HobbyKing Turnigy Rotomax 1.60    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> HobbyKing Turnigy Rotomax 1.60
Page: [1]
Login
HobbyKing Turnigy Rotomax 1.60 - 6/24/2012 6:29 AM
avrod
Score: 100
Last Login: 10/21/2012
Status: offline
Has anyone tried one of these motors?
http://www.hobbyking.com/hobbyking/store/__17986__Turnigy_RotoMax_1_60_Brushless_Outrunner_Motor.html
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: HobbyKing Turnigy Rotomax 1.60 - 6/24/2012 8:02 AM
Alex Voicu
Score: 100
Last Login: 5/15/2013
Status: offline
It's way too heavy for pattern (849g). kV also seems a little too high, but since they recommend a 21x13W APC propeller, maybe it's possible to use a 21x14.
Hide Signatures
(in reply to avrod)
       Post #: 2
RE: HobbyKing Turnigy Rotomax 1.60 - 6/24/2012 10:16 AM
avrod
Score: 100
Status: offline
I thought that too but it might just be the shipping weight.
Hide Signatures
(in reply to Alex Voicu)
       Post #: 3
RE: HobbyKing Turnigy Rotomax 1.60 - 6/24/2012 12:48 PM
Alex Voicu
Score: 100
Status: offline
Shipping weight is displayed lower on the page: 1150g.
Hide Signatures
(in reply to avrod)
       Post #: 4
RE: HobbyKing Turnigy Rotomax 1.60 - 6/24/2012 2:26 PM
AmishWarlord
Score: 121
Last Login: 5/23/2013
Status: offline
Wow many Watts per pound do you pattern guy like to use?
Hide Signatures
       Post #: 5
RE: HobbyKing Turnigy Rotomax 1.60 - 6/24/2012 9:17 PM
Flyer88
Score: 100
Last Login: 5/9/2013
Status: offline
Why bother when you can get a real F3A motor from Extreme Flight RC for about $200.
And it's nice and lite too.....
< Message edited by Flyer88 -- 6/24/2012 10:44 PM >
_____________________________
Why is there never enough time to do it right, but always enough time to do it over ?
Hide Signatures
(in reply to AmishWarlord)
       Post #: 6
RE: HobbyKing Turnigy Rotomax 1.60 - 6/25/2012 12:55 AM
cmoulder
Score: 106
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: AmishWarlord
250-300 watts/lb is common because you want a system that can handle long verticals easily.
But 849 grams is ridiculously heavy for a pattern motor. An excellent choice at a reasonable price is the Himax 6330-210 weighing around 630g at a cost of approx $279. A Plettenberg Advance 30-10 weighs in at 567g (which was what mine weighed, although some report somewhat higher) at a cost of about $570. Geared inrunners are lighter, but get ready to spend more. I like outrunners (altho the Advance is actually a direct drive (1:1) inrunner) for their simplicity and low maintenance - no gears to grease!
Bob
Hide Signatures
       Post #: 7
RE: HobbyKing Turnigy Rotomax 1.60 - 6/25/2012 4:29 AM
Doug Cronkhite
Score: 105
Last Login: 5/22/2013
Status: offline
IMO there isn't a better 'bargain' motor on the market for pattern flying than the Hacker A60-7S V2 28 Pole motor. I flew Andrew Jesky's Osiris 2m with this motor in some pretty heavy wind in Phoenix and it had MORE than enough power for anything I wanted to fly.
Doug Cronkhite
Hide Signatures
(in reply to cmoulder)
       Post #: 8
RE: HobbyKing Turnigy Rotomax 1.60 - 6/25/2012 12:39 PM
RC_Pattern_Flyer
Score: 105
Last Login: 4/28/2013
Status: offline
Dualsky 6355 12t. Swings a 2113 nicely. $ 200 bucks. Usd
Chuck
580 grams I
Mark Hunt Designs
Hide Signatures
(in reply to Doug Cronkhite)
       Post #: 9
RE: HobbyKing Turnigy Rotomax 1.60 - 6/25/2012 3:39 PM
apereira
Score: 100
Status: offline
Avrod,
I bought a Turnigy to try it once, and I had to rework the motor in my lathe, and still taking some material off, it never came close to the advertised weight, after the rework it was still 22gr more than the specs.
Consider also the shipping cost befeore you make a desicion.
Regards
Hide Signatures
(in reply to RC_Pattern_Flyer)
       Post #: 10
RE: HobbyKing Turnigy Rotomax 1.60 - 12/12/2012 10:52 PM
RoyR
Score: 120
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: Flyer88
Bother because the Rotomax is just over $100. Saving a hundred dollars.
Ultra Sport Brotherhood #73
Hide Signatures
(in reply to Flyer88)
       Post #: 11
RE: HobbyKing Turnigy Rotomax 1.60 - 12/12/2012 11:08 PM
BHolsten
Score: 100
Last Login: 5/26/2013
Status: offline
I'll second that Doug.
bholsten
Hide Signatures
       Post #: 12
RE: HobbyKing Turnigy Rotomax 1.60 - 12/13/2012 1:49 AM
Flyer88
Score: 100
Status: offline
Yes but the Bullet is $350 less than a Pletti !
Hide Signatures
(in reply to RoyR)
       Post #: 13
RE: HobbyKing Turnigy Rotomax 1.60 - 12/13/2012 3:52 AM
gaRCfield
Score: 156
Status: offline
Think of $100 as the average cost if 28g savings. That makes the $200 motor a better deal for anyone interested in maintaining weight. Is personally rather invest in something with a good track record and a little customer support.
Joe Marri
Enjoying all things aviation.
Hide Signatures
       Post #: 14
RE: HobbyKing Turnigy Rotomax 1.60 - 12/13/2012 4:07 AM
Flyer88
Score: 100
Status: offline
I have many Turnigy motors running in my airplanes...including a 90 size pattern plane and a 50cc Yak, and they work great.
Im not slamming the brand...but for pattern the Bullet is one of the best buys on the market today.
Just my 2 cents...
Hide Signatures
(in reply to gaRCfield)
       Post #: 15
RE: HobbyKing Turnigy Rotomax 1.60 - 12/13/2012 4:16 AM
Flyer88
Score: 100
Status: offline
Heres a good cheap 10s motor
Specs.
Turns: 22T
Voltage: 10S Lipoly
RPM/V: 215kv
Internal resistance: 0.032 Ohm
Max Loading: 65A
Max Power: 2100W
Shaft Dia: 8.0mm
Bolt holes: 32mm
Bolt thread: M4
Weight: 485g
Motor Plug: 4mm Bullet Connector
Or this one :
Specs.
Turns: 16T
Voltage: 10S Lipoly
RPM/V: 213kv
Internal resistance: 0.023 Ohm
Max Loading: 65A
Max Power: 2550W
Shaft Dia: 8.0mm
Bolt holes: 32mm
Bolt thread: M4
Weight: 706g
< Message edited by Flyer88 -- 12/13/2012 4:48 AM >
Hide Signatures
       Post #: 16
RE: HobbyKing Turnigy Rotomax 1.60 - 12/13/2012 4:19 AM
countilaw
Score: 219
Last Login: 5/24/2013
Status: offline
Just have to remember,  you get what you pay for.    And a  motor that cost  $100  is probaby just  junk to start with.     Plus,  what are you going to do when you need customer service.   Won't get it with Hobby King.    And after  shipping cost,  it's going to be  alot more than $100.
I would bet one of the other  tried and true motors.
Frank
It''s a hobby, not a job.
Hide Signatures
       Post #: 17
RE: HobbyKing Turnigy Rotomax 1.60 - 12/13/2012 4:26 AM
Flyer88
Score: 100
Status: offline
I have to defend some of these lesser brand motors because I have used many with great results.
I have "over-clocked" almost all of them and they just keep running.
Only had one go completely bad on me. But it was my abuse that put it there not the quality of the motor.
Flyer
< Message edited by Flyer88 -- 12/13/2012 5:26 AM >
Hide Signatures
(in reply to countilaw)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
