Hitec X4    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Hitec X4 Page: [1]
Login
Hitec X4 - 6/27/2012 10:24 PM
louden
Score: 100
Last Login: 4/16/2013
Status: offline
I am having a problem charging brand new Nimh battery packs to full capacity with the Hitec X4. They come up 800mAh short. What should I set the parameters at for 2700mA 6V and 4.8V battery packs with AA cells?
Louden Kleer
Hide Signatures
       Post #: 1
RE: Hitec X4 - 6/27/2012 10:27 PM
guver
Score: 174
Last Login: 5/24/2013
Status: offline
Which parameters are you interested in or which ones are adjustable? You , of course already have the capacity and cell count. The voltage drop can be default (or 5 mv per cell)
_____________________________
and airplanes were in
Hide Signatures
(in reply to louden)
       Post #: 2
RE: Hitec X4 - 6/28/2012 3:13 PM
louden
Score: 100
Status: offline
Thanks for the reply. the parameters I'm interested in are:
NiMH charge (man or auto?)
NiMH charge current ?.?A
NiMH discharge ?.?A ?.?V
Capacity cutoff on or off? ?mAH
NiMH Sensitivity D.Peak ?mV/cell
I"m using 2700mA 4.8V (4 AA cell) and 6.00V (5 AA cell) packs.
Thanks again
Louden Kleer
Hide Signatures
(in reply to guver)
       Post #: 3
RE: Hitec X4 - 6/28/2012 3:59 PM
t9dragon
Score: 328
Last Login: 5/25/2013
Status: offline
Do you have the manual for the charger?
Hide Signatures
       Post #: 4
RE: Hitec X4 - 6/28/2012 8:03 PM
jmcowart
Score: 100
Status: offline
Charge at C/10 and discharge at C for NiMH packs.
Keep reading the manual, keep reading the blogs, and search the internet - then confirm everything through personal experience.  I think I have ruined two NiMH packs trying to learn the correct settings for the X4 and any battery chemistry.  Good luck.    Mike.
John M. Cowart
Hide Signatures
(in reply to t9dragon)
       Post #: 5
RE: Hitec X4 - 6/28/2012 11:21 PM
guver
Score: 174
Status: offline
quote:
ORIGINAL: louden
I''m using 2700mA 4.8V (4 AA cell) and 6.00V (5 AA cell) packs.
Thanks again
Louden Kleer
You can use manual or auto , but if using manual then set the rate to anything between about 200-500 ma
If you will discharge then the rate can be anything up to around 2 amps with a cutoff range of .8 volts per cell (at 2 amp current) to 1.1 volts per cell (at very low current)
capacity cut-off can be set to anything higher than 2700 mah at fast rates and 4000 mah for using c/10 rate.
delta peak can be set to 3-5 mv per cell.
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
