Replacing the Air in a Jug    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Replacing the Air in a Jug
Page: [1]
Login
Replacing the Air in a Jug - 6/28/2012 9:00 PM
bolar
Score: 105
Last Login: 5/20/2013
Status: offline
Anyone using something like nitrogen in their fuel to try and keep the bad air out? I've noticed once I get to the bottom of a jug my engines start to run finicky. I was thinking putting a gas layer on top of the fuel might help preserve it to the end. I don't get to fly as often as I use to and it can take me a few months, or maybe longer to get through a jug of fuel. I would like the bottom of a jug to burn as good as the top. Thanks.
_____________________________
72 MHz Forever...............or at least until I buy a new radio.
Hide Signatures
       Post #: 1
RE: Replacing the Air in a Jug - 6/28/2012 9:47 PM
Dave Harmon
Score: 101
Status: offline
quote:
ORIGINAL: bolar
Remove from the jug whatever fuel line, connectors and adaptors you are using and put the original neck plug and cap back on the jug.
This will keep the water out whne you are not using it.
If you already have water in the fuel.....well....wait till the next gallon and keep it sealed when not using it.
Forget Mixing Your Own Fuel....It''s Easy But No Longer Needed!
Hide Signatures
(in reply to bolar)
       Post #: 2
RE: Replacing the Air in a Jug - 6/29/2012 12:54 AM
Jim Thomerson
Score: 160
Status: offline
I usually run a jug down to less that 1/4 full, the put it back in the carton and start on a new jug. Once the new jug gets down enough, I pour the old jug in it. I've never noticed any problem and I am presently flying on four year old fuel.
Hide Signatures
(in reply to Dave Harmon)
       Post #: 3
RE: Replacing the Air in a Jug - 6/30/2012 7:25 PM
countilaw
Score: 219
Status: offline
It helps to keep the container of fuel out of direct sunlight.   Store it in a dark cool place.  Like Jim says,   mix the older fuel with the newer.
I heard some guy once say that he squeesed the jug to get the air out then tightened the cap on the jug.     All it did was suck the methanol out of the mix.    Bad news.
Frank
It''s a hobby, not a job.
Hide Signatures
(in reply to Jim Thomerson)
       Post #: 4
RE: Replacing the Air in a Jug - 7/10/2012 9:55 PM
countilaw
Score: 219
Status: offline
Here is something that might work.
http://www.innate.com/Paint/DIY/Must%20Haves.htm
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to countilaw)
       Post #: 5
RE: Replacing the Air in a Jug - 7/11/2012 5:23 PM
bolar
Score: 105
Status: offline
That's interesting. Wow, the price in the description went up quite a bit from the "add to cart" price, ouch!
Hide Signatures
       Post #: 6
RE: Replacing the Air in a Jug - 7/12/2012 6:24 PM
countilaw
Score: 219
Status: offline
The price stayed the same.    It's the cost of shipping that doubled the price.    I've ordered a lot of stuff from this company  and the postage remains at $9.99  total.      They have a lot of stuff that is usable in the hobby.     I like their mixing cups and sticks.     They have squirt botles that work great for fuel and after run oil.
I don't know if the  Oxyblow  will work for perserving fuel,  never tried it for that.   Works great for paint though.  Especially if you are using paint that cost  $200. a qt.
Frank
Hide Signatures
(in reply to bolar)
       Post #: 7
RE: Replacing the Air in a Jug - 7/22/2012 7:43 PM
Sport_Pilot
Score: 233
Status: offline
If you are pumping fuel from the planes tank back into the fuel jug you are putting more water into the fuel jug than you would get from any air in the jug.  When fuel burns it creates a lot of water from the hydrogen atoms in the alcohol  that combines with oxygen.  This is far more water than that in ever very humid hot air.  I wouldn't worry about it, but do keep it sealed.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 8
RE: Replacing the Air in a Jug - 7/25/2012 4:45 AM
jester_s1
Score: 233
Last Login: 5/21/2013
Status: offline
If you don't burn much fuel dividing it up into half gallons or quarts would help. That way most of your fuel is in full sealed jugs until you need it.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 9
RE: Replacing the Air in a Jug - 7/25/2012 6:35 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: jester_s1
This is not required.  If you only have a few ounces of fuel in a jug the air in the jug does not have enough water to be a problem.  The most water you can expect to have is probably about .03 pounds of water per pound of dry air and at about 15 cubic feet per pound of dry air.  The condensed moisture from less than a gallon of very humid air is only about 2 tenths of water.  Since this is air that is over 90 degrees and 100% relative humidity this is just not enough moisture to worry about.  How ever a loose cap exposes the fuel to an unlimited amount of air and moisture.
Hide Signatures
(in reply to jester_s1)
       Post #: 10
RE: Replacing the Air in a Jug - 7/30/2012 5:50 AM
Bobhend
Score: 100
Last Login: 12/1/2012
Status: offline
I just cleared up all my "engine problems" by testing my fuels against new fuel. Turns out I had three old jugs that were definitley bad. I attribute it all to water. I now plan to keep much closer track of my fuels. I did have one older jug that was still good.  I no longer trust the standard DuBro fuel system be fully sealed and I will take it off and put a cap on the jug when not activly flying. I bought several 2 quart jugs from Great Planes to minimize exposure. I gave up on electric pumps and just use a DuBro hand crank pump.   I also decided to not pump fuel out of the tank and back into the jug. I will either pump it into a "used" jug, or keep it in the tank.
I have wondered if those box wine containers could stand up to fuel. That would be an ideal system for keeping moisure out. . If fuel were sold in a one gallon [or larger] box with a hose barb outlet you could gravity feed it into the aircraft tank. No pump, no moisture , no problems.
If anyone knows a way to pour fuel from a gallon jug into a smaller jug, let me know. I use a large funnel and drippage is minimal but it would be slick to find a spout for a gallon jug because the stuff loves to follow down the side of the jug.
Hide Signatures
       Post #: 11
RE: Replacing the Air in a Jug - 7/31/2012 4:26 PM
Sport_Pilot
Score: 233
Status: offline
Again not worth the truouble.  Although a poor seal will cause fuel to asorb more water, and a poor seal or hole in the jug would do that, the major problem is usually that the methanol evaporates leaving a fuel with lots of oil and nitro.  A collapsing jug would not prevent that.
Hide Signatures
(in reply to Bobhend)
       Post #: 12
RE: Replacing the Air in a Jug - 8/5/2012 5:33 PM
LouisB
Score: 103
Status: offline
I heard that some guys use glass marbles/ beads and fill their jugs with it as the fuel level drops. Otherwise, shouldn't one use an air drier to suck air into the jug as you pump fuel out (air displacing fuel)? These air driers are installed on large transformers and consist of cobalt crystals. The crystals absorb the moisture in the air and turns from blue to pink over time. To regenerate it you just need to dry them in the sun/ low heat in the oven.
If you propose to speak first ask yourself: is it true, is it kind, is it necessary?
Hide Signatures
       Post #: 13
RE: Replacing the Air in a Jug - 8/5/2012 5:54 PM
Bobhend
Score: 100
Status: offline
It would be extra work to dry out the dessicant, which is constantly exposed to the atmosphere. Still, if you could get the color-changing crystals in a glass tube, and have only a small air hole, it would be excellent for removing water. However it would not prevent the methanol from evaporating out [see below]. I top off my working jug with a second jug. I found a flexible spout at the Walmart auto section for $ .50. Otherwise, pouring fuel out of a jug requires a big funnel and then you can't see very well. I have also upgraded my two working jugs with Slimline caps [expensive !] because the DuBro and Great Planes do not seal completely.  I think for a low cost solution, epoxy two short brass tubes thru a jug cap. Put a short piece of fuel tubing on the outside of the vent tube. When not in use put your fuel filler fitting into the vent line tube. Then you have a completely sealed system. I had never though about the methanol evaporating out [thanks, Sports Pilot !], just water coming in but sealing the system prevents both. Unfortunately Slimline is undergoing some problems. Ron's Heli South has inventory of parts and pumps.
< Message edited by Bobhend -- 8/5/2012 6:55 PM >
Hide Signatures
(in reply to LouisB)
       Post #: 14
RE: Replacing the Air in a Jug - 2/3/2013 7:41 PM
speedracerntrixie
Score: 189
Status: offline
quote:
ORIGINAL: Bobhend
That is the quickest way to end up with rusted bearings and crank.
Hide Signatures
       Post #: 15
RE: Replacing the Air in a Jug - 2/4/2013 3:19 PM
1QwkSport2.5r
Score: 155
Status: offline
I keep fuel in the tanks all the time, I just disconnect the feed line to the carb and connect it to the pressure line on the tank. I then run the engine until it won't fire anymore and leave the piston at BDC. Works fine for me.
I do not worry about the air in the jug, never had any problems with fuel once I started mixing my own fuel.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 16
RE: Replacing the Air in a Jug - 2/5/2013 4:53 PM
earlwb
Score: 584
Status: offline
I have never bothered with the fuel containers as they emptied out from use. I use it until the container is almost empty. I then dispose of the small amount left and refill the container. I also empty the airplane's fuel tank back into the container when I am done flying that plane too. I have never had a problem with the fuel so far.
I think the problem is not having a good container that is sealed up Ok so it doesn't leak or allow it to breathe (as the temperature changes the air is drawn in when cold and pushed out when hot). Also my containers are sealed all the time. I have seen folks leave their fuel container open at the flying field for hours like that, and then they complain about how the fuel goes bad so fast on them.
I have had problems with those plastic jugs leaking in the past, especially from the bottom, so I use the metal gallon containers for my flight box fuel container.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 17
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> RC Fuels >> Replacing the Air in a Jug
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.907RCU1
