New to Electrics HELP    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> New to Electrics HELP
Page: [1]
Login
New to Electrics HELP - 6/25/2012 6:14 AM
Flyboydaddy
Score: 100
Last Login: 3/4/2013
Status: offline
Hello my name is Kevin and I have a couple question about electric motors.  I have been flying glo for years but am building a plane that calls for a 15 size glo engine and am considering converting it to electric.  I purchased a Parkzone brushless p-51 and have been enjoying it but do wish it had a bit more power.  I have looked at engines but really don't have a clue as to what to select.  I have seen some of the engines markes as a 15 size etc.  But many are rated differently.  The motor in my P-51 is a brushless 480 outrunner I believe.  So I am not sure what to select, and don't know what the kv rating means, I thought someone said kilavolt, but am not sure and don't have the knoledge to know is that small or large etc.  I know what glo engine sizes are and what types of planes a certain size engine will do.  I would really appreciate any info that anyone has, at this point I am clueless what to select.  I do know that I want this plane I am building to be very fast.  I wish the P-51 I bought was faster. Thanks for any help.
Kevin
Hide Signatures
       Post #: 1
RE: New to Electrics HELP - 6/27/2012 1:07 AM
blvdbuzzard
Score: 123
Last Login: 5/24/2013
Status: offline
There are many motors out there that will be a good fit for your 15 sized plane. The higher the KV rating, the smaller the prop. This is not a perfect way of thinking this through but is sort of close. Low KV rating is like a 4s engine. Swings a larger prop slower. I higher KV rating is a 2s motor spinning a smaller prop faster.
What plane are you thinking of converting to "E" power?
For a standard plane here is a 15 sized setup.
Motor
http://www.hobbypartz.com/96m602-bigfoot15-2826-950kv.html
I used a calc program with an APC 12X6 prop.
ESC
http://www.hobbypartz.com/07e05-proton-40a.html
Battery
http://www.hobbypartz.com/98p-25c-2200-3s1p.html
WATT meter, yes this is a MUST HAVE! If you do not use one, you will let the magic smoke out.
http://www.hobbypartz.com/aeo-p0-watt-meter.html
With the above setup, it calc's out to 67 pounces or 4.1 pounds of thrust.
Here is the online calc program
It may seem like you are learning a new language, because you are Just start plugging numbers in and see what changes. It will take a little time but it should start to become as clear.
Buzz.
Hide Signatures
(in reply to Flyboydaddy)
       Post #: 2
RE: New to Electrics HELP - 7/2/2012 1:45 AM
aeajr
Score: 205
Last Login: 5/21/2013
Status: offline
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
_____________________________
Long Island Silent Flyers
www.lisf.org
Hide Signatures
(in reply to blvdbuzzard)
       Post #: 3
RE: New to Electrics HELP - 9/6/2012 2:54 PM
aeajr
Score: 205
Status: offline
Kevin,
How are you doing?   Tell us of your progress.
www.lisf.org
Hide Signatures
(in reply to aeajr)
       Post #: 4
RE: New to Electrics HELP - 1/4/2013 3:19 PM
aeajr
Score: 205
Status: offline
Kevin?  How you doing?
www.lisf.org
Hide Signatures
(in reply to aeajr)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
