RE: Another Kadetito Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Another Kadetito Build Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Another Kadetito Build - 7/18/2012 6:41 PM
carlosam
Score: 100
Last Login: 6/19/2013
Status: offline
Then
The idea of ​​using ultracote is good.
My idea is to use ultracote transparent..
I using this ultracote not have problems.Am I right? http://www.hangar-9.com/Products/Default.aspx?ProdID=HANU966
_____________________________
Be happy is to stop being a victim and becoming an author of the history itself.
Hide Signatures
(in reply to hllywdb)
       Post #: 26
RE: Another Kadetito Build - 7/18/2012 8:19 PM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: hllywdb
................In the last 10 years I have covered all my 1/2a planes with Ultracote. I goes on easier, has less chance of warping the wings, and is 3 to 4 times stronger so if my plane bounces around a bit in the car or on a less than perfect landing I don't have to fix holes. Is it heavier? Yes, but in weight measured in grams.
Given the size of most of the 1/2A planes, a little calculation on the area to be covered will show that covering weight is really fairly insignificant - in many cases, less than .5 oz. Like Bill posted, simply choosing a different battery pack or tank will usually make much more difference in weight than using a different covering.
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
       Post #: 27
RE: Another Kadetito Build - 7/18/2012 9:05 PM
carlosam
Score: 100
Status: offline
I agree, but this model airplane is an area of ​​approximately =1.5m² = 16sqft
monokoteTOPQ0304 Weight = 0.2 oz / sq ft (61 g / m²) = 90grs=3,17oz.
ultracote Weight: 0.12 oz per square ft (36.6 g / m²). = 54.9 grs=1,94oz.
(90 -54.9) = 35.1 grams = 1.2 oz.
Hide Signatures
(in reply to Andrew)
       Post #: 28
RE: Another Kadetito Build - 7/24/2012 1:49 AM
sirzepp
Score: 100
Last Login: 6/1/2013
Status: offline
Good information here, thanks guys. I'll be posting more pics of progress. I've been on the road working...but will be home tomorrow. Perhaps I'll have a couple of hours to work on the plane over my next 3 days at home.
Goldberg Ultimate Brotherhood #79
GP Ultra Sport Brotherhood #118
Hide Signatures
(in reply to carlosam)
       Post #: 29
RE: Another Kadetito Build - 7/26/2012 2:32 AM
sirzepp
Score: 100
Status: offline
Finished framing up the first side.
Now on to the second.
The familiar photocopy construction method for truss fuselages...weeee!
Hide Signatures
(in reply to sirzepp)
       Post #: 30
RE: Another Kadetito Build - 7/26/2012 1:38 PM
Iron Bottom
Score: 100
Status: offline
Looking good, sirzepp. I have a question about the dihedral in the wing. I am working on a Kadetito also and on the plans I have there is no actual figure for the amount of dihedral. Measuring the angle of the dihedral brace with a protractor I get 9.5 degrees. Is there a figure on the plans you have?
Hide Signatures
       Post #: 31
RE: Another Kadetito Build - 7/26/2012 3:55 PM
carlosam
Score: 100
Status: offline
well,
In my plan, the only existing picture is the one below.
It found a measure of 5 ° or 10 ° in total
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Iron Bottom)
       Post #: 32
RE: Another Kadetito Build - 7/28/2012 12:41 PM
Iron Bottom
Score: 100
Status: offline
Thanks, carlosam.
Hide Signatures
       Post #: 33
RE: Another Kadetito Build - 7/28/2012 7:57 PM
sirzepp
Score: 100
Status: offline
I just used the dihedral brace to set up my wing...basically the TLAR method. We will see how she flies.
Hide Signatures
       Post #: 34
RE: Another Kadetito Build - 7/29/2012 2:10 PM
Iron Bottom
Score: 100
Status: offline
I expect you'll be OK with the dihedral, sirzepp. I checked a model design book I have, and for a trainer, an angle of 6-8 degrees was specified for 3 channel trainers. Think I'll go with 9 degrees. A little bit either way probably won't matter.
Hide Signatures
       Post #: 35
RE: Another Kadetito Build - 8/2/2012 5:52 PM
sirzepp
Score: 100
Status: offline
Fuse sides done:
Fuse assembly:
I made my first big screw up above (there have been a few little ones). I used a 1/4 inch ply firewall...for some reason my brain was convinced it was the right size (1/8")...I've had a lot on my mind lately and even though it looked too big...I installed it without reassessing. So now I can but a 30cc gasser on the front of my kadetito. Dear Lord, I think I'm going insane. Anyway, it shouldn't matter TOO much, I'll just move the battery back. The bummer is, I'm using an ultra light LiFe battery, and I just counteracted that weight savings...lol. But I am too lazy to fix it.
Mocked up:
Hide Signatures
       Post #: 36
RE: Another Kadetito Build - 8/2/2012 7:57 PM
carlosam
Score: 100
Status: offline
That's right, work calmly
Everything seems perfect until now
Watching....
Hide Signatures
       Post #: 37
RE: Another Kadetito Build - 8/4/2012 2:24 PM
sirzepp
Score: 100
Status: offline
Fuse is nearly complete. Just a few more things to do.
Still have to build the vertical stab and rudder, then it's time to prep and cover.
Hide Signatures
       Post #: 38
RE: Another Kadetito Build - 8/8/2012 8:33 PM
sirzepp
Score: 100
Status: offline
Vertical stab and Fuselage are done. Gotta build the rudder then sand and cover. Almost there!
Hide Signatures
       Post #: 39
RE: Another Kadetito Build - 8/8/2012 11:01 PM
skyraider71
Score: 110
Status: offline
I have been following this and have been enjoying your build. Nice job.
aka MrBreeze
73''s KK4MSE
Hide Signatures
       Post #: 40
RE: Another Kadetito Build - 8/9/2012 12:36 PM
Wagon1
Score: 101
Status: offline
She looks great! This is about the time in every build that I "fly" her around the room making silly airplane noises when nobody is looking....
"Leave the gun, take the cannolis"
Hide Signatures
(in reply to skyraider71)
       Post #: 41
RE: Another Kadetito Build - 8/14/2012 12:03 AM
sirzepp
Score: 100
Status: offline
Got the fuselage sanded, installed the cowl, engine mount (and mocked up engine, obviously...which is where I started making airplane noises!). Hinged control surfaces and started mocking up servo placement. It's getting there, but the electronics installation and control rod routing is always where I bog down...I don't find it enjoyable at all. I'm looking forward to covering, but until I get the radio squared away I have to wait...UG.
Hide Signatures
(in reply to Wagon1)
       Post #: 42
RE: Another Kadetito Build - 8/14/2012 4:55 AM
skaliwag
Score: 100
Last Login: 6/18/2013
Status: online
The perfect table centre piece.. Who needs a Bronze or Crystal?
No Dear ..... This week we have a Kadet. Next week you have the Cupid. Then I have my Dooling '29 , and for the week your mother is here you get to choose again..
Real Airplanes have Round Engines and Two Wings.
Hide Signatures
       Post #: 43
RE: Another Kadetito Build - 8/14/2012 1:23 PM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: skaliwag
Oops, I forgot to tell you, for the week your mother is here, I'm scheduled to be out of town on some contract work. Guess I'll just have to miss her visit, but I'll take the Kadet to have something to do in the evenings.
the "other" andrew
Hide Signatures
(in reply to skaliwag)
       Post #: 44
RE: Another Kadetito Build - 8/14/2012 2:00 PM
dmbaerry
Score: 100
Status: offline
Looking good.. keep up the good work
Hide Signatures
       Post #: 45
RE: Another Kadetito Build - 8/14/2012 4:09 PM
hllywdb
Score: 118
Status: offline
My mother-in-law is 81, doesn't mind 1/2A centerpieces, and occasionally goes up to the field with us to get a little stick time in on the buddy box. If your mother-in-law doesn't get the centerpiece thing, take her to a swap meet and trade her for a couple of good running TD's or something
Hide Signatures
(in reply to dmbaerry)
       Post #: 46
RE: Another Kadetito Build - 8/15/2012 12:00 AM
sirzepp
Score: 100
Status: offline
You guys gave me a good laugh! Love that. Luckily my mom-in-law is an incredible woman...so glad to be married into their family.
Not sure she'd be down with 1/2A centerpieces, though...but a couple of TDs do sound nice .
Hide Signatures
       Post #: 47
RE: Another Kadetito Build - 8/19/2012 9:17 PM
sirzepp
Score: 100
Status: offline
She's up on her own legs now. Servos are installed, pushrods routed, engine mount ready...getting really close now...
Wheels are dubro ultra lite foams...front one is a bit smaller, but they are all kind of big because I want it to be able to fly off reasonably mowed grass. My dad doesn't have access to a formal field, so he'll be finding a place out in the boonies...and I want him to have all the options he possibly can.
Hide Signatures
       Post #: 48
RE: Another Kadetito Build - 8/20/2012 8:49 PM
buzzard bait
Score: 115
Last Login: 6/17/2013
Status: offline
It looks terrific. Over-sized wheels are excellent on grass, especially for small airplanes. It's amazing what will take off from a rough field if you just make the wheels big enough.
Jim
Hide Signatures
       Post #: 49
RE: Another Kadetito Build - 8/20/2012 10:06 PM
hllywdb
Score: 118
Status: offline
Looks great so far Sirzepp.
Can't tell from the picture, but you want to make sure that the landing gear setup keeps the wing level, or even just a tad down, otherwise they just keep bouncing and trying to take off again when you try to land them
Hide Signatures
(in reply to buzzard bait)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.455RCU1
