how to use a servo for a power plant ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> how to use a servo for a power plant ?
Page: [1]
Login
how to use a servo for a power plant ? - 6/23/2012 6:37 AM
ozpom
Score: 100
Last Login: 6/24/2012
Status: offline
hi I am looking at converting some small plastic kits to RC
on the forum I found this comment
The easiest way to convert a plastic model to RC is to use a simple 2 channel radio. Use one servo for rudder, and disassemble the other for a combo speed control/powerplant.
could anyone explain in a bit more detail how you could do this
thanks
Hide Signatures
       Post #: 1
RE: how to use a servo for a power plant ? - 6/23/2012 7:10 AM
Deathwish
Score: 100
Last Login: 5/25/2013
Status: offline
Hope this help's.
http://www.mhsd.org/model/howto/servo.htm
< Message edited by Deathwish -- 6/23/2012 9:32 AM >
Hide Signatures
(in reply to ozpom)
       Post #: 2
RE: how to use a servo for a power plant ? - 6/23/2012 10:49 AM
mfr02
Score: 105
Status: offline
I would mostly go along with that link - just adding a few extra points.
1. Refitting the case is optional, but if you use the bare board, either to save weight or make siting the unit easier, it is a good idea to put a wrap of tape around it to both insulate it and provide a strain relief for the wire lead.  The motor can also be separated from, and rewired to the board.  Already like that on some (older) servos.
2. Finding the right size wire sleeving for the drive can be tricky,  the motor shaft is very short, and sleeving tends to push itself off over time, usually just as the boat goes out of reach.  My preference is the flint spring from a disposable lighter.  I recently got 5 for £1, picked the inevitable one that didn't work and dismembered the flint carrier.  Downside is that not all designs have the same diameter spring, most have tapered ends, which can be persuaded on, and GRIP.  Some are not tapered and cannot be used.  There have been questions about the spring unwinding.  Bearing in mind the power levels involved, nothing to worry about.  The best possible arrangement would be something that fitted over, and gripped, the cog, that way there would be a positive drive and no need to remove the cog.
3.  You use the pot as a center off setting control, but on a servo the deadband is very narrow, so fully off is not always easy to hit reliably.  One the other hand, if you just intend to park the boat, why bother with a motor?  One the other other hand (3 so far) there are robotics sites out there where circuit board mods are detailed to expand the dead band, but with my fingers and eyesight I have never bothered.
Hide Signatures
(in reply to Deathwish)
       Post #: 3
RE: how to use a servo for a power plant ? - 6/23/2012 10:54 PM
ozpom
Score: 100
Status: offline
ok thanks for the help .
can i ask where to you get the small drive shafts and props from ?
Hide Signatures
(in reply to mfr02)
       Post #: 4
RE: how to use a servo for a power plant ? - 6/24/2012 5:16 AM
Deathwish
Score: 100
Status: offline
You get a prop from the kit usually and sometimes the drive shaft. But u can use a thin wire that fit's into the prop and epoxy it into place.
Hide Signatures
(in reply to ozpom)
       Post #: 5
RE: how to use a servo for a power plant ? - 6/24/2012 11:42 AM
mfr02
Score: 105
Status: offline
I usually make my own - it helps a lot if you have a hobby shop with a K&S bar.
I start with the bearings - normally a short length of the plastic tube from a Q-tip or cotton bud.  I then find some brass rod that is a nice sliding fit through the tube.  That will form the basis of the shaft.  Next find a tube that is a reasonable fit over the Q-tip tube, thats the shaft outer.  The shaft needs to be lightly greased, the bearings part inserted in the tube, the shaft pushed through to align everything, and epoxy applied to the exposed part of the bearings before pushing them home.
Using the kit props involves CAREFULLY drilling and reaming a hole for the shaft and possibly some sanding of the blades.  Normally I epoxy this to the shaft.  I normally cut a sliver off the end of the tube and use it as a thrust washer/spacer.
It is also quite possible, with very basic tools and abilities to mark out and cut a prop from thin brass sheet, and soft solder it onto the shaft.
The master of this sort of thing, albeit at a larger scale, was the late great Towboat Joe, sadly no longer with us, but his site, and the information on it, has been rescued and is at   http://towboatjoe.tripod.com/
Similar procedure when making a working rudder.
Hide Signatures
       Post #: 6
RE: how to use a servo for a power plant ? - 6/29/2012 9:24 PM
diy-pro
Score: 100
Last Login: 11/8/2012
Status: offline
A servo as a power plant? What are you building something for speed or a cruiser? If its speed your looking for and dont have an esc handy use that servo to flip a power switch on a relay to a larger motor. just a thought.
Just found this and i will attempt to make one once i get over to radio shack...
http://www.rc-airplane-advisor.com/electronic-speed-controller-photos.html
< Message edited by diy-pro -- 6/30/2012 12:19 AM >
Hide Signatures
(in reply to mfr02)
       Post #: 7
RE: how to use a servo for a power plant ? - 6/30/2012 12:01 PM
mfr02
Score: 105
Status: offline
quote:
ORIGINAL: diy-pro
I would take the first line of the OP as a good clue -
Small plastic kits normally implies scale models, the power from a servo suggests that high speed is not the intention.
Back in the day when ESCs were expensive items I used a servo board to drive an opto isolator which in turn drove two pairs of Darlington power transistors, simple, relatively cheap, and you got reverse as well, unlike the flight idea.  It didn't rely on copious air cooling to survive, either.  Modern ESCs are smaller, handle more power, and only cost pennies more than the parts, so I use them now.
Hide Signatures
(in reply to diy-pro)
       Post #: 8
RE: how to use a servo for a power plant ? - 7/1/2012 9:03 AM
Cloudsoarer
Score: 100
Last Login: 2/15/2013
Status: offline
A dozen 10mm props available from here.
Hide Signatures
(in reply to mfr02)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
