AMT Pegasus Air Start Question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> AMT Netherlands >> AMT Pegasus Air Start Question
Page: [1]
Login
AMT Pegasus Air Start Question - 6/21/2012 12:04 AM
cbooth1979
Score: 100
Last Login: 5/22/2013
Status: offline
 Hi,
I am installing an older AMT Pegasus into my jet and had a question about the air/gas lines. Do I need to run a check valve on them or can I leave them open. I was going to make a little plate with two 4mm Festo bulkhead fittings to hook up to but Im wondering if they can be left open.
Thanks for the help!
Hide Signatures
       Post #: 1
RE: AMT Pegasus Air Start Question - 6/21/2012 1:01 AM
hooker53
Score: 100
Status: online
Hey Cbooth. I never leave those open. It's just to easy for Fod to get in there. I have an open 4mm for my propane and I leave a Festo one way check valve on it in the jet.
_____________________________
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
(in reply to cbooth1979)
       Post #: 2
RE: AMT Pegasus Air Start Question - 6/21/2012 2:12 AM
cbooth1979
Score: 100
Status: offline
Hi,
Thanks for the reply, so your saying to run check valves on both right? I have it plummed right now without them but maybe I can make some 4mm plugs to put in the bulkhead fittings. My main concern was if there was any back pressure when the engine is running that would put air,ect. back into the fuse.
Thanks again,
-Carl
quote:
ORIGINAL: hooker53
Hide Signatures
(in reply to hooker53)
       Post #: 3
RE: AMT Pegasus Air Start Question - 6/21/2012 3:56 AM
Dr Honda
Score: 100
Status: offline
If you don't cap off... or use a check valve on the propane and the air hose... along with FOD intrusion:
Propane: The hot combustion gasses will flow out the hose, and melt the fittings, and hose.
Air: You will loose a small amount of pressure in the engine... and it could run a little hotter.
< Message edited by Dr Honda -- 6/26/2012 11:28 AM >
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 4
RE: AMT Pegasus Air Start Question - 6/24/2012 4:47 PM
GlenR
Score: 100
Status: online
I have learned something knew today. I have a 180 with an umbilical cord between my A S U and my turbine on a test stand right now.I did not think of back pressure from air and propane lines. Thank you for the heads up. glenr
Hide Signatures
(in reply to Dr Honda)
       Post #: 5
RE: AMT Pegasus Air Start Question - 12/31/2012 8:57 PM
Dieselman1220
Score: 110
Status: offline
Haaa I never thought of that when I had my air start AMTs. could have used that air hose as some sort of bleed air tap.. Maybe use a festo 4mm shut off valve operated by a servo to turn it on and off....ahh the ideas.
Joseph K
Hide Signatures
(in reply to GlenR)
       Post #: 6
RE: AMT Pegasus Air Start Question - 12/31/2012 10:17 PM
yeahbaby
Score: 135
Last Login: 5/23/2013
Status: online
You could use a bleed air tap to recharge your air system.
"Audentes fortuna iuvat"
Hide Signatures
(in reply to Dieselman1220)
       Post #: 7
RE: AMT Pegasus Air Start Question - 1/2/2013 2:16 PM
AMTdude
Score: 100
Last Login: 5/21/2013
Status: offline
check valve on propane line to keep hot gasses inside engine, the tubing can melt. The thick teflon tubing is good for this job. I have not noticed any problems related to the air line needing extra equipment or accessories. Bleed Air is avail. but very low pressure. I recall that Bennie had hooked up bleed air on his Bobcat. ? I believe it was Jets over Pampa 2002 ?.?
Hide Signatures
(in reply to yeahbaby)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.316RCU1
