5/22/2013
Status: offline
As far as I know the only replacement is to just buy a new strut, the boat actually benefits from modding it to fit a standard strut they are adjustable and use a replaceable brass bushing and normal flexshaft
_____________________________
http://www.youtube.com/user/toyotatruckin
www.aircapitolhobbies.com
Hide Signatures
(in reply to wholehog)
       Post #: 2
RE: Prop Strut - 6/19/2012 9:16 PM
wholehog
Score: 100
Status: offline
So are you saying that there is a strut made that has a replaceable brass bushng that will adapt to my 1/12 pro boat hydro? Thanks
Hide Signatures
(in reply to toyotatruckin)
       Post #: 3
RE: Prop Strut - 6/20/2012 1:21 AM
Dan S
Score: 115
Last Login: 5/7/2013
Status: offline
that would be a yes.
the replacement struts won't be the same as what you have, meaning it will not attach itself to the under side of the hull.
It attach itself to the back of the transom, and this will give you a lot more tuning ability than the original strut.
the following is for the Aquacraft UL-1, not saying to get that one, but just to give you an idea of what to get.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVXS9&P=7
Dan.
F-41 Stryker Cat 260 Full Mod - Whiplash GV NFS 260 - FireFighter 18 - Miss Vegas CVRM 18
Futaba FASST
Hide Signatures
       Post #: 4
RE: Prop Strut - 6/20/2012 2:20 PM
wholehog
Score: 100
Status: offline
Thanks for your help.
Hide Signatures
(in reply to Dan S)
       Post #: 5
RE: Prop Strut - 6/25/2012 8:57 PM
wholehog
Score: 100
Status: offline
I think I will attempt this. Is the strut you had me look at the one I need? I am sure I'll have to change the flex shaft also,and if so,which one do I need? Can I still use the stock size prop shaft. I use a s/s prop I really like on the stock prop shaft,which I think is 3mm. I have tried some other props (Octura) that are for 1/8 in shaft using a shim,but the boat just didn't seem to perform a well with the bigger prop,as with the S/S prop. Wish I could find a aluminum prop that would work. Tried to get info from hobbbico  about  what to use,they didn't have a clue. One other question,my steering rod boot comes out just a tick to the left center on the transom,will this new strut fit and clear the boot? Thanks
Hide Signatures
       Post #: 6
RE: Prop Strut - 6/26/2012 11:13 AM
borristhboxer
Score: 100
Last Login: 5/19/2013
Status: offline
The stock strut is good, but having an adjustable strut is so much better!
I've attached a few pictures of different ways some people have out them on the 1:21 hydro.
I have the same boat with .15 & .18 engines & found a y535 brass or the proboat s/s prop best so far, the aluminium props I've tried I wasn't happy with.
hope it helps a little, with the white boat's set up I cut open the deck & fitted an aluminium backing to strength the transon because proboat use a ply wood & found it to be weak with a bigger motor
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
RE: Prop Strut - 6/26/2012 2:28 PM
wholehog
Score: 100
Status: offline
I like the stock style strut that mounts on the bottom of the red boat,and the strut on the white boat. Can the sleeve be replaced on either style? Do you have the info on both of these struts? Thanks
Hide Signatures
(in reply to borristhboxer)
       Post #: 8
RE: Prop Strut - 6/26/2012 2:38 PM
wholehog
Score: 100
Status: offline
Oops,didn't say witch red boat. Either one,you tell me,looks as if the stock stile on the red boat on the left would be the easiest fix. Thanks again
Hide Signatures
       Post #: 9
RE: Prop Strut - 6/26/2012 3:51 PM
toyotatruckin
Score: 100
Status: offline
the bottom mounted strut bracket was originally a part from TLR (out of business) that one may have been theirs or a home done job but the strut looks familiar. Yes going to any of those struts you get to change your flexshaft to a regular style, (3/16 drop to 1/8 for 1/8 bore props is most common), I can sell you a complete shaft with bushing drive-dog lock-nut but you would need to cut it to length, if I get time in the next day or so Ill look through the TLR blue print's and see if I can find that bracket or see if I have one around here I just might..
Hide Signatures
       Post #: 10
RE: Prop Strut - 6/26/2012 5:07 PM
wholehog
Score: 100
Status: offline
Thanks again. What about the setup on the red boat on the stand or the white boat. I have two other 1/12 pro boat hydros I'll need to convert over to. I would like to use something that I will be able to get parts for a long time in the future. Your the expert here,what's going to be the easiest converson? I don't race but I get a lot of pond time at the house. The second boat I accuired is for the wife,and the third is for my Brother-in-law,so I need to fix both of them. What up with the insert wearing out so fast any way? Is this just the nature of the beast? I try and not run the boat out of the water no longetr than I have to,and just as a precaution,I'll put a drop oil in the strut's water hole to help in keeping it lubed until I get the boat in the water. New strut has had about five tanks of gas and it is already getting sloppy causing the prop to get a bit of a wobble.
Hide Signatures
       Post #: 11
RE: Prop Strut - 6/26/2012 6:35 PM
toyotatruckin
Score: 100
Status: offline
Any of those set-ups above are going to do basically the same thing, give you an adjustable prop angle and height which is a must to get the most out of a boat and cheap replaceable wear parts (the bushing) also gong with a standard flexshaft your not limited to one brand you could even use a miss vegas stock replacement shaft and cut it to length in a pinch.
You do need to either extend the stock stuffing tube so it will reach a new drive or replace the tube completely <-gets my vote- the bracket that bolts up to the bottom does a nice job of filling the stock recess..
One thing about R/C boats is parts are limited and parts suppliers/builders come and go there is no set-in-stone suppliers in this end of the hobby, just ones that have managed to stick around longer than others
Hide Signatures
       Post #: 12
RE: Prop Strut - 6/26/2012 7:14 PM
amax
Score: 107
Last Login: 5/14/2013
Status: offline
Are you Greasing the Flex Shaft & Bushing Every 2 or 3 runs?? I have run several of these with Stock Set Up and Never wore a bushing out.
Top Speed Hobbies llc. Gotta Need For Speed..
www.youtube.com/user/topspeedhobbies
Hide Signatures
       Post #: 13
RE: Prop Strut - 6/27/2012 11:56 PM
borristhboxer
Score: 100
Status: offline
 The white boat setup is the one I cut the back out of the boat & replaced it & the flex shaft, look up building gp1 in the forum.
Thepicture of the yellow boat is a vegas (not sure of spelling) setup from the net but I made my own setup on the red & yellow boat with blue flame work, look up .21 in t hull Proboat. Miss hydro has done the same to her boats in regards for strut setup.
The best setup I have was to cut the boat & do it properly, lolks like it was ment to be like that from factory but the home made con-versions still work fine
Hide Signatures
(in reply to amax)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
