Arrgh - Why are lipos out of stock everywhere    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Arrgh - Why are lipos out of stock everywhere
Page: [1]
Login
Arrgh - Why are lipos out of stock everywhere - 6/21/2012 4:46 PM
FarBeyondDriven
Score: 100
Last Login: 8/4/2012
Status: offline
Ok, so new caldera 10e owner here. Looking to buy a couple lipos and a charger. After much research it seems im going to go with the SKY 30C 2S 5000mah lipos, and the Thunder AC6 charger.
Problem is finally when I decide on the lipo to go with, hobbypartz is out of stock Anyone with experience know how long or what their deal is with restocking? Im pretty fixed on going with them as they seem to have the best shipping rates to ontario Canada.
Unless there is some online site based in Canada i could go with, but any i've found so far are a rip off.
Thoughts?
Thanks in advance
Hide Signatures
       Post #: 1
RE: Arrgh - Why are lipos out of stock everywhere - 6/21/2012 4:58 PM
Foxy
Score: 2012
Last Login: 5/19/2013
Status: offline
Hobbyking? Why would anyone go anywhere else for batts! Hobbypartz is for ezrun stuff, hobbyking is for lipos.
_____________________________
IT`S A FAAAAAAAAKKKKKKKEEEEEEEEE!
Hide Signatures
(in reply to FarBeyondDriven)
       Post #: 2
RE: Arrgh - Why are lipos out of stock everywhere - 6/21/2012 5:30 PM
FarBeyondDriven
Score: 100
Status: offline
because - "Im pretty fixed on going with them as they seem to have the best shipping rates to ontario Canada."
plus king doesnt show Sky lipos anywhere.
Hide Signatures
(in reply to Foxy)
       Post #: 3
RE: Arrgh - Why are lipos out of stock everywhere - 6/21/2012 5:47 PM
Foxy
Score: 2012
Status: offline
Why do you want Sky lipos in particular? Nanotechs and Zippy are both just as good, nanotech arguably better...shipping is cheaper from hobbyking to europe than hobbypartz, not sure about canada.
These are very good packs... http://www.hobbyking.com/hobbyking/store/__11934__Turnigy_nano_tech_5000mah_2S_25_50C_Lipo_Pack.html
And this is a good charger... http://www.hobbyking.com/hobbyking/store/__6478__IMAX_B6_AC_Charger_Discharger_1_6_Cells_GENUINE_.html
I bet you can get 2 batteries and the charger delivered for less than $100.
Hide Signatures
       Post #: 4
RE: Arrgh - Why are lipos out of stock everywhere - 6/21/2012 6:02 PM
FarBeyondDriven
Score: 100
Status: offline
Hmmm, ok I'll check thanks ! Appreciate it
Edit - i cant determine if that imax charger is able to connect to 4mm banana plugs???
Hide Signatures
(in reply to Foxy)
       Post #: 5
RE: Arrgh - Why are lipos out of stock everywhere - 6/21/2012 7:44 PM
Foxy
Score: 2012
Status: offline
What most people do is change the battery plugs for something more helpful, like deans or traxxas. There is most likely a Deans cable with the charger, and changing the connector on a lipo is something I'm afraid you'll have to get used to, we all do it from time to time, the Chinese seem to like bullets. Change em for deans, get a good soldering iron or befriend someone with one
In any case, the point being, what plugs a charger or battery is supplied with is not expected to matter, cables are easy to make and connectors easy to solder. You can buy all kinds of ready made adapters if you really are averse to soldering.
Hide Signatures
       Post #: 6
RE: Arrgh - Why are lipos out of stock everywhere - 6/23/2012 4:02 AM
SoonerBorn
Score: 100
Last Login: 7/30/2012
Status: offline
 So when you chance the plugs via soldering you cut and change the bullet connectors, not then multi-pin plug that the stock charger uses, right?  That would also mean having to cut and solder the speed controllers itch new plugs as well, correct?  Thanks in advance and didn't mean to butt in.
-SB
Hide Signatures
(in reply to Foxy)
       Post #: 7
RE: Arrgh - Why are lipos out of stock everywhere - 6/23/2012 4:10 AM
edgeverse
Score: 100
Last Login: 2/23/2013
Status: offline
Valuehobby carries lipos at good prices with deans already soldered on.
http://www.valuehobby.com/power-systems/lipo-batteries/car-lipo-hard-case/gforce-25c-5000mah-2s-car-lipo.html
So does SPC Racing
http://www.spcracing.com/index.php?categoryID=13
You can choose traxxas or deans
3D Comics/3D Art
edgeversemedia.com
Hide Signatures
(in reply to SoonerBorn)
       Post #: 8
RE: Arrgh - Why are lipos out of stock everywhere - 6/24/2012 2:55 PM
FarBeyondDriven
Score: 100
Status: offline
I think I'm just going to order a couple of these hardcase Sky batteries. They should fit the 10E battery tray right?
http://www.hobbypartz.com/77p-sl4400-2s1p-30c-2222-hardcase.html
Hide Signatures
(in reply to edgeverse)
       Post #: 9
RE: Arrgh - Why are lipos out of stock everywhere - 6/24/2012 5:34 PM
kelynsdad1023
Score: 100
Last Login: 5/17/2013
Status: offline
Great album from Pantera.....although Vulgar Display of Power is my favorite !
Hide Signatures
       Post #: 10
RE: Arrgh - Why are lipos out of stock everywhere - 6/24/2012 6:56 PM
Foxy
Score: 2012
Status: offline
quote:
ORIGINAL: FarBeyondDriven
Why would you buy those? They are lower duratio AND more expensive than these... They're like, worse in every way... Just check your battery tray is 170mm.
Or these... http://www.hobbyking.com/hobbyking/store/__9961__ZIPPY_Flightmax_5000mAh_2S1P_40C.html
More duration and more power for the same price.
Hide Signatures
       Post #: 11
RE: Arrgh - Why are lipos out of stock everywhere - 6/24/2012 7:41 PM
FarBeyondDriven
Score: 100
Status: offline
quote:
ORIGINAL: kelynsdad1023
yep - love them all myself. Been a fan since cowboys
Hide Signatures
(in reply to kelynsdad1023)
       Post #: 12
RE: Arrgh - Why are lipos out of stock everywhere - 6/24/2012 7:45 PM
FarBeyondDriven
Score: 100
Status: offline
[/quote]
[/quote]
Yah but Foxy, shipping from hobbyking is 30$ for the cheapest rate. The place i listed its 9 bucks to my door. I was going to go with the 5000Mah but was starting to worry that running two in a row might be too hard on my motor (heat etc).....Also I'm kinda set on going with the Thunder AC6 charger which is at hobby partz. So for 2 lipos and charger and shipping, I'll be at $103  total.
know what i mean? I do appreciate the help though really.. thanks for chiming in.
Kids are using this truck too, so I dont need THAT much power for now. Hence why Im going with 30C 4400mah .....(but im not the pro, you guys are....i;'ve only been in this for a week )
Thanks again.
Hide Signatures
(in reply to Foxy)
       Post #: 13
RE: Arrgh - Why are lipos out of stock everywhere - 6/25/2012 11:41 AM
Foxy
Score: 2012
Status: offline
Ah, sorry, as I mentioned before, hobbyking's shipping is much cheaper for me than hobbypartz, I assumed it would be the same for you. Those batts will be fine for you, hope everyone has fun with the car
Hide Signatures
       Post #: 14
RE: Arrgh - Why are lipos out of stock everywhere - 6/25/2012 5:09 PM
FarBeyondDriven
Score: 100
Status: offline
thanks,
double aargh - no have a grinding/clicking servo when turning to the limits of left and right
Hide Signatures
(in reply to Foxy)
       Post #: 15
RE: Arrgh - Why are lipos out of stock everywhere - 6/25/2012 7:14 PM
Foxy
Score: 2012
Status: offline
Bad gears. Grab yourself one of these...
http://www.hobbypartz.com/60gexidise.html
Hide Signatures
       Post #: 16
RE: Arrgh - Why are lipos out of stock everywhere - 6/28/2012 11:13 PM
1969elcamino
Score: 100
Last Login: 11/6/2012
Status: offline
Can I use a 7.4v lipo in a 7.2v truck?
Hide Signatures
(in reply to Foxy)
       Post #: 17
RE: Arrgh - Why are lipos out of stock everywhere - 6/29/2012 2:02 PM
FarBeyondDriven
Score: 100
Status: offline
dammit - nothing is easy for me. Just got an email from HobbyPartz saying they dont ship Lipos internationally. so i have a nice Ac6 charger and new exi servo on the way.....but no batteries.
Anyone know somewhere online that they ship lipos to canada?
Hide Signatures
(in reply to 1969elcamino)
       Post #: 18
RE: Arrgh - Why are lipos out of stock everywhere - 6/29/2012 5:48 PM
Foxy
Score: 2012
Status: offline
Hobbyking.com
lol.
Hide Signatures
       Post #: 19
RE: Arrgh - Why are lipos out of stock everywhere - 6/29/2012 5:49 PM
FarBeyondDriven
Score: 100
Status: offline
HAHA on their site now.. Wouldnt that be ironic (and a kick in the nutz for me)
Hide Signatures
(in reply to Foxy)
       Post #: 20
RE: Arrgh - Why are lipos out of stock everywhere - 6/29/2012 5:56 PM
Foxy
Score: 2012
Status: offline
Go with the ones I linked above, make sure they are US warehouse stock and you'll be golden. Maybe that affected your shipping rate? You know you have to pick the right product from the right warehouse, be careful you aren't ordering from China, when you could order from the US.
Hide Signatures
       Post #: 21
RE: Arrgh - Why are lipos out of stock everywhere - 6/29/2012 5:58 PM
FarBeyondDriven
Score: 100
Status: offline
i'll check it out thanks
Hide Signatures
(in reply to Foxy)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.914RCU1
