RE: JET LEGEND VIPER BUILD THREAD    Gallery
Logged in as Guest
Users viewing this topic: killerG
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: JET LEGEND VIPER BUILD THREAD
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 11:05 AM
modelmancan
Score: 100
Last Login: 5/20/2013
Status: offline
Here you go Jeremy, it just in front of the right tank, note I've lined the tray with 2mm lite ply to tidy things up, the pre cut holes never seem to be just were you want them!
I also made a "mud guard" or housing for the nose wheel for when it finally gets to the grass strip, its a nuisance picking grass out of the pilots teeth every time you land!
Ive also shown how I've retained the Rx Lipos, easy to take out to recharge.
I have also cut a RX sized hole for the servo leads to come through the tray, that means I don't have to unplug every thing to remove the tray
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Jeremy_D)
       Post #: 101
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 11:15 AM
Jeremy_D
Score: 100
Status: offline
Thanks for the photos, this will help me heaps!
_____________________________
Global Jet Club Australia
www.aussiejet.com
Hide Signatures
(in reply to modelmancan)
       Post #: 102
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 11:26 AM
modelmancan
Score: 100
Status: offline
I'm quite please with this little trick with the power box Duel switch leads.
Ive glued them together then made a lite ply flange, cut a hole in the top deck pused it through and fixed it with two small screws from the top.
Nice and simple and keeps the leads from flying around in the cockpit or disappearing through a hole and hiding under the tray.
I also made a housing from lite ply for the switch, its essayer to get to the buttons and the switch doesn't get in the way of anything under the tray.
I still cut a hole in the deck under the switch as its very important to keep the switch cool, you may have noticed they get quite hot in use.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 103
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 12:01 PM
steve2972
Score: 100
Last Login: 5/17/2013
Status: offline
So basically to obtain best C&G with the T12,aux equiment needs to placed as far back as possible?
Hide Signatures
       Post #: 104
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 1:25 PM
modelmancan
Score: 100
Status: offline
Yes, Dispite going to some lengths with the first install to keep it all forward to obtain the recommended and very safe CG,
All of the 112mm dia turbines seem to weigh about the same at between 1400-1600g including the T12.
Had I known that the CG was safe further back I would have just done my more usual install and layout as it has ended up now.
It still did not take me long to put it together, it arrived on the Monday and was ready to fly on the Thursday despite having to try and fit everything up front.
Had I gone with my instincts and made my usual layout as it is now I could have saved another day on the bench, its a very quick build.
There plenty of scope to move things around for lighter turbines, having the ECU battery on top of the tank at the very least would be a given.
I may well relocate my Rx battery just behind the nose wheel cover and refit my lights lipo further back along side the ECU Lipo
You could fit the ECU Lipo along side the Turbine on its mounting rail, that should help a lot.
Click for fullsize
Click for fullsize
< Message edited by modelmancan -- 8/26/2012 4:18 PM >
Hide Signatures
(in reply to steve2972)
       Post #: 105
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 5:24 PM
Ian Prentice
Score: 100
Last Login: 5/3/2013
Status: offline
Hi Guys, I managed to skive off work for an hour to maiden my viper! I managed to get 2 flights in! and it flew a treat, I had mine balanced at about 30mm behind the factory setting and will take it back , The merlin 90 flys it great take off was good and I flew it about half throttle! Think I should get about 12 mins or more ! did'nt get chance to play with the smoke maybe next week! The one downside is the colour scheme sucks in sunny conditions (reflecting) ! might have to start wearing sun glasses :-( however I cant see this being an issue here in the UK :-) very rare
clip of the takeoff and landing !
http://youtu.be/29_5m_mqJQQ
Click for fullsize
Click for fullsize
< Message edited by Ian Prentice -- 8/2/2012 5:54 PM >
Hide Signatures
       Post #: 106
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 5:31 PM
martin.lees1
Score: 100
Last Login: 1/5/2013
Status: offline
Well done skiver,
Rgds Martin.
Hide Signatures
(in reply to Ian Prentice)
       Post #: 107
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 6:24 PM
Jame
Score: 100
Last Login: 4/19/2013
Status: offline
Congrats Ian, and everyone said owning your own business was reaaaallllllyyyyy hard work Looks really good mate, looking forward to seeing it if the weather will hold up
Hide Signatures
(in reply to martin.lees1)
       Post #: 108
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 6:30 PM
modelmancan
Score: 100
Status: offline
Nice one Ian, You now know They are beautiful to land. Nice bit of turf you have to play on there.
All we need now is a very large wind brakes all the way round our flying sites and we can all go out to play.
Will it ever stop blowing.
Regards Mark V
< Message edited by modelmancan -- 8/26/2012 4:13 PM >
Hide Signatures
(in reply to Jame)
       Post #: 109
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 6:43 PM
Ian Prentice
Score: 100
Status: offline
Thanks Mark and thanks for all the info really helpful ! Need to move the ecu battery back into the turbine bay ! They sure do fly nice and landing is a breeze ! Just need to sort out a few things and then fine tune it !
Cheers Jame weather for the weekend looks pretty normal wet with thunder storms so we will see ! Might take a chance and go Sat!
Hide Signatures
       Post #: 110
RE: JET LEGEND VIPER BUILD THREAD - 8/2/2012 7:10 PM
Jame
Score: 100
Status: offline
Ive noticed mate Same Old Same Old by the look of it, I may nip down tomorrow night after work for an hour with FoamE Acro, I havent flown since Elvington, feel like Ive lost a limb
Hide Signatures
       Post #: 111
RE: JET LEGEND VIPER BUILD THREAD - 8/4/2012 4:42 AM
keweiliang
Score: 100
Status: offline
Hi,
Congratulations
William
Growth in flights ...
Hide Signatures
       Post #: 112
RE: JET LEGEND VIPER BUILD THREAD - 8/5/2012 7:33 PM
madmodelman
Score: 110
Status: online
Hi guys,
Happy to report successful maiden of my Viper today at RAF Barkston Heath.
CG was just 10mm behind the factory setting so I opted for 3mm of up elevator trim knowing she would be a bit nose heavy but rotation was quick, just a flick of elevator saw her tracking steady at about 15 degrees climb out hands off.
Flight was very good, only hint of forward cg was hauling a fair bit of elevator out of a dive and almost running out of elevator authority on the flare out, quite flyable and no tendency to drop her nose in tight turns.
Sorry, no camera or vid, after the flight the heavens just opened and we all got drowned, I consider myself lucky to even get a window for one flight with our weather this year.
Thanks to Jeff Sewell and JetLegend, a great, easy to fly model. Powered by JetCat P80SE (more than adequate) and guided by DX18 radio.
Gary.
Click for fullsize
Stuka, P51, Super Chipmunk, Super Stearman R170, BE2e, Javelin, Hawk, F16, L39, F86, Viperjet. Need an F4!!
Hide Signatures
       Post #: 113
RE: JET LEGEND VIPER BUILD THREAD - 8/6/2012 12:06 PM
Xairflyer
Score: 105
Status: online
Well done Gary, glad it went well
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to madmodelman)
       Post #: 114
RE: JET LEGEND VIPER BUILD THREAD - 8/6/2012 12:14 PM
modelmancan
Score: 100
Status: offline
Nice to see another JL Viper airborne, well done sham your day was cut short.
I hope you enjoy flying yours as much as I have flying mine.
Looks fantastic on the Ground, How is the vis in the air with it in the Black and Bronze?
Regards Mark V
Hide Signatures
(in reply to Xairflyer)
       Post #: 115
RE: JET LEGEND VIPER BUILD THREAD - 8/6/2012 1:57 PM
madmodelman
Score: 110
Status: online
Thanks Seamus.
Hi Mark, vis was quite bad as the approach had a big dark grey cloud behind it! The good news was I'd fitted four landing lights in the wingtips which helped no end.
For general flying the vis and orientation semed quite good, certainly nothing to worry about.
I shovelled all the batteries back to the tank area this morning so really looking forward to the next flights, it was one of the easiest maidens I have ever done, flew beautifully.
Like others I used a bit of down trim on t/off flap and more again on landing, hardly any ail trim used, highly recommended jet as far as I'm concerned.
Gary.
Hide Signatures
       Post #: 116
RE: JET LEGEND VIPER BUILD THREAD - 8/11/2012 8:39 PM
modelmancan
Score: 100
Status: offline
Hi Guys
Here's my latest CG update, I'm now back to 49mm behind the wing tube centre with empty tanks and gear down.
There is no tendency to balloon on the approach and it is still lands like its on rails.
Its very stable in normal flight and at speed, strangely I still have quite a lot of up trim ?
How ever at very "very" slow speeds clean ive got it for the first time to drop a wing in both straight flight and in a very "very" turn.
The good thing is as soon as I let it pick up evan a littel speed it recoverd straight away.
I have also tried spins upright and inverted and it recovers easaly just by letting go.
Im not sure this is a result of the more rearward CG or I am just trying harder with the Viper as im gettin use to it?
When I get a chance ill try it all again with the more forward CG and report back.
I was teasing the hell out of it and would never imagine anyone silly enough to try flying it this slow or tight wile low or on the landing approach.
In normal flight all manoeuvres are smooth loops are true fast and large or slow and tight, slow rolls still need a fair bit of forward stick wile inverted.
I'm not going to go any further and will now settle on 35-40mm as I have noticed no diffrence beond this piont and still feels very safe at this position, Have fun
The pic below shows the elevator trim setting for norm flight, it just like every Flash ive seen and owend!
Click for fullsize
< Message edited by modelmancan -- 8/26/2012 4:48 PM >
Hide Signatures
       Post #: 117
RE: JET LEGEND VIPER BUILD THREAD - 8/13/2012 10:50 AM
madmodelman
Score: 110
Status: online
Managed to get three flights on the Viper yesterday at Barkston, excellent flying machine, I would recommend this jet to anyone, good value for money and flies extremely well, this model will now permanently replace old my Elan as my "fun" flyer!
Cg was settled at 35mm behind spar as per Mark etc. and seems the best setting so far.
Gary.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 118
RE: JET LEGEND VIPER BUILD THREAD - 8/13/2012 11:41 AM
Xairflyer
Score: 105
Status: online
Looking good there Gary, well the Viper is anyway
www.jmaireland.com
Hide Signatures
       Post #: 119
RE: JET LEGEND VIPER BUILD THREAD - 8/13/2012 1:01 PM
madmodelman
Score: 110
Status: online
Sorry mate, the guy with the camera said "say cheese"
Hide Signatures
       Post #: 120
RE: JET LEGEND VIPER BUILD THREAD - 8/13/2012 5:46 PM
kasi122
Score: 100
Status: offline
Hi ian,
Did you have the same problem with the front strut, that the spring Is too weak.
We are building 4 Vipers, and every front gear goes down to the end way, when the tanks are full!. How Did you
Solve that Problem ?
Best regards
Andi
Hide Signatures
       Post #: 121
RE: JET LEGEND VIPER BUILD THREAD - 8/13/2012 6:01 PM
madmodelman
Score: 110
Status: online
Andi, it's Gary, not Ian.
Yes, you need some old nipples off a valve or retract cylinder, screw them into the threaded holes in the struts and pump them up with air when tanks are full.
This cures the problem,
Gary.
Hide Signatures
(in reply to kasi122)
       Post #: 122
RE: JET LEGEND VIPER BUILD THREAD - 8/13/2012 6:11 PM
kasi122
Score: 100
Status: offline
Hi,
Sorry Gary for calling you the wrong one :-)
Do you have a photo from your strut?. there is a little hole (with a srew thread in int)in the front strut above the two allen key blindscrews who hold the strut. i read that someone put oil in the strut. Did you use the same hole, Do you have to pump up the strut every flight?
bestr regards
Andi
Hide Signatures
       Post #: 123
RE: JET LEGEND VIPER BUILD THREAD - 8/13/2012 6:18 PM
Ian Prentice
Score: 100
Status: offline
Hi Andi
There is a threaded hole on each leg ! Just pressurise them ! I did mine and they are fine 4 weeks later ! I had to top my migs oil up to keep it sealed !
Cheers Ian
Hide Signatures
       Post #: 124
RE: JET LEGEND VIPER BUILD THREAD - 8/13/2012 6:23 PM
madmodelman
Score: 110
Status: online
As Ian says, they seem to hold the air ok Andi.
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.910RCU1
