X-acto knife sharpening    Gallery
Logged in as Guest
    Search This Thread
Printable Version
DAB-A-GLUE Glue Applicators
Seller:  donnboyd
Details:   $3.95   |  6/3/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Tips & Techniques >> X-acto knife sharpening
Page: [1] 2 3   next >   >>
Login
X-acto knife sharpening - 6/27/2012 9:54 AM
Paul_BB
Score: 100
Last Login: 6/16/2013
Status: offline
Hi everybody,
I would like to sharpen my x-acto blades.
I found on the web japenese sharpening stones.
I think I will buy two stones: one 600/1000 grit and another one 3000/8000 grit.
But before sending out my money I would like to have your advice.
-Paul
_____________________________
"If it looks like a duck, swims like a duck, and quacks like a duck, then it probably is a duck."
Hide Signatures
       Post #: 1
RE: X-acto knife sharpening - 6/27/2012 12:20 PM
snir2001
Score: 100
Last Login: 6/19/2013
Status: offline
I'm using only the 3000/8000 grit with great results.
Hide Signatures
(in reply to Paul_BB)
       Post #: 2
RE: X-acto knife sharpening - 6/27/2012 1:13 PM
Paul_BB
Score: 100
Status: offline
So I only need the 3000/8000 grit. Thanks for the advice.
I found the Kasumi stone:
http://www.everten.com.au/kasumi-whetstone-30008000.html
And the Wüsthof stone:
http://www.paulsfinest.com/Wusthof-Sharpening-Stone-Superfine-1000-2000-3000-8000-Japanese-wood-case.html
Interesting to learn that the Japanese standards 3000/8000 grit corresponds to the European standards 1000/2000 grit.
Hide Signatures
(in reply to snir2001)
       Post #: 3
RE: X-acto knife sharpening - 6/27/2012 2:54 PM
smithcreek
Score: 159
Status: offline
Water stones are very soft and require regular flattening. They will easily gouge when you hold the blade at even a very slightly wrong angle. When I say gouge I mean you will take a thin slice off the stone, they are not like hard Arkansas stones, then you must use a diamond stone to flatten it. They really are not the right tool for the job. If you are dead set on sharpening exacto blades you would be better off buying two small diamond stones or one double sided like this: http://www.sharpeningsupplies.com/6-Double-Sided-Dia-Sharp-Diamond-Stone-P129C3.aspx To polish the edge buy a piece of leather and some polishing compound.
I am a stringed instrument builder by trade, so I spend many hours sharpening plane blades, knives, chisels, gouges, etc. The best advice I can give you is take the money you were going to spend on stones and buy exacto blades in bulk. It's just not worth the time or money sharpening exacto blades. Throw them away when they get too dull to perform the task at hand. I have two #11 knives, one has a fresh blade. When that one loses it's edge I put it in the other handle and throw out the dull one. I bought a pack of 100 blades for $25 about 4 years ago and still have 30-40 left and I've built 9 planes since then. The two stones you linked to cost about $200, at the rate I go through blades that would be roughly 48 years worth of blades.
For a kit you are, and to a kit you shall return.
Hide Signatures
       Post #: 4
RE: X-acto knife sharpening - 6/27/2012 3:11 PM
RAMFlyer
Score: 105
Last Login: 6/20/2013
Status: offline
I agree with smithcreek   It is cheaper in the long run, both time and dollar-wise, to buy bulk blades and just throw away the dull ones.  Just cutting iron-on covering for a medium sized airplane will use up 6 to 8 blades.  Covering material seems to dull blades faster than balsa
Hide Signatures
(in reply to smithcreek)
       Post #: 5
RE: X-acto knife sharpening - 6/27/2012 3:17 PM
raptureboy
Score: 183
Status: offline
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJC80&P=ML Chuck em!
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to RAMFlyer)
       Post #: 6
RE: X-acto knife sharpening - 6/27/2012 3:24 PM
LesUyeda
Score: 151
Status: offline
If you really want to extend the life of the blade, a piece of 400 grit wet or dry sandpaper works just fine for a hone. A little spit on the paper, and a few swipes, and you have a new edge. When you have worn the blad down too short, start on a new one.
Les
Hide Signatures
(in reply to raptureboy)
       Post #: 7
RE: X-acto knife sharpening - 6/27/2012 4:36 PM
Paul_BB
Score: 100
Status: offline
quote:
ORIGINAL: smithcreek
Thank you very much for the enlightenment.
I want to sharpen my exacto blades for two reasons:
- the 1st one is that my wife also wants me to hone her kitchen knifes very very sharply (I hope she does'nt have a hidden agenda regarding my staying in life)
- the 2nd one is that I am reluctant to throwing away steel blades. Maybe am I getting old but I feel this throwing away is a waste, I just can't help it.
I'll follow your advice and will buy a diamond stone.
-Paul
Hide Signatures
       Post #: 8
RE: X-acto knife sharpening - 6/27/2012 4:59 PM
EloyM
Score: 100
Status: offline
Another point to remember is that all hobby knife blades now available are not "Xacto"or Xacto quality.
Some of them are not as sharp to begin with, or re-sharpen well. Definitely throw-aways.
The Xactos - and equally good X-Cell blades no doubt will cost you a bit more, but they are well
worth it.
Hide Signatures
       Post #: 9
RE: X-acto knife sharpening - 6/27/2012 5:16 PM
Paul_BB
Score: 100
Status: offline
quote:
ORIGINAL: LesUyeda
Les
I have already tried sandpaper (400 & 600) but to no avail. Can you describe the way you do it ?
Hide Signatures
(in reply to LesUyeda)
       Post #: 10
RE: X-acto knife sharpening - 6/27/2012 5:39 PM
Paul_BB
Score: 100
Status: offline
quote:
ORIGINAL: raptureboy
Thanks for the link raptureboy.
Hide Signatures
       Post #: 11
RE: X-acto knife sharpening - 6/27/2012 5:44 PM
Rodney
Score: 174
Status: offline
I sharpen my blades all the time using a fairly large assortment of stones,do not know for sure what the grit size is. The blades I use most are those I made from old hacksaw blades as they seem to hold and edge much better than the X-acto. Just break the blades into required size with a cold chisel and anvil and then shape on a grinder and stone to the desired edge. You can shave with most of them. Make the handles out of scrap hardwood.
Hide Signatures
       Post #: 12
RE: X-acto knife sharpening - 6/27/2012 7:52 PM
snir2001
Score: 100
Status: offline
there is another good way.
make friends with people working in the hospital and get yourself surgical blades... they are the best!
Hide Signatures
(in reply to Rodney)
       Post #: 13
RE: X-acto knife sharpening - 6/27/2012 7:55 PM
skeeter_ca
Score: 121
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: Rodney
Boy, do i feel lazy. lol
skeeter
"It is easier to ask for forgiveness than permission".
Hide Signatures
       Post #: 14
RE: X-acto knife sharpening - 6/27/2012 9:13 PM
AA5BY
Score: 153
Status: offline
I also sharpen my blades. Can be done as fast as hunting a new blade and changing it. I use a stone that belonged to my dad.
As to covering, I used to cut covering on glass with xacto blades and of course dulled a great many. I now use a rotary cutter and seamstress mat, which seems superior.
I also agree with use of two knifes with red tape around the handle of one indicating it is reserved for use where it won't be abused.
Hide Signatures
(in reply to skeeter_ca)
       Post #: 15
RE: X-acto knife sharpening - 6/27/2012 10:31 PM
Rodney
Score: 174
Status: offline
Here are some of the blades I made. I used to do a bit of wood carving on small stuff and needed special shaped blades.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to AA5BY)
       Post #: 16
RE: X-acto knife sharpening - 6/27/2012 11:15 PM
Jim Thomerson
Score: 160
Status: offline
The late George Aldrich had a special pocket knife he used only to cut out tissue numbers, and trim. It had a long pointed blade which he had ground, sharpened, whatever, so that the taper from the cutting edge went straight to the back of the blade, a much narrower cutting edge angle than usual. He sharpened it with oil on 600 grit wet or dry sand paper taped own on plate glass.
Hide Signatures
       Post #: 17
RE: X-acto knife sharpening - 6/27/2012 11:24 PM
weboyd
Score: 100
Last Login: 5/22/2013
Status: offline
The best way I have found for sharpening small blades is to use wet/dry sandpaper held in place on a hard surface( i use 1/4" glass) using contact adheasive. I starting with 800 grit and work thru two or three finer grits up to 8000 grit. When the edge shines like a mirror you are able to shave with the blade. Yes it's a lot of work but their is a certain satisfaction in the completed blade.
Hide Signatures
       Post #: 18
RE: X-acto knife sharpening - 6/27/2012 11:27 PM
mike31
Score: 114
Status: offline
Another reason health insurance is so expensive. I know hospitals are thieves but why add fuel to the fire?
Hide Signatures
       Post #: 19
RE: X-acto knife sharpening - 6/28/2012 12:04 AM
flycatch
Score: 118
Status: offline
I heard of cheap modelers but this takes the cake.
Hide Signatures
       Post #: 20
RE: X-acto knife sharpening - 6/28/2012 1:12 AM
Link119
Score: 128
Status: offline
My mom gets me a nice stock of surgical blades. You can always just rehone the blade often (with leather and some polishing paste) or go to the local walmart and pick up a nice supply of wet/dry sandpaper so you can sharpen the blades easily.
Gws Slow Stick Brushless
Hide Signatures
(in reply to flycatch)
       Post #: 21
RE: X-acto knife sharpening - 6/28/2012 1:34 AM
coreman
Score: 100
Last Login: 2/17/2013
Status: offline
I had been buying bulk blades while my daughter was in college for architecture and making lots of models. Lately I have been building a lot of RTF Flat Foamies for sale and I must say that painted EPP foam seems to really dull blades. Cutting the bevels really shows how sharp the blades are. Just for the heck of it I tried a few of the sharpeners I had for the household knives and I found one that did a good job.
Smiths Two-step Knife Sharpener
This .sig intentionally left blank.
Hide Signatures
(in reply to Link119)
       Post #: 22
RE: X-acto knife sharpening - 6/28/2012 6:01 AM
ma_mulcahy
Score: 100
Status: offline
Paul BB, I respect what you would like to do. Unfortunately, our culture here in the US leads us to a lot of disposables. A friend of mine transferred to the UK for work, and was surprised when she went to Tesco and tried to find paper towels that we use by the trillions every year. None were to be found because they use cloth towels and wash them when they get dirty. Maybe someday we'll get back to that standard!
Mike
Waco Brotherhood #215/Ultra Sport Brotherhood #126
Hide Signatures
(in reply to rockin daddy)
       Post #: 23
RE: X-acto knife sharpening - 6/28/2012 7:02 AM
Paul_BB
Score: 100
Status: offline
quote:
ORIGINAL: ma_mulcahy
In France we are like the Japanese: we don't use towels. But unlike the Japanese we have dedicated young women who wipe our a.. each time we defecate. This helps keep the unemployement low. I must agree with you that this is a matter of culture.
Hide Signatures
(in reply to ma_mulcahy)
       Post #: 24
RE: X-acto knife sharpening - 6/28/2012 8:31 AM
Paul_BB
Score: 100
Status: offline
quote:
ORIGINAL: flycatch
Please relax, everything's gonna be all right. Just take your time.
Let me know as soon as you've swallowed this pill.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.297RCU1
