JMP Accumulator - tips?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> JMP Accumulator - tips?
Page: [1]
Login
JMP Accumulator - tips? - 6/24/2012 3:16 PM
ddennison
Score: 103
Last Login: 5/23/2013
Status: offline
Finished installing my JMP accumulator for the 200SX in the UB after leaking UAT (air and fuel leak not responsive ot PTFE wrapping etc..)
Was wonderinf if those WHO USE THIS have tips for getting this thing running perfectly? Tom told me to place the "in" from the tanks at the highest point and I have done this -it is mounted 45degrees which he states is fine.
I was going to do my usual fill, maybe "drain" a few second off the fill line and then cap. Then start and observe
Should be that simple right? I have never had one where I couldnt see inside. The rest of my install to the tanks is solid, safety wired and not leaking with pressure tests.
Thanks for any thoughts,
Dave
Hide Signatures
       Post #: 1
RE: JMP Accumulator - tips? - 6/24/2012 8:21 PM
David Searles
Score: 115
Status: offline
Dave,
That little part about draining "a few seconds off the fill line" is the key! The Accumulator needs to be purged of all air and that is exactly how it is done. Make sure that the Accumulator actually gets the "final fill" from the onboard tank backflow and it'll work great.
David S
Hide Signatures
(in reply to ddennison)
       Post #: 2
RE: JMP Accumulator - tips? - 6/24/2012 9:08 PM
ddennison
Score: 103
Status: offline
Thanks for the reply!
Dave
Hide Signatures
(in reply to David Searles)
       Post #: 3
RE: JMP Accumulator - tips? - 6/24/2012 9:37 PM
CraigG
Score: 105
Status: offline
I just fueled up all the tanks through the Accumulator the first time, making sure not to get any air in through the fill line when I capped it off, checked for leaks and eventually flew it. No problems ever since. Mine is mounted vertically.
Craig
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 4
RE: JMP Accumulator - tips? - 10/15/2012 11:54 AM
Ragz
Score: 100
Last Login: 5/18/2013
Status: offline
Mine is mounted vertically in a skygate hawk.  Yesterday I noticed bubbles going into the pump when I throttled UP.  There was not a single bubble coming INTO the ACCU from the on board fuel tanks, but several bubbles going up into the pump from the center feed line of the ACCU.
I have not followed the above mentioned purging procedure.  I simply fueled up using the fuel line and started.  If we drain out a bit from the "fill lines" wont air go into the ACCU when you remove the tube to cap it off?  I dont understand why this is a must as other bubble busters dont need this method of purging.  Is the ACCU designed differently that it needs a reverse flow through the main tanks and the fill line?  Is it mentioned in the instruction sheet?
_____________________________
Anurag
Hide Signatures
(in reply to CraigG)
       Post #: 5
RE: JMP Accumulator - tips? - 10/15/2012 12:10 PM
ddennison
Score: 103
Status: offline
I pinch the line afte reversing flow (draining to purge) to cap it without air going back in the line.
Hide Signatures
(in reply to Ragz)
       Post #: 6
RE: JMP Accumulator - tips? - 10/15/2012 12:34 PM
Ragz
Score: 100
Status: offline
OK i understand this.  Do you do this "pinch" with other bubble traps as well?  Is this a must with all air traps?  Or only the accu.
Anurag
Hide Signatures
       Post #: 7
RE: JMP Accumulator - tips? - 10/15/2012 2:01 PM
ddennison
Score: 103
Status: offline
I do. I just bend the tubing and place the stopper in.
Hide Signatures
(in reply to Ragz)
       Post #: 8
RE: JMP Accumulator - tips? - 10/15/2012 6:53 PM
ww2birds
Score: 105
Last Login: 5/22/2013
Status: offline
I installed a little jetcat valve inline with the drain line between the accumulator and the plug, originally as a "belt and suspenders" strategy in case the plug on the fill line leaks (which is a fatal issue...since the bubble trap .. anyone's .. will empty first), but find it very useful to make sure NO air ever gets into the line .. just shut off the fuel can pump when tanks full, then shut the jetcat valve, then plug the fill line at your leisure :-)
Did it on one of my more expensive planes, and have been replicating across the others since it works so nicely.
Agree 100% that the JMP accumulators are nice and 100% trouble free. BV states correctly that you don't get the diagnostic value of seeing a UAT collapse to show fuel plumbing impedance issues, and you don't see air over the fuel at the end of the flight .. but you CAN watch how long it takes for the line from the JMP to the last main tank to flow liquid after starting the fuel fill .. which tells you how much air was in there, if any.
Dave
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.512RCU1
