engine out with controllability with spoilers or up aileron only.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> engine out with controllability with spoilers or up aileron only.
Page: [1]
Login
engine out with controllability with spoilers or up ail... - 6/26/2012 1:24 PM
larrysogla
Score: 105
Last Login: 10/29/2012
Status: offline
I read somewhere here in RCU??? that a scale P61 Black Widow with one engine out is completely flyable and controllable because of the spoilers. Now, with our computer radios..............we can program up aileron only to make turns............cancelling the down aileron on the opposite side should make the up aileron only function like a spoiler and help in one engine out situations...........The question is why have the twin flyers not adopted this????? Even with electrics....sometimes the connectors come loose and you still loose an engine. Larry.
Hide Signatures
       Post #: 1
RE: engine out with controllability with spoilers or up... - 6/26/2012 4:41 PM
ps2727
Score: 100
Last Login: 5/22/2013
Status: online
I don't know anything about the P 61 but an engine out produces yaw, and yaw is controlled with rudder. Spoilers are for roll control and while they
will produce a little yaw that is not what they are there for. I think the best way to handle engine outs in models is to be proficient in the use of
the rudder. If you use spoiler only to control yaw in an engine out you will get a little yaw but a lot of roll, which is not what you'll need.
However, it would be an interesting experiment.
Paul
Hide Signatures
(in reply to larrysogla)
       Post #: 2
RE: engine out with controllability with spoilers or up... - 6/26/2012 9:09 PM
mboland
Score: 100
Last Login: 5/13/2013
Status: offline
The P-61 uses a special type of flap known as the Zap Flap in the prototype.
They also used a spoileron in production models.
It does not operate from the trailing edge but is mid chord and raises on the top surface only, just like the air brakes used on a lot of gliders.
This produces roll, and would not assist with the yaw problems encountered with an engine out.
Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf
_____________________________
It''s the quality of life that counts, not the quantity.
Hide Signatures
(in reply to ps2727)
       Post #: 3
RE: engine out with controllability with spoilers or up... - 7/20/2012 7:08 PM
swervo
Score: 100
Last Login: 1/11/2013
Status: offline
the thing you need the most , in engine out flight , is rudder authority . the widow probably handles this well because the rudders are blown .
Hide Signatures
(in reply to mboland)
       Post #: 4
RE: engine out with controllability with spoilers or up... - 7/25/2012 3:23 AM
Wayne22
Score: 105
Last Login: 5/21/2013
Status: offline
Every twin is completely controllable on one engine if you keep the speed above VMC, as Bob Hoover demonstrated from several decades...
All I ask is for a chance to prove that money can't make me happy......
Hide Signatures
(in reply to swervo)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
