new backdraft 3.5 problems    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> new backdraft 3.5 problems
Page: [1]
Login
new backdraft 3.5 problems - 6/22/2012 7:41 PM
MadMax49
Score: 100
Last Login: 7/27/2012
Status: offline
Well first off, hi to all! I just got the backdraft broke in and been having problems starting it after it runs awhile! Also it seems to be running in only one speed, is there any way to adjust this 2 speed timing on this buggy, because its different from the video on the other 2 speeds? Man I have blisters on my fingers from trying to start it after it heats up! Thanks any help will be helpful
Hide Signatures
       Post #: 1
RE: new backdraft 3.5 problems - 6/22/2012 8:38 PM
NewRageRC
Score: 100
Last Login: 4/8/2013
Status: offline
Make sure you aren't running a fuel with too much oil. We tried a 18% mix and I couldnt get my 3.5 to run for crap.
For the transmission, you'll have to take the whole thing apart. There's a set screw on the side of one of the gears that tensions a spring against a centrifugally actuated lever. You'll want to turn it out a bit. Unfortunately it's a whole lot of tearing apart and putting back together over and over again to test.
Hide Signatures
(in reply to MadMax49)
       Post #: 2
RE: new backdraft 3.5 problems - 6/22/2012 9:15 PM
MadMax49
Score: 100
Status: offline
Well im running 20%! Can u buy 18%? if so where can u get it! Also shouldnt I put diff oil back in it when I tear it down?
Hide Signatures
(in reply to NewRageRC)
       Post #: 3
RE: new backdraft 3.5 problems - 6/23/2012 3:41 AM
NewRageRC
Score: 100
Status: offline
The transmission isn't sealed, you'll just want to make sure the gears are greased. You're running 20% nitro, you want to see what the oil %age is. The more oil the hotter its going to need to be to burn and the more susceptible it's going to be to fouling plugs. I think 10% oil is about what you want.
Hide Signatures
       Post #: 4
RE: new backdraft 3.5 problems - 6/23/2012 3:13 PM
MadMax49
Score: 100
Status: offline
Hmm I wondering if it be better to use a hotter plug instead of using 10%? Im thinking 10% may be rough on the engine! what do you think?
quote:
ORIGINAL: NewRageRC
Hide Signatures
       Post #: 5
RE: new backdraft 3.5 problems - 6/23/2012 5:13 PM
Valgath
Score: 100
Last Login: 5/19/2013
Status: offline
my EQ has the 3.5 engine and i use 20% nitro and it runs just fine  . Im using sidewinder fuel for mine .
< Message edited by Valgath -- 6/24/2012 3:44 PM >
Hide Signatures
       Post #: 6
RE: new backdraft 3.5 problems - 6/23/2012 9:44 PM
kelynsdad1023
Score: 100
Last Login: 5/17/2013
Status: offline
I have the EQ 3.5 and I use Byron fuel with 20% nitro and 12% oil and use OS 8 glow plugs and it runs like a champ !
Hide Signatures
(in reply to Valgath)
       Post #: 7
RE: new backdraft 3.5 problems - 6/25/2012 4:35 PM
NewRageRC
Score: 100
Status: offline
quote:
ORIGINAL: MadMax49
quote:
ORIGINAL: NewRageRC
I don't know. I tried probably half a dozen different plugs and gave up on the fuel we had and bought something with less oil because it was just too frustrating.
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
